Appliance Repair Forum
-   Microwave Repair (http://forum.appliancepartspros.com/microwave-repair/)
-   -   Buzzing Microwave GE XL1800 (http://forum.appliancepartspros.com/microwave-repair/12217-buzzing-microwave-ge-xl1800.html)
diver19 09-22-2008 05:28 PM
Unit has a buzzing noise as soon as you plug it in table doesn't turn and vent louver won't open on its own
Gene 09-23-2008 11:57 AM
Where this noise is coming from?
diver19 09-23-2008 03:22 PM
from behind the control panel
Gene 09-25-2008 11:29 AM
Open the control panel and check all door switches.
Look for an envelope with the tech sheets behind the top grille and post it.
Here are the break down diagrams for the GE microwave Model JVM1860WD001
djman 05-14-2009 01:18 PM
buzzing microwave ge xl1800
check cap. C01 220uf 50 volt
cap. opens allowing ac on the 24 volt dc contacts.
the noise you hear is contact chatter.
jd49 08-17-2011 07:48 PM
Worked Like a Charm ! ! !
C01 cap replacement that is. Got a dozen on ******** for $8.00 free shipping.
Received them two days later. Popped it in - Works like new.
Looks like this was your only post ! ! !
You are the DJMan ! ! !
5_guy 10-18-2011 08:21 PM
Since I stumbled across this Forum as my GE Spacemaker XL1800 is doing the exact same thing (buzzing sound, seems as if there not enough electricity) can someone point me in the direction as to where I can buy this C01 cap? As well as how to replace it since this seems to be the issue?
Thanks in advance
jd49 10-18-2011 09:01 PM
Hope this works for you. I was so lucky to find this post.
I got a dozen CAPs cheap on the site where you can bid for anything:cool:.
Find C1 written on the printer circuit board. You will see the size and the specs 220uf 50 volt written on the side. Using a soldering iron, heat each connection to pop each off the board. Put a new one in the same holes - make sure you get - & + wires in right holes - and re-solder.
5_guy 10-19-2011 08:29 AM
Thanks for the info
chas365 03-01-2013 04:46 PM
Thank you, thank you, thank you, djman! I'm so glad I found this post. I would have been buying a new microwave otherwise. I got double-lucky and found an electronics distribution center in Springfield, OH (just a bit up the road). In a few hours I had the new cap installed and the microwave works great again!
