Discuss
How to remove advantium door
 in
Microwave Repair
We have an Advantium oven that the outer window cracked. Ordered an entire new door assy. but not sure how
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » How to remove advantium door
  #1 (permalink)
Old 07-25-2008, 07:58 PM
Junior Member
cwill81 is on a distinguished road
Default How to remove advantium door
Model Number: scb2001css   Brand: GE   Age: 5 - 10 years
We have an Advantium oven that the outer window cracked. Ordered an entire new door assy. but not sure how to remove old door? Do I disassemble hinge somehow or does it slide off hinge like an oven door? Thanks
Related Models
General Electric SCB2001CSS03 Counter top microwave
General Electric SCB2001FSS01 Counter top microwave
General Electric SCB2001FSS02 Counter top microwave
General Electric SCB2001KSS01 Counter top microwave
General Electric SCB2001KSS02 Counter top microwave
General Electric SCBC2000CBB001 SPEEDCOOK/MICROWAVE
General Electric SCBC2000CBB01 Counter top microwave
General Electric SCBC2000CCC001 SPEEDCOOK/MICROWAVE
General Electric SCBC2000CCC01 Counter top microwave
General Electric SCBC2000CWW001 SPEEDCOOK/MICROWAVE
General Electric SCBC2000CWW01 Counter top microwave
General Electric SCBC2001CSS001 SPEEDCOOK/MICROWAVE
General Electric SCBC2001CSS01 Counter top microwave
Amana SCD19H REF - SXS/I&W
Amana SCD19J REF - SXS/I&W
Amana SCD22J REF - SXS/I&W
Amana SCD22NL REF - SXS/I&W
Amana SCD22NW REF - SXS/I&W
Amana SCD22TBL REF - SXS/I&W
Amana SCD22TBW REF - SXS/I&W
Amana SCD23VBL REF - SXS/I&W
Amana SCD23VBW REF - SXS/I&W
Amana SCD23VL REF - SXS/I&W
Amana SCD23VW REF - SXS/I&W
Amana SCD25J REF - SXS/I&W
Amana SCD25JB REF - SXS/I&W
Amana SCD25JP REF - SXS/I&W
Amana SCD25N2L REF - SXS/I&W
Amana SCD25N2W REF - SXS/I&W
Amana SCD25NL REF - SXS/I&W
Amana SCD25NW REF - SXS/I&W
Amana SCD25TBL REF - SXS/I&W
Amana SCD25TBW REF - SXS/I&W
Amana SCD25TL REF - SXS/I&W
Amana SCD25TW REF - SXS/I&W
Thermador SCD272T BUILT-IN ELECTRIC OVEN
Thermador SCD302T BUILT-IN ELECTRIC OVEN
Amana SCDE25J REF - SXS/I&W
Amana SCDT20H REF - SXS/I&W
Amana SCDT22H REF - SXS/I&W
Amana SCDT25H REF - SXS/I&W
Jenn-Air SCE30500B RANGE- S/C S/I ELE
Jenn-Air SCE30500W RANGE- S/C S/I ELE
Jenn-Air SCE30600B RANGE- S/C S/I ELE
Jenn-Air SCE30600BC RANGE- S/C S/I ELE
Jenn-Air SCE30600W RANGE- S/C S/I ELE
Jenn-Air SCE30600WC RANGE- S/C S/I ELE
Jenn-Air SCE4320B RANGE- S/C S/I ELE
Jenn-Air SCE4320W RANGE- S/C S/I ELE
Jenn-Air SCE4340B RANGE- S/C S/I ELE
Jenn-Air SCE4340B-C RANGE- S/C S/I ELE
Jenn-Air SCE4340W RANGE- S/C S/I ELE
Jenn-Air SCE4340W-C RANGE- S/C S/I ELE
Jenn-Air SCE70600B RANGE- S/C S/I ELE
Jenn-Air SCE70600W RANGE- S/C S/I ELE
Whirlpool SCF0710HQ00 CHEST
Whirlpool SCF0710HQ01 CHEST
Whirlpool SCF0710HW00 CHEST FREEZER
Whirlpool SCF0710HW01 CHEST FREEZER
Whirlpool SCF0710HW05 CHEST FREEZER
Whirlpool SCF0710KQ00 CHEST FREEZER
Whirlpool SCF0710KQ01 CHEST FREEZER
Whirlpool SCF0710KQ02 CHEST FREEZER
Whirlpool SCF0710KQ03 CHEST FREEZER
Whirlpool SCF0710KQ04 CHEST FREEZER
Whirlpool SCF1510HW00 CHEST FREEZER
Whirlpool SCF1510HW02 CHEST FREEZER
Whirlpool SCF1510HW05 CHEST FREEZER
Jenn-Air SCG20200A RANGE- S/C S/I GAS
Jenn-Air SCG20200B RANGE- S/C S/I GAS
Jenn-Air SCG20200W RANGE- S/C S/I GAS
Thermador SCM-1 SPEED CONTROL
Maytag SCM10DB12 CONVENT GAS CARTRIDGE
Maytag SCM20DB11 GAS GRILLE CARTRIDGE
Whirlpool SCS3004GN0 30" GAS COOKTOP
Whirlpool SCS3004GN1 GAS COOKTOP
Whirlpool SCS3004GS0 30" GAS COOKTOP
Whirlpool SCS3004GS1 GAS COOKTOP
Whirlpool SCS3004GS2 GAS COOKTOP
Whirlpool SCS3004GV1 GAS COOKTOP
Whirlpool SCS3004GV2 GAS COOKTOP
