| » GE Microwave door handle replacement |
Model Number: SCA1000DBB03 Brand: GE Age: 1 - 5 years
I received the door handle from this site, I was able to remove the Plastic cover 1804 from the door, then I was able to remove the top screw for the door handle. To reach to the bottom screw I need to remove the metal frame which hold the glass.
I cannot remove this , need help on how to remove this and to reach to the bottom screw. Looking forward for your help. Neel Related Models |
You should notice 3 plastic tabs on top an3 3 on bottom, and 2 on each side. You will need to carefully work the metal out of those tabs until it seperates. It is a whole lot easier if you remove the door from the oven first. Take off the grille above the door, it is held in by 2 screws up top, then just lift the door off the hinge.
__________________
There are still 6 weeks left in the NFL regular season, 6 CHANCES TO WIN $10,000 FOR ONLY $39.95!!!! Who wants a chance to win $10,000??? The best fantasy football site around, hosted by Terry Bradshaw!!!!!!!!!!!!!!!!!!!! Sign up here to give abadfish66@cox.net credit for referring you to us. You can also just go to PayTheFan.com and enter "2179" as a Referral Code when you sign up. |
Your gonna have to just work it out. It will come, just takes some finesse, bend the tabs a bit and work it out, one at a time.
__________________
| Display Modes | |
| Microwave Door Handle | weissjp | Microwave Repair | 7 | 08-13-2008 10:56 AM |
| Microwave Door Handle | robcouch@verizon.net | Microwave Repair | 1 | 04-26-2008 06:36 PM |
| Microwave Handle Replacement, yet again. | sandy5j | Microwave Repair | 1 | 03-15-2008 08:50 PM |
| Replacement door handle installation | manushand | Microwave Repair | 0 | 01-05-2008 12:24 PM |
| Microwave Door and Handle Replacement | Lucky | Microwave Repair | 0 | 11-11-2007 08:25 AM |
