Discuss
Jenn-Air Microwave Shuts Down
 in
Microwave Repair
My Jenn-Air Microwave at the beginning operated normally with a sound of an exhaust fan running I noticed that exhaust
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Jenn-Air Microwave Shuts Down
  #1 (permalink)
Old 08-22-2008, 06:47 AM
Junior Member
bheitzen is on a distinguished road
Default Jenn-Air Microwave Shuts Down
Model Number: JMV9169BAS   Brand: Jenn-Air   Age: 1 - 5 years
I noticed that exhaust fan sound stopped one day, however microwave continued to heat food normally
HOWEVER, now when I heat foods for 4+ minutes I run the risk of the unit shutting down completely and acting like it has no power, completely unresponsive.
After about 1 hour unit will come back to life requesting the user to set the time.
I'm thinking that fan sound i'm now NOT HEARING, is an exhaust fan that exhausts mositure, and that moisture is building up in the cook area, and activating a sensor causing the unit to shut down out of safety.
What do you think and how do you think I can fix it?
Thanks for your help.
Brent
Ads By Google
Related Models
Jenn-Air JMV9169BAS Mwave - Mounted Over Range/wo
Jenn-Air JMV9169BAW Mwave - Mounted Over Range/wo
Jenn-Air JMW8130AAB Walloven - S/c Mwave Ele
Jenn-Air JMW8130AAW Walloven - S/c Mwave Ele
Jenn-Air JMW8130DAB Walloven - S/c Mwave Ele
Jenn-Air JMW8130DAS Walloven - S/c Mwave Ele
Jenn-Air JMW8130DAW Walloven - S/c Mwave Ele
Jenn-Air JMW8330DAB Walloven - S/c Mwave Ele
Jenn-Air JMW8330DAS Walloven - S/c Mwave Ele
Jenn-Air JMW8330DAW Walloven - S/c Mwave Ele
Jenn-Air JMW8527AAB Walloven - S/c Mwave Ele
Jenn-Air JMW8527AAW Walloven - S/c Mwave Ele
Jenn-Air JMW8527BAB Walloven - S/c Mwave Ele
Jenn-Air JMW8527BAW Walloven - S/c Mwave Ele
Jenn-Air JMW8527CAB Walloven - S/c Mwave Ele
Jenn-Air JMW8527CAS Walloven - S/c Mwave Ele
Jenn-Air JMW8527CAW Walloven - S/c Mwave Ele
Jenn-Air JMW8527DAB Walloven - S/c Mwave Ele
Jenn-Air JMW8527DAQ Walloven - S/c Mwave Ele
Jenn-Air JMW8527DAS Walloven - S/c Mwave Ele
Jenn-Air JMW8527DAW Walloven - S/c Mwave Ele
Jenn-Air JMW8530AAB Walloven - S/c Mwave Ele
Jenn-Air JMW8530AAW Walloven - S/c Mwave Ele
Jenn-Air JMW8530BAB Walloven - S/c Mwave Ele
Jenn-Air JMW8530BAW Walloven - S/c Mwave Ele
Jenn-Air JMW8530CAB Walloven - S/c Mwave Ele
Jenn-Air JMW8530CAS Walloven - S/c Mwave Ele
Jenn-Air JMW8530CAW Walloven - S/c Mwave Ele
Jenn-Air JMW8530DAB Walloven - S/c Mwave Ele
Jenn-Air JMW8530DAQ Walloven - S/c Mwave Ele
Jenn-Air JMW8530DAS Walloven - S/c Mwave Ele
Jenn-Air JMW8530DAW Walloven - S/c Mwave Ele
Jenn-Air JMW9130DAB Walloven - Std Mwave Ele
Jenn-Air JMW9130DAS Walloven - Std Mwave Ele
Jenn-Air JMW9130DAW Walloven - Std Mwave Ele
Jenn-Air JMW9330DAB Walloven - S/c Mwave Ele
Jenn-Air JMW9330DAS Walloven - S/c Mwave Ele
Jenn-Air JMW9330DAW Walloven - S/c Mwave Ele
Jenn-Air JMW9527AAB Walloven - S/c Mwave Ele
Jenn-Air JMW9527AAQ Walloven - S/c Mwave Ele
Jenn-Air JMW9527AAW Walloven - S/c Mwave Ele
Jenn-Air JMW9527BAB Walloven - S/c Mwave Ele
Jenn-Air JMW9527BAQ Walloven - S/c Mwave Ele
Jenn-Air JMW9527BAW Walloven - S/c Mwave Ele
Jenn-Air JMW9527CAB Walloven - S/c Mwave Ele
Jenn-Air JMW9527CAQ Walloven - S/c Mwave Ele
Jenn-Air JMW9527CAS Walloven - S/c Mwave Ele
Jenn-Air JMW9527CAW Walloven - S/c Mwave Ele
Jenn-Air JMW9527DAB Walloven - S/c Mwave Ele
Jenn-Air JMW9527DAS Walloven - S/c Mwave Ele
Jenn-Air JMW9527DAW Walloven - S/c Mwave Ele
Jenn-Air JMW9530AAB Walloven - S/c Mwave Ele
Jenn-Air JMW9530AAQ Walloven - S/c Mwave Ele
Jenn-Air JMW9530AAW Walloven - S/c Mwave Ele
Jenn-Air JMW9530BAB Walloven - S/c Mwave Ele
Jenn-Air JMW9530BAQ Walloven - S/c Mwave Ele
Jenn-Air JMW9530BAW Walloven - S/c Mwave Ele
