| » Diode Check??? |
Model Number: MMV4205BAQ Brand: Maytag Age: 1 - 5 years
Oven died completely, no display, fuses ok, checked components using the provided tech sheet, only problem I find is diode coming off of cap.....I get no continuity forward or reverse, and the same with the new diode I purchased, any ideas please
Found the problem, There is an overload located at the top of the cabinet that must carry quite the current, one of the terminal ends was melted. This shuts down power to basically everything. Need to totally remove outer skin of unit and its located under panel near the lamp.
| Display Modes | |
| HV Diode Failure | jbullis | Microwave Repair | 0 | 06-06-2009 04:20 PM |
| No heat and bad diode? | wa9zug | Microwave Repair | 1 | 05-04-2009 06:54 PM |
| diode testing | electricfave | Microwave Repair | 2 | 01-10-2009 03:07 PM |
| HV Diode | tek2349 | Microwave Repair | 0 | 12-28-2008 01:55 PM |
| Good or Bad HV diode | Chuck Sancinito | Microwave Repair | 2 | 07-27-2007 11:30 PM |
