I replaced the lcd bracket. I put everything back together. I placed the humidity sensor wire in the wrong place but did replace everything else correctly. Everything was working but I got a humidity sensor error. After correcting the error, I now can't use all the numbers on the touch panel and the cancel button doesn't work. Any advice?
