Discuss
Replace Microwave Outer Door Glass Panel
 in
Microwave Repair
As I was opening the door on our over-the-range Jenn-Air convection microwave this morning, the exposed right-hand edge of the
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Replace Microwave Outer Door Glass Panel
  #1 (permalink)
Old 11-01-2010, 07:22 PM
Junior Member
ahovde is on a distinguished road
Default Replace Microwave Outer Door Glass Panel
Model Number: JMV9169BAP   Brand: Jenn-Air   Age: 1 - 5 years
As I was opening the door on our over-the-range Jenn-Air convection microwave this morning, the exposed right-hand edge of the outer door glass panel hit the plate I was holding and shattered (a very poor design, in my opinion, but I digress...).
Jenn-Air quoted me $575 for an entire door assembly, however I was able to remove and disassemble the door and am quite confident I could replace the outer glass panel myself; it simply slides into upper and lower slots in the door frame and is held in place by the handle screws which pass though holes in the glass.
So, my first question is, can I get my hands on a replacement Jenn-Air glass panel and, if so, where? The alternative would be to have a local glass shop fabricate, drill and temper a replacement glass panel for about $50, but I would prefer to have the factory part with the Jenn-Air logo.
The second part of my question is, are there any special considerations I should be aware of when undertaking this repair, such as, will it be necessary to have the unit tested for microwave leaks once it is put back together?
Thanks for any assistance!
Related Models
Jenn-Air JMV9169BAP MWAVE- MOUNTED OVER RANGE/WO
Jenn-Air JMV9169BAS MWAVE- MOUNTED OVER RANGE/WO
Jenn-Air JMV9169BAW MWAVE- MOUNTED OVER RANGE/WO
Maytag JMV9186WB0 MICROWAVE OVEN/HOOD 1.8 CU. FT.
Maytag JMV9186WP0 MICROWAVE OVEN/HOOD 1.8 CU. FT.
Maytag JMV9186WR0 MICROWAVE OVEN/HOOD 1.8 CU. FT.
Maytag JMV9186WS0 MICROWAVE OVEN/HOOD 1.8 CU. FT.
Maytag JMV9186WW0 MICROWAVE OVEN/HOOD 1.8 CU. FT.
Maytag JMW2327WB00 27" MICROWAVE / WALL OVEN COMBO
Jenn-Air JMW2327WB01 MICROWAVE
Maytag JMW2327WS00 27" MICROWAVE / WALL OVEN COMBO
Jenn-Air JMW2327WS01 MICROWAVE
Maytag JMW2330WB00 30" MICROWAVE / WALL OVEN COMBO
Maytag JMW2330WS00 30" MICROWAVE / WALL OVEN COMBO
Maytag JMW2427WB00 27" MICROWAVE / WALL OVEN COMBO
Jenn-Air JMW2427WB01 27" MICROWAVE / WALL OVEN COMBO
Maytag JMW2427WS00 27" MICROWAVE / WALL OVEN COMBO
Jenn-Air JMW2427WS01 27" MICROWAVE / WALL OVEN COMBO
Maytag JMW2427WW00 27" MICROWAVE / WALL OVEN COMBO
Jenn-Air JMW2427WW01 27" MICROWAVE / WALL OVEN COMBO
Maytag JMW2430WB00 30" MICROWAVE / WALL OVEN COMBO
Maytag JMW2430WP00 30" MICROWAVE / WALL OVEN COMBO
Maytag JMW2430WR00 30" MICROWAVE / WALL OVEN COMBO
Maytag JMW2430WS00 30" MICROWAVE / WALL OVEN COMBO
Maytag JMW2430WW00 30" MICROWAVE / WALL OVEN COMBO
Maytag JMW3430WB00 30" MICROWAVE / WALL OVEN COMBO
Maytag JMW3430WB01 30" MICROWAVE / WALL OVEN COMBO
Maytag JMW3430WP00 30" MICROWAVE / WALL OVEN COMBO
Maytag JMW3430WP01 30" MICROWAVE / WALL OVEN COMBO
Maytag JMW3430WR00 30" MICROWAVE / WALL OVEN COMBO
Maytag JMW3430WR01 30" MICROWAVE / WALL OVEN COMBO
Maytag JMW3430WS00 30" MICROWAVE / WALL OVEN COMBO
Maytag JMW3430WS01 30" MICROWAVE / WALL OVEN COMBO
Jenn-Air JMW8130AAB WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW8130AAW WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW8130DAB WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW8130DAS WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW8130DAW WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW8330DAB WALLOVEN- S/C MWAVE ELE
Maytag JMW8330DAB15 30" BUILT-IN MICROWAVE/ELECTRIC OVEN COMBO SELF-CLEAN
Jenn-Air JMW8330DAS WALLOVEN- S/C MWAVE ELE
Maytag JMW8330DAS16 30" BUILT-IN MICROWAVE/ELECTRIC OVEN COMBO SELF-CLEAN
Jenn-Air JMW8330DAW WALLOVEN- S/C MWAVE ELE
Maytag JMW8330DAW16 30" BUILT-IN MICROWAVE/ELECTRIC OVEN COMBO SELF-CLEAN
Jenn-Air JMW8527AAB WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW8527AAW WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW8527BAB WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW8527BAW WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW8527CAB WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW8527CAS WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW8527CAW WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW8527DAB WALLOVEN- S/C MWAVE ELE
