tom12345
#1 Posted : Tuesday, August 10, 2010 12:51:45 PM(UTC)
tom12345
I was wondering if its ok to use a stronger magnetron as a replacement in my microwave. It uses a 2m219, but I have a 2m319 from a different microwave. It looks identical and I tested it briefly and it works, but I was wondering if its ok to use as a permanent replacement. The microwave it came out of is actually smaller than the one I want to use it in.
Here are specs I found for the two magnetrons:
2m219:
Voltage (ebm) 4.2kV
Current (Ib) 300mAdc
Maixmum Output (Po) 945W
Frequency (fo) 2458MHz
Filament (Ef) 3.3V
2m319:
Voltage (ebm) 4.4kV
Current (Ib) 320mAdc
Maximum Output (Po) 1050W
Filament (Ef) 3.3V
Thanks for any advice.
Tom
Joe / APP Team
#2 Posted : Tuesday, August 10, 2010 1:26:31 PM(UTC)
Joe / APP Team
2m219:
Voltage (ebm) 4.2kV
Filament (Ef) 3.3V
2m319:
Voltage (ebm) 4.4kV
Filament (Ef) 3.3V
Tom
Tom,
I don't see why you can't leave it in.
You are just inside the 10% tolerance, that most manufacturers use as a rule of thumb.
I don't see much of a change in the performance of the unit.
You should check the capacitor for the same 10% tolerances.
But I'm sure you'll be OK.
:cool:
