Discuss
bulb repacement for built in microwave
 in
Microwave Repair
I am a property manager and found that the light under the microwave did not come on. I removed the
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » bulb repacement for built in microwave
  #1 (permalink)
Old 08-13-2008, 10:06 AM
dwalinski dwalinski is offline
Junior Member
dwalinski is on a distinguished road
Default bulb repacement for built in microwave
Model Number: MH1140XMQ2   Brand: Whirlpool   Age: 1 - 5 years
I am a property manager and found that the light under the microwave did not come on. I removed the long thin glass cover to remove the light bulb but discovered no bulb. Also I don't see any threads for a bulb to be screwed into. Almost looks like the bulb that was there was broken off, but there are no remnants of any bulb parts. I'm stumped. I need to know if this is a standard screw in bulb with a small or medium base and if it is how do I remove the broken base, the oven is unplugged. I was going to use a pair of needlenose pliers to unscrew the base, however, there is nothing that I can see that resembles a light bulb base to grab with the pliers to unscrew. Do I need to remove anything else and what type of bulb is used as a replacement. Any help here is greatly appreciated. Sincerely, Mark
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 08-13-2008, 12:00 PM
ApplianceJunk's Avatar
ApplianceJunk ApplianceJunk is offline
Senior Expert
APP Volunteer
ApplianceJunk is on a distinguished road
Default
Here is the diagram if it help.
__________________
You can Repair your Appliance & we can help with our Appliance Repair Forum and Appliance Repair Blog.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
2006 kenmore microwave light bulb needs replacing rogerskoler Microwave Repair 2 03-31-2008 02:32 PM
30 in Built-in wall oven with upper microwave ifiebrich Oven Repair (including Ranges and Cooktops) 1 03-04-2008 07:20 PM
Litton microwave built in oven ferdshaw Microwave Repair 0 02-18-2008 10:05 PM
Microwave Bulb Replacement cityservices Microwave Repair 0 10-17-2007 02:51 PM
Microwave interior light bulb replacement Ardith Microwave Repair 4 07-26-2007 04:54 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
