billbr
#1 Posted : Tuesday, September 28, 2010 8:59:29 AM(UTC)
billbr
Kenmore over the range type model 401.80093. eveything but heat works. Do you have a trouble shoot list to follow or more likely place to start based on repair history of the microwave? Of course, discharging Cap is first.
#2 Posted : Tuesday, September 28, 2010 12:48:18 PM(UTC)
Does it make any unusual noise?
The model number you posted is incomplete.
billbr
#3 Posted : Tuesday, September 28, 2010 12:53:37 PM(UTC)
billbr
That is the model number in the owners manuel. I will see what is on the microwave. Did not notice a different noise, I can check it again tonight.
billbr
#4 Posted : Wednesday, September 29, 2010 5:02:46 AM(UTC)
billbr
Gene,
I checked the serial number on the unit and you are correct the full serial number is 401.80093700. I also verified that no unusal noise is apparent when running. I did however find that the external light bulb is blown when checking to make sure eveything is working except heating.
#5 Posted : Wednesday, September 29, 2010 7:10:33 PM(UTC)
The problem can be a bad high voltage transformer, a bad diode, a bad magnetron or a bad control board. The microwave has to be removed from the cabinet for the diagnosis and/or repair.
- The control board Part number: AP4337094
- The magnetron Part number: AP4527211
- The high voltage transformer Part number: AP4216107
- The high voltage diode Part number: AP4232062