Whirlpool SCS3004GW0 30" GAS COOKTOP
Whirlpool SCS3004GW1 GAS COOKTOP
Whirlpool SCS3004GW2 GAS COOKTOP
Whirlpool SCS3004LW0 GAS COUNTER UNIT
Whirlpool SCS3004LW01 30" GAS COOKTOP
Whirlpool SCS3014GB0 30" GAS CO0KTOP
Whirlpool SCS3014GB1 GAS COOKTOP
Whirlpool SCS3014GB2 COUNTER UNIT, GAS
Whirlpool SCS3014GB3 COOKTOP
  #2 (permalink)
Old 07-25-2008, 08:12 PM
abadfish66's Avatar
Senior Expert
APP Volunteer
abadfish66 is a glorious beacon of light
Default
You need to open the door, and down at the hinge, you will see a hole on each hinge. you will need to get something small enough to go through the hole on each side, and strong enough so it wont break, like a nail. once you have something in those holes, push the door like your closing it, and the hinges will release from inside the cavity. If I'm not mistaken, the new door will come with plastic deals so you can easily put the new door on. Hope I was clear enough.
__________________
  #3 (permalink)
Old 07-27-2008, 01:48 PM
Junior Member
Default Thanks
Your instructions worked great. I used two small S hooks and the door came off so easy. The new door did not come with anything to help install it so i used a clothes hanger to pull the new hinge out far enough to insert an S hook and then reversed the procedure. GE was no help in this unfortunately as they only have the same owners manual as I have. The 'technician' also said they did not have the new door assy to sell me because those items would have to be installed by a technician and then a leak check would be required. I do not see why a leak check would be needed for something like this were it is only one way off/on with no adjustment on the hinge?
Thanks again
  #4 (permalink)
Old 08-13-2008, 02:16 PM
Junior Member
ahcoyne is on a distinguished road
Default
I'm about to replace the whole door of my Jenn Air JMV8000BAB and had the same question. It looks simple to slide the old one out and the new one in, but the company said we'd need a professional or fancy device to check for microwave leaks. Is that just their way of saying, "buy a new microwave instead of fixing the one you have," or is this a real concern that we should check?
  #5 (permalink)
Old 08-13-2008, 02:24 PM
abadfish66's Avatar
Senior Expert
APP Volunteer
Default
I can only speak for the company I work for, but we are required to do a microwave leak check anytime we change a door. It's not a companies way of telling you to buy a new oven, but simply their way of covering theirselves from lawsuits. I have done many door replacements and many repairs to microwaves, and have yet to find a m/w leak.
__________________
  #6 (permalink)
Old 08-13-2008, 04:39 PM
Junior Member
Default
Thanks so much, appreciate your quick answer. That makes sense, is there any possibility of me renting the device to check it or is that something to hire a professional to do? Thanks again!
  #7 (permalink)
Old 12-22-2008, 12:45 PM
Junior Member
jk1399 is on a distinguished road
Default we have the same problem
We are on our 3rd door. All the doors have had the outer glass crack. Were anyone tell you what caused this issue?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Advantium 120 - has your door handle broken? monpeasch Microwave Repair 9 09-01-2015 08:15 AM
How to replace GE advantium door handle tcchristo Microwave Repair 6 11-21-2010 07:24 AM
GE Advantium door assembly westhighlander Microwave Repair 3 12-03-2009 12:58 PM
GE Advantium Microwave Door Replace APBethesda Microwave Repair 0 10-07-2009 02:42 PM
ge advantium door handle estilid Microwave Repair 1 01-23-2009 06:56 PM
