Discuss
Microwave / Oven Combo
 in
Microwave Repair
There's a big copper looking fuse mounted on the top of the microwave - that one is fine. There's also
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Microwave / Oven Combo
  #11 (permalink)
Old 08-29-2008, 06:16 PM
Junior Member
rprprp is on a distinguished road
Default Fuses look good
There's a big copper looking fuse mounted on the top of the microwave - that one is fine. There's also a glass one on the left of the control panel circuit board which is also fine.
Thanks.
  #12 (permalink)
Old 09-02-2008, 02:04 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Check the door switches and, if there is nothing wrong, then the magnetron most likely is bad.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #13 (permalink)
Old 09-02-2008, 02:13 PM
Junior Member
Default Magnetron
It looks like the part number is AP3109457. Is this something that is straightforward to replace? ie diy or professional?
  #14 (permalink)
Old 09-02-2008, 02:20 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Yes, this is the right part number for the magnetron.
This job is not too complicated to do it yourself. Most difficult part is to remove the microwave from the oven cabinet. You'll need to disconnect a lot of wires. Mark them properly to avoid problems with assembly it back.
Be careful and do one thing at a time and you can fix it.
__________________
  #15 (permalink)
Old 09-02-2008, 02:28 PM
Junior Member
Default Thanks for your help
I will let you know how it goes.
  #16 (permalink)
Old 09-06-2008, 07:30 AM
Junior Member
Default Any tips on how to get Microwave out
My magnetron arrived. Do you have any tips or pointers on getting the Microwave out?
  #17 (permalink)
Old 09-06-2008, 12:32 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You can find the complete instructions in this Service manual.
__________________
  #18 (permalink)
Old 09-07-2008, 06:33 AM
Junior Member
Default Magnetron Replaced but over isn't working
I replaced the Magnetron, the microwave is still not heating. I did find from the service manual that when I press the Cancel a code F ' R1 appears on the display on the microwave side of the control panel.
  #19 (permalink)
Old 09-08-2008, 11:32 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Originally Posted by Gene View Post
...Check the door switches...
Did you do it?
__________________
  #20 (permalink)
Old 09-08-2008, 12:16 PM
Junior Member
Default
Not correctly I suspect. I'll check again.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Microwave/oven combo atcac Microwave Repair 2 08-15-2009 07:44 AM
Microwave and oven combo by whirpool Rkassam0786 Microwave Repair 3 08-07-2009 04:56 PM
Oven Microwave combo coh1dlw Microwave Repair 0 06-08-2009 04:48 PM
microwave/oven combo bartsp Microwave Repair 0 02-25-2009 04:41 PM
Whirlpool Microwave-Oven Combo MDVince Microwave Repair 4 01-27-2008 02:17 PM