Maytag JMW8527DAB27 27" BUILT-IN ELECTRIC OVEN NON-CONVECTION
Jenn-Air JMW8527DAQ WALLOVEN- S/C MWAVE ELE
Maytag JMW8527DAQ27 27" BUILT-IN ELECTRIC OVEN NON-CONVECTION
Jenn-Air JMW8527DAS WALLOVEN- S/C MWAVE ELE
Maytag JMW8527DAS28 27" BUILT-IN ELECTRIC OVEN NON-CONVECTION
Jenn-Air JMW8527DAW WALLOVEN- S/C MWAVE ELE
Maytag JMW8527DAW27 27" BUILT-IN ELECTRIC OVEN NON-CONVECTION
Jenn-Air JMW8530AAB WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW8530AAW WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW8530BAB WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW8530BAW WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW8530CAB WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW8530CAS WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW8530CAW WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW8530DAB WALLOVEN- S/C MWAVE ELE
Maytag JMW8530DAB28 30" BUILT-IN ELECTRIC COMBO NON-CONVECTION
Jenn-Air JMW8530DAQ WALLOVEN- S/C MWAVE ELE
Maytag JMW8530DAQ28 30" BUILT-IN ELECTRIC COMBO NON-CONVECTION
Jenn-Air JMW8530DAS WALLOVEN- S/C MWAVE ELE
Maytag JMW8530DAS28 30" BUILT-IN ELECTRIC COMBO NON-CONVECTION
Jenn-Air JMW8530DAW WALLOVEN- S/C MWAVE ELE
Maytag JMW8530DAW29 30" BUILT-IN ELECTRIC COMBO NON-CONVECTION
Jenn-Air JMW9130DAB WALLOVEN- STD MWAVE ELE
Jenn-Air JMW9130DAS WALLOVEN- STD MWAVE ELE
Jenn-Air JMW9130DAW WALLOVEN- STD MWAVE ELE
Jenn-Air JMW9330DAB WALLOVEN- S/C MWAVE ELE
Maytag JMW9330DAB16 30" BUILT-IN MICROWAVE/ELECTRIC OVEN COMBO SELF-CLEAN
Jenn-Air JMW9330DAS WALLOVEN- S/C MWAVE ELE
Maytag JMW9330DAS16 30" BUILT-IN MICROWAVE/ELECTRIC OVEN COMBO SELF-CLEAN
Jenn-Air JMW9330DAW WALLOVEN- S/C MWAVE ELE
Maytag JMW9330DAW16 30" BUILT-IN MICROWAVE/ELECTRIC OVEN COMBO SELF-CLEAN
Jenn-Air JMW9527AAB WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW9527AAQ WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW9527AAW WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW9527BAB WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW9527BAQ WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW9527BAW WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW9527CAB WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW9527CAQ WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW9527CAS WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW9527CAW WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW9527DAB WALLOVEN- S/C MWAVE ELE
Maytag JMW9527DAB29 27" BUILT-IN ELECTRIC OVEN CONVECTION
Jenn-Air JMW9527DAS WALLOVEN- S/C MWAVE ELE
Maytag JMW9527DAS30 27" BUILT-IN ELECTRIC OVEN CONVECTION
Jenn-Air JMW9527DAW WALLOVEN- S/C MWAVE ELE
Maytag JMW9527DAW29 27" BUILT-IN ELECTRIC OVEN CONVECTION
Jenn-Air JMW9530AAB WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW9530AAQ WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW9530AAW WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW9530BAB WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW9530BAQ WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW9530BAW WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW9530CAB WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW9530CAQ WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW9530CAS WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW9530CAW WALLOVEN- S/C MWAVE ELE
Jenn-Air JMW9530DAB WALLOVEN- S/C MWAVE ELE
Maytag JMW9530DAB29 30" BUILT-IN ELECTRIC COMBO CONVECTION
Jenn-Air JMW9530DAS WALLOVEN- S/C MWAVE ELE
Maytag JMW9530DAS30 30" BUILT-IN ELECTRIC COMBO CONVECTION
Jenn-Air JMW9530DAW WALLOVEN- S/C MWAVE ELE
Maytag JMW9530DAW30 30" BUILT-IN ELECTRIC COMBO CONVECTION
General Electric JN30*01 Electric range
General Electric JN30*02 Electric range
General Electric JN319WIW Electric range
General Electric JN322*01 Electric range
General Electric JN322*02 Electric range
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Replace GE Double Oven Door Outer Glass nv1951@hotmail.com Oven Repair (including Ranges and Cooktops) 0 07-24-2010 10:48 PM
Replace inner glass panel on upper oven door gabaldini@gmail.com Oven Repair (including Ranges and Cooktops) 2 05-26-2010 07:22 AM
How to replace outer glass akstuff Oven Repair (including Ranges and Cooktops) 2 01-30-2010 07:37 AM
Replace the shattered outer glass panel laokimeng Oven Repair (including Ranges and Cooktops) 0 11-04-2009 11:50 PM
Replace the shattered outer glass panel laokimeng Oven Repair (including Ranges and Cooktops) 0 11-04-2009 11:47 PM