Jenn-Air JMW9530CAB Walloven - S/c Mwave Ele
Jenn-Air JMW9530CAQ Walloven - S/c Mwave Ele
Jenn-Air JMW9530CAS Walloven - S/c Mwave Ele
Jenn-Air JMW9530CAW Walloven - S/c Mwave Ele
Jenn-Air JMW9530DAB Walloven - S/c Mwave Ele
Jenn-Air JMW9530DAS Walloven - S/c Mwave Ele
Jenn-Air JMW9530DAW Walloven - S/c Mwave Ele
General Electric JN30*01 Electric range
General Electric JN30*02 Electric range
General Electric JN319WIW Electric range
General Electric JN322*01 Electric range
General Electric JN322*02 Electric range
General Electric JN322*03 Electric range
General Electric JN322*J1 Electric range
General Electric JN322*J2 Electric range
General Electric JN322J3 Electric range
General Electric JN322S2 Gas range
General Electric JN322S3AD Range accessory
General Electric JN322S3WH Range accessory
General Electric JN322V1AD Range accessory
General Electric JN322V1WH Range accessory
General Electric JN327H1AA Electric range
General Electric JN327H1BB Electric range
General Electric JN327H1CC Electric range
General Electric JN327H1WW Electric range
General Electric JN327X1AD Range accessory
General Electric JN327X1CT Range accessory
General Electric JN327X1WH Range accessory
General Electric JN330*01 Electric range
General Electric JN330*02 Electric range
General Electric JN330*03 Electric range
General Electric JN334*01 Electric range
General Electric JN334*02 Electric range
General Electric JN334*03 Electric range
General Electric JN334*J1 Electric range
General Electric JN334*J2 Electric range
General Electric JN334J3 Electric range
General Electric JN334R1 Electric range
General Electric JN334S1 Gas range
General Electric JN335R1 Electric range
General Electric JN335S1AA Range accessory
General Electric JN335S1BB Range accessory
General Electric JN335S1WW Range accessory
General Electric JN361*01 Range accessory
General Electric JN361001 Electric range
General Electric JN630*01 Electric range
General Electric JN630*02 Electric range
General Electric JN630*03 Electric range
General Electric JN634*01 Electric range
General Electric JN634*02 Electric range
General Electric JN634*03 Electric range
General Electric JN634*J1 Electric range
General Electric JN634*J2 Electric range
General Electric JN634J3 Electric range
General Electric JN634R1 Electric range
General Electric JN634S1 Gas range
General Electric JN635R1 Electric range
General Electric JN635S1AA Range accessory
General Electric JN635S1BB Range accessory
General Electric JN635S1WW Range accessory
General Electric JNM1541DM1BB Counter top microwave
General Electric JNM1541DM1CC Counter top microwave
General Electric JNM1541DM1WW Counter top microwave
  #2 (permalink)
Old 08-22-2008, 09:23 AM
Senior Expert
APP Volunteer
libertyappl is on a distinguished road
Default
HI,
It sounds like your fan motor is out, part number AP4217097.
change that and it should take care of your problem.
Nat
  #3 (permalink)
Old 08-22-2008, 11:23 AM
Junior Member
Default
Yea, that sounds like a good place to start to me. Would you say this job is one for the homeowner or technician? My microwave is above my stove. To access the fan motor will I have to remove the microwave from the wall or can I get to it through the inside of the microwave?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Microwave shuts off after 2-3 sec. John_John Microwave Repair 3 12-09-2009 11:18 AM
Microwave shuts off and on s3lambert Microwave Repair 0 12-06-2009 03:57 PM
Microwave shuts off after 30-45 sec and shows F2 FixItRev Microwave Repair 1 10-30-2009 06:39 PM
Whirlpool Microwave Shuts Off alord Microwave Repair 2 09-01-2009 01:17 PM
Microwave Shuts down melangman Microwave Repair 5 05-05-2008 12:10 PM
