| » GE Profile Microwave does not heat any more |
Model Number: jvm1871sh04 Brand: GE Age: 5 - 10 years
Our microwave little over 5 years has stopped heating food. In addition it makes a cracking noise while trying to heat. The display control panel works fine, including the vent fan. The fan is normal when it is operated alone. When trying to heat the fan is loud too.
Any thoughts on what could be wrong ? TIA -DM Ads By Google Related Models |
Hi, I am having the same issue with my GE microwave, According to what I have read so far, It could be three parts,
1- Magnetron 2- Capacitor 3- High voltage diode. I have replaced the magnetron ($130.00) it did not fix the problem. I just ordered the other two parts, Whichever part fixes the problem I will keep and return the ones I don't need. Hope this helps. Good Luck. |
nneysari,
It looks like either the diode or capacitor. I wanted to test these components using a multi meter before buying either of these parts. Waiting for the multimeter to arrive in mail. BTW, if your microwave is less than 10 years old the magnetron is covered by GE warranty. What is your model number ? Also, I am not able to open the control panel to get to the capacitor and diode in my microwave. Once I test and conclude those components as defective..I will worry about opening the control panel. Do you know where I may be able to find instructions to open the control panel ? Thanks DM |
Hi, This is Vikki with GE. If you are not trained to work on microwave ovens I must caution you against trying to do so. Microwaves unlike other kitchen appliances contain parts that retain voltage even when the unit is unplugged. This could make for a very dangerous situation for the average do-it-yourselfer.
Quote:
. which should happen in 30 secs as per GE internal wiring diagram or . you can short the terminals of the capacitor using a screwdriver (may generate some sparks) .. search on youtube on how to do this... it is pretty much safe to open the microwave and replace parts. QED. |
I can really feel for you. Im my opinion, if your microwave is not heating the first thing to check is the plug. If there is a blown fuse you can replace that or reset a tripped circuit breaker. Turn the switch on. If it does not work then there might be other issues or you may have to contact a professional. Also sometimes the diode or the capacitor may be bad. Test the capacitor using the voltmeter. The reading should gradually increase to infinity. Test again by reversing the probes. The reading should be the same. If it is not, it is damaged. Similarly, test the diode as well. The two readings have to be opposite. If they are not you need to replace them. But if you are not able to identify the problem, you need to call a professional. If you feel that the microwave cooks unevenly or relatively slowly, examine the voltage at the power supply. If it's less than 115 the trouble is with the electrical service. A bad motor can also cause the problem. To check this, remove the grill at the bottom and check using the voltmeter after setting it to RX1 and removing a lead from the terminals of the motor. You will have to replace the motor if the reading is infinity
I hope you get what you need. Good Luck.... Regards |
Don,
Thanks for your reply. I have tested the diode and capacitor..The diode is the culprit. It shows open in both the direction. Waiting for a generic diode to arrive by mail. Also, the microwave I have has a flow chart to trouble shoot the connections and your description kind of matches the flow chart. And, I guess that is what the tech uses when they come in to troubleshoot. Thanks Again |
copying the text from different thread...posted by magician59
First, disconnect the power and discharge the capacitor by shorting across the terminals.You'll need to see if the main circuit board is sending 120VAC to the power transformer. To do this, first disconnect the output from the transformer to the capacitor. Select a cooking cycle and start it. If you don't get 120VAC to the transformer, the problem is in the control board. Be very careful: You're sticking hands and instruments in the proximity of lethal voltage!If you DO find the correct voltage; since you have already replaced the other major high-voltage components, the transformer is the next logical replacement. Read more: Microwave help PLEASE!!! |
| Display Modes | |
| ge profile microwave | Master Craft | Microwave Repair | 0 | 11-23-2009 10:46 PM |
| GE Profile Microwave | sparkebk | Microwave Repair | 6 | 09-18-2009 10:53 AM |
| GE Profile Microwave | timmy17 | Microwave Repair | 3 | 05-02-2009 11:07 PM |
| Ge Profile Je2160bf Microwave Won't Heat | ALASKACOLE | Microwave Repair | 12 | 02-10-2009 09:28 PM |
| GE Profile microwave doesn't heat | pfai | Microwave Repair | 0 | 02-20-2008 10:20 AM |
