Discuss
microwave doesn't work
 in
Microwave Repair
Every time when you do the continuity test, the wires should be disconnected. The microwave MUST be unplugged. I would
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » microwave doesn't work
  #11 (permalink)
Old 12-11-2010, 03:28 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I would just replace the switches. Especially because the substituted switch is absolutely inexpensive. This switch has three terminals compare to the OEM switch which has just two. You have to carefully break off the terminal marked NC.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #12 (permalink)
Old 12-13-2010, 07:36 AM
Junior Member
raylamm05 is on a distinguished road
Default
Which switch should I order?
Ray
  #13 (permalink)
Old 12-13-2010, 07:37 AM
Junior Member
Default Microwave broken
Which switch should I buy?
Ray
  #14 (permalink)
Old 12-13-2010, 01:50 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Ray,
As I posted earlier the substituted switch Part number: AP3186054
__________________
  #15 (permalink)
Old 12-18-2010, 01:52 PM
Junior Member
Default microwave still doesn't work
I replaced the switch. The symptoms are the same. Nothing works. What next?
Ray
Ray,
  #16 (permalink)
Old 12-19-2010, 04:31 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
If you have the schematic for the microwave, can you post it here?
__________________
  #17 (permalink)
Old 12-21-2010, 01:41 PM
Junior Member
See if this attachment helps.
Ray
Quote:
Ray
  #18 (permalink)
Old 12-21-2010, 07:07 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
According to the diagram, the secondary interlock switch in this model is the bottom switch. So if you replaced only the upper switch, replace the bottom switch too.
__________________
  #19 (permalink)
Old 12-22-2010, 06:18 AM
Junior Member
I replaced the bottom switch only.
Ray
  #20 (permalink)
Old 12-22-2010, 03:46 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Ray,
Looks like the problem is a bad power relay on the control board.
- The control board Part number: AP3205428
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Microwave light blew and now microwave doesn't work. swood Microwave Repair 0 08-26-2010 08:59 AM
Microwave does not work yflyer48 Microwave Repair 0 04-11-2010 05:40 PM
GE Microwave turntable does not work scott allen Microwave Repair 0 10-07-2009 08:57 PM
microwave wont work t d curlee Microwave Repair 0 02-21-2009 09:32 AM
Microwave doesn't work Novice Microwave Repair 1 12-08-2008 11:57 AM
