jonsey
#1 Posted : Monday, June 21, 2010 7:53:31 AM(UTC)
jonsey
While baking potatos (4 of them) the microwave stopped dead. It appears it could be a fuse (hopefully). We can do the repair but can't locate where the fuse is. Can anyone help. I called GE - they are useless - I downloaded a schematic drawing with numbers next to parts but no index telling me what the part is or where it is located.
Help!!!
#2 Posted : Monday, June 21, 2010 11:00:56 AM(UTC)
You have to have an Ohmmeter to check some parts for continuity. Very likely the microwave has to be removed from the cabinet for the troubleshooting and/or repair. Let us know when you ready.
The model number you posted is incomplete. Verify and repost it.
jmbII
#3 Posted : Monday, June 21, 2010 3:49:54 PM(UTC)
jmbII
We had a power outage over the weekend. When the power came back on the micro and stove did not come back on. I know the power source is OK. the oven light works and I checked the micro outlet.
I am guessing therre was a power surge when the juice came back on.
Help?:confused:
Microwave GE JVM2070SK manufactured Dec. '05
Range GE JGS905SEKSS " " " "
#4 Posted : Monday, June 21, 2010 4:49:55 PM(UTC)
Help?:confused:
Sounds very strange. A power surge could kill control boards or/and blow fuses, but the ignition for the range surface burners should work. I would double check the voltage at the wall outlets. Make sure there is 120 VAC.
GE SpacemakerXL Microwave Oven (Microwave Repair)
by respis3500 12/6/2007 2:31:32 PM(UTC)
