| » replace torsion spring in micro door |
I have a kbmc140hss0 I am stumped I read all the posts for the spring replacement but I cant get the vent off the bottom. The pictures were great in one of the posts but they were for a microwave combo Over/Under. What I have is a Microwave/Convection Oven.
Can anyone tell me how to get the vent of the bottom so I can access the screws that hold the black plastic shield? |
Quote:
At least one person here just took a hack saw blade and trimmed off the screw below the vent. Since the vent does not support anything and surrounded by plastic after re-assembly, it should not be a problem if you have to do that too. |
Quote:
I figured it was the Torx screws up in there. I had to use the screw driver on a slight angle to clear the points of the other screws. The came out ok but the vent wont budge. Something up in there must be binding it. |
Quote:
On this exploded parts diagram, if it is the right diagram, part number 7, which might be the item you are trying to remove, is held in by a screw (number 10) from the rear on the right hand side. If this is not the correct reference, scroll down on this tall image to see other views of other parts of the oven. Hopefully, seeing the parts in roughly their installed position will help you determine how to proceed. My apologies for the earlier poor advice based on a faulty understanding of your model and its unique design challenges. |
I looked at thet diagram and the vent doesn't look anything like that.
The only screws that are accessable are the 2 Torx ones in the bottom openings. Other that that there has to be something eles that I am missing. There are several screws located under the vent but short of bending it up there is no way to get them out. Attached is a picture of the Torx screws. |
Quote:
Quote:
So the wife is on me to get it fixed. Problem is they want $129 for them to come out and install the part. So I called appliancepartspros.com customer service for help. I was told that FACTORY TRAINED TECHNICIANS MONITOR THE FORUMS and chime in on repair issues and they cant help me. So where are they? So beware you may get screwed and have to call for service! I am going to repost the question and see if there really is a Kitchen Aid Technician out there! |
evo, did you try to install the Part number: 4451009
| Display Modes | |
| Replace door torsion spring Kitchen Aid Superba microwave | upsdave | Microwave Repair | 12 | 03-12-2012 02:40 PM |
| Torsion Spring | mtucker1949 | Microwave Repair | 0 | 02-04-2010 08:37 AM |
| replace the torsion spring in micro door | cheftrini | Microwave Repair | 0 | 08-18-2009 02:09 PM |
| How to replace torsion springs/light in KA cabinet micro | rhinorsv | Microwave Repair | 0 | 07-19-2009 12:30 PM |
| Replace Broken Torsion Spring | jamesjeng | Microwave Repair | 1 | 12-31-2007 06:31 PM |
