| » Opening door blows fuses |
Model Number: JMC7000ADQ Brand: Jenn-Air Age: More than 10 years
Opening the door to the microwave blows fuses frequently. Under the cover, there is a notice to check the interlock and interlock monitor if it is blowing fuses.
Would replaceing the two door electronic sensors remedy this? It is a stacked unit with the oven, so would like to fix if possible. all other functions work properly. Thanks Dave Ads By Google Related Models |
Quote:
I don't really think you need switches, besides one of the switches you would need is no longer available. If the switches were bad, your problem would be constant, not intermittent. Were it me, I would attempt to realign the door switch mounting assembly. and check the latch hook assembly on the door. A) You may even want to remove the assembly and clean the mini plungers on all the switches. B) I used to use "star washers", when remounting the switch assembly, they help to hold the assembly screws tighter and grip the plastic housing and holds the mounting bracket in place longer.(you can get the washers at any local hardware store). Apparently, you've been inside the control panel assembly, at least,and are aware of the possible shock hazard(s) when working in that area. Good Luck,
__________________
Thanks for allowing AppliancePartsPros.com to assist you, Joe M. APP TEAM Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
| Display Modes | |
| Microwave Blows Fuses | tps | Microwave Repair | 0 | 07-28-2010 05:18 PM |
| blows fuses | herman | Dryer Repair | 3 | 03-10-2010 07:56 AM |
| blows fuses | herman | Dryer Repair | 1 | 03-09-2010 11:15 AM |
| microwave blows fuses | kenjadog | Microwave Repair | 0 | 08-07-2009 07:38 AM |
| Whirlpool microwave blows fuses | jclawman | Microwave Repair | 5 | 01-27-2008 05:46 PM |
