| » replace torsion spring in micro door |
ok so both my springs on my SS microwave are broken. i ordered 2 4451009 medium weight spring to replace them as instructed. the first went in perfect as shown on the detail directions and pictures (thanks for the details!!!). the second does not seem to work unless you recommend twisting one end 180 degrees. is there a left and right option for the 4451009 medium weight spring? thanks in advance for you help...
Quote:
Tools needed: Stubby Phillips. Angled screwdriver which can work in tight space http://www.wilsoncombat.com/a_tools_...crewdriver.asp Harborfreight sells an equivalent drive for cheap. 1. Swing open the door. Locate 2 screws on the side of the frame. The head gets exposed on the sides once the door is opened up. (use stubby phillips). Slide down and swing out the trim pieces. 2. Undo the 2 screws that hold the bottom trim piece of the microwave frame. The screws are on the side. 3. Keep the door open and undo 2 screws that hold the front door. [top portion of the door from inside.] Hold on to the door-skin and pull it up and out. [pic 1 from evo] 4. Once the skin is removed, it will expose a plastic shell. Fold the attached part of the door in close position. Dont need to latch it closed. Locate the 2 screws that hold the plastic shell and undo them using the low clearance angled screw driver. ... Look up from below. On my model there are 2 stainless steel "U" pieces that hold the bottom of the door skin. You dont have to remove them form the plastic shell. [pic 7 from evo. there is no metal shielding and you will see black colored plastic] 5. With the plastic shell removed, the torsion spring(s) can be replaced. Once you thread the new spring in, it will take a bit of patience to snap the end in place. 6. Re-assembly is reverse 5 -1 Note: You dont need to detatch the microwave out of the cabinet. Caution: If you have the stainless steel, the bottom of the door can be very sharp. Correction of previous post: Left and Right springs are NOT interchangeable. You can not use the higher tension right for the left spring. Salim Last edited by salimshah : 01-13-2009 at 01:51 AM. Reason: Updates after repairs. |
Quote:
Thank you. |
Great thread Evo!!! My RH torsion spring was the culprit, went to Whirpools site to order the part at $50.00 bucks...founds this site offering the same part for $25
Part Details - WHIRLPOOL Spring, torsion ( right hand) Blue Tip, part number: AP3082257 Thanks again for your help!! |
I just finished changing the RH torsion spring on my KitchenAid stainless steel microwave/oven combo (Model KEMS308GSS) for the fifth time (9/02, 3/05, 2/07, 3/08 and 5/09). This unit was installed in my kitchen in 3/01. I have always replaced the spring with the production unit (4452396). This time I installed the medium spring (4451009) based on the information from this forum. Unfortunately the door is heavier to use now, but if I never have to replace that spring again it will be worth it. I expect the medium spring will last as long as the LH spring (4452395) which has never broken, since the diameters are so close (Med RH: 0.142”, LH: 0.139”). The diameter of the heavy RH production spring is 0.156”.
A few comments about installation:
Thanks to evo for the original detailed instructions and to Toddt for instructions on my exact model number. Since I also had the lower oven door not closing completely problem as described in other threads, I took Toddt's advice about removing lower oven door to make the torsion spring replacement job easier. While the lower door was off I replaced both hinges/springs. So, in the space of a couple of hours I got my microwave door fixed and my lower oven door fixed as well.
Only glitch in the process was that my microwave would not wiggle out far enough to get to the screw above the oven vent tube. Tried and tried and finally wound up hacksawing the head off the screw just inside the vent tube so that I could move the vent tube to the right just far enough to get to the screw. Double victory day! |
Thank you!!! I followed evo's instructions and they worked perfectly. You made it so easy even this non-handy stay-at-home mom was able to replace the spring during my kids' naptime. I'm feeling pretty proud of myself!
| Display Modes | |
| replace burner solenoid | richard | Oven Repair (including Ranges and Cooktops) | 2 | 07-21-2007 11:56 AM |
