| » replace torsion spring in micro door |
I replaced both torsion springs for the third time on my kemc308ksso. Used spring numbers 4452395 and 4452396. door drops open if you do not keep hand on it. Do i ned to go with larger spring? I know i replaced blue tipped spring w/ a blue tipped spring and the other springs thickness visualy loked to match the replacement springs size. What am i doing wrong? The blue spring was the broken spring but then i decidd to go ahead and replace both since i had it open.
Thanks so much for the info. It made replacing this torsion spring faily easy. FYI on the later model combined stainless models, you do not have to pull the microwave out. The screw is able to be reached without removing the microwave.
thanks mr Evo for you info, but replacing the heavy spring torsion model KEMC308KSS03 did not bring it back to the level that was holding the door when it was the original part do you now why????
Quote:
do you know if the replaced parts were working as the original
Quote:
Quote:
These are the two springs for the SS model. from post #6 4452396 RH (For SS MDL) heavy spring 4452395 Spring,Torsion LH lightweight spring. Don't know maybe your model is different since mine is a different model than yours. You have to use either, 4452396 RH and 4452395 LH Spring together for mine. or two 4451009 medium weight. Which the Kitchen aid ordering diagram shows. (but I have not tested just told by K.A. They have been wrong before and have never got back to me as they said they would over 10 times. Just wait until you have to price the microwave oven light. You can get them online for as little as $1.98 (OSRAM 64405 S) or at schucks for $7 tail light. Last edited by evo : 10-20-2009 at 03:58 PM. |
| Display Modes | |
| replace burner solenoid | richard | Oven Repair (including Ranges and Cooktops) | 2 | 07-21-2007 11:56 AM |
