Discuss
GE Profile JE2160SF Microwave Dead
 in
Microwave Repair
I got a same problem. I used LOCKING PLIERS to open special screws, easily. Found fuse blew off. Replaced new
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » GE Profile JE2160SF Microwave Dead
  #21 (permalink)
Old 02-10-2015, 10:18 AM
Junior Member
Hoang Nguyen is on a distinguished road
Default
I got a same problem. I used LOCKING PLIERS to open special screws, easily. Found fuse blew off. Replaced new fuse, same problem next day. Some thing else.
  #22 (permalink)
Old 02-10-2015, 11:03 AM
Junior Member
padepede is on a distinguished road
Default Fixed (interlock switches)
Quote:
Originally Posted by padepede View Post
I noticed that the relay(s) click when I press the start. I assume that this means the interlock switches are working, otherwise the timer would not start decrementing, correct? What could be wrong? I still haven't figured out why the fuse popped when the unit was not even in use or how it worked for a day after I replaced the fuse. I would like to repair this unit as I also have the trim kit.
It was the interlock switches. I don't recall if it was one or two. They are trivial to replace. It's been awhile, you unscrew the panel that is behind the keypad and you will see the interlock switches. Most likely it is the topmost switch but check them all with a meter. You can either order replacements online or take them to your local electronics parts store (for example, Frys Electronics) and get replacements. I keep a few around because I had to do this again last year. The switches are inexpensive, a few dollars each I think. I have heard that stopping the oven before opening the door instead of popping the door helps keep the switches functioning longer.
  #23 (permalink)
Old 04-07-2018, 11:33 AM
Junior Member
R Ortiz is on a distinguished road
Default
Thank you very helpful
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Microwave DEAD Kathy Lamprecht Microwave Repair 0 04-15-2009 12:10 PM
GE Profile Dishwasher Front Panel dead Mitch 472 Dishwasher Repair 2 04-12-2009 11:48 AM
GE Profile Dishwasher dead britta923 Dishwasher Repair 0 03-17-2009 05:56 AM
Dead GE profile over range dthickey Microwave Repair 1 09-02-2008 06:11 PM
GE Profile dead, power surge Simbot Microwave Repair 17 07-26-2008 02:18 PM
