Microwave
#1 Posted : Saturday, October 25, 2008 11:47:10 AM(UTC)
Microwave
I had this same problem back in April but the dealer talked me into bringing the microwave in as the parts were covered under warranty. At that time he replaced the magnetron, capacitor and diode. Now I have the same problem again but I can't keep taking it back to the dealer as I will soon have the price of a new microwave.
When I checked the diode I do not receive a reading in either direction even on 20M setting. Checking the capacitor I receive a momentary reading on a 2M setting. Also, checking from both terminals to the capacitor case, I read infinity.
Checking the magnetron from terminal to terminal, I have a reading of .6 ohm on a meter setting of 200. Checking from terminal to the case of the magnetron, I have infinity.
Checking the transformer on a 200 setting, I have .4 ohm from terminal to terminal wires that attach to the magnetron. On the primary winding I have a .6 ohm on a 200 setting. From the red and black wire that goes to the capacitor to ground I have a reading of 92.2 ohm on a 200 setting.
Any feedback you can give me would be greatly appreciated.
Thank you.
repairman08
#2 Posted : Saturday, October 25, 2008 12:36:52 PM(UTC)
repairman08
most times on ge mw its always mag tube and diode
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
no heat from oven or broiler (Oven Repair (including Ranges and Cooktops))
by lennyag 1/5/2024 1:41:07 PM(UTC)
Dryer loud squeaking and no heat (Dryer Repair)
by hackerfam 11/2/2023 10:52:15 AM(UTC)
LG Dryer DLE2301R No Heat (Dryer Repair)
by mhess01 10/19/2023 4:56:37 PM(UTC)
No heat when assembled (Dryer Repair)
by Guest 8/16/2023 3:44:03 AM(UTC)
whirlpool PN# W10339417; no heating after replacing element (Oven Repair (including Ranges and Cooktops))
by Guest 7/13/2023 12:27:07 PM(UTC)
Whirlpool Duet Electric dryer - no heat (Dryer Repair)
by ShawnDS24 2/25/2023 9:08:24 AM(UTC)
No heat, (Dryer Repair)
by tseibring 1/8/2023 7:57:44 AM(UTC)
Brand New LG gas dryer , GAS code, no heat (Dryer Repair)
by lglad 11/24/2022 7:24:02 PM(UTC)
Gas Dryer GE GFDS355GL0MS No Heat. Ignitor is good E11 error. (Dryer Repair)
by jim.starzynski@gmail.com 7/5/2022 6:35:29 PM(UTC)
Dryer starts, does not stop, no heat (Dryer Repair)
by Guest 6/28/2022 11:03:33 AM(UTC)
Samsung Electric Range-No Heat (Oven Repair (including Ranges and Cooktops))
by Jimh64 6/27/2022 8:39:17 AM(UTC)
Samsung Dryer DV448AEP/XAC - no heat (Dryer Repair)
by mgmjtech 5/18/2022 8:22:27 PM(UTC)
heeat turns on no heat comming up through floor register (Heating, Ventilation, and Air Conditioning (HVAC))
by Guest 2/6/2022 2:57:49 PM(UTC)
LG Gas Dryer No Heat - Control Panel? (Dryer Repair)
by TomDBBills 1/29/2022 4:03:42 PM(UTC)
