Discuss
GE Microwave - Runs, no heat?
 in
Microwave Repair
Hi all, new to the forums. I have a Ge Microwave (shame on me, no model # with me right
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » GE Microwave - Runs, no heat?
  #1 (permalink)
Old 12-08-2010, 04:43 AM
Junior Member
7upedition is on a distinguished road
Smile GE Microwave - Runs, no heat?
Brand: GE   Age: 1 - 5 years
I have a Ge Microwave (shame on me, no model # with me right now) but the unit functions properly, with the exception that it does not heat food.
I suspect the magnetron is not working? When I measured the resistance between filament terminals i have 7ohms. I read it should be less that 1 ohm. The magentron is an LG 2M246 050GF.
Is this true? Is the magnetron bad? Are these known bad units?
The capacitor tested ok, and I don't suspect the transformer because eveything else functions.
Thanks in advance
  #2 (permalink)
Old 12-08-2010, 04:44 PM
Junior Member
nrowe46 is on a distinguished road
Default
I have a Ge Microwave It is a GE WES13S84SM2SS
Serial TM922492Mbut the unit functions properly, with the exception that it does not heat food. Light lights timer counts down.
  #3 (permalink)
Old 12-22-2010, 09:01 PM
Junior Member
neogara is on a distinguished road
Default
...yes, you have a defective magnetron. It shouldn't read 7 Ohm between leads. Replace it. before you do that, check a h.v. diode also.Good luck!
  #4 (permalink)
Old 12-23-2010, 06:21 AM
Junior Member
Default
Need a special screw driver to open it up. Does anyone know what it is called? Seems to be a central point with a star around it.
  #5 (permalink)
Old 12-23-2010, 11:57 AM
Junior Member
Default microwave will not heat
...I am not sure how it calls, but I call it a "star" srew driver tip. Manufactures LOVE to do that. A reason, so less handy man get into a microware repair business, or do it yourself projects.
  #6 (permalink)
Old 01-25-2011, 03:39 PM
Junior Member
jjpeters1100@yahoo.com is on a distinguished road
Default
They are called tamper proof torx. Same as a regular torx but with a stud in the middle. You can purchase the correct tools at most tool stores.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kitchenaid microwave runs but won't heat ladymay65 Microwave Repair 2 11-01-2013 09:14 AM
Microwave Runs But Will Not Heat sjant73 Microwave Repair 0 11-22-2009 02:30 PM
GE JTP95B microwave runs without heat jtran Microwave Repair 0 09-14-2009 07:49 AM
Microwave runs but does not heat food newell Microwave Repair 0 08-24-2009 09:01 PM
Microwave Runs But Does Not Heat twothguy Microwave Repair 0 10-28-2007 07:05 AM
