Discuss
Removing the control panel - how to do it????
 in
Microwave Repair
My Mom's built microwave oven quit working soon after she pushed the start button. Now it has no power
Appliance Repair Forum > Appliance Repair Help > Microwave Repair » Removing the control panel - how to do it????
  #1 (permalink)
Old 07-23-2008, 12:59 PM
sean_lui sean_lui is offline
Junior Member
sean_lui is on a distinguished road
Unhappy Removing the control panel - how to do it????
Model Number: RM278BXV-4   Brand: Whirlpool   Age: More than 10 years
My Mom's built microwave oven quit working soon after she pushed the start button. Now it has no power at all - no light, and the control panel display is blank. The conventional oven at the bottom has a light when we open the door - so we know power is getting to the unit.
It looks like the problem is a fuse or the control panel itself...
The problem I'm having now is that I can't even open the control panel for further troubleshooting. I turned off the breaker at the wall and removed the 2 screws at the top of the panel and now the top can tilt forward a little bit. Then I tried to push it up to unlock it from the tabs at the bottom so I could pull it out, BUT it is really hard. It almost seems that there are other screws securing the panel, but I can't see it.
Could anyone help me and describe how to remove the control panel so I can access the circuit board and/or the fuse(s) to troubleshoot the problem further?
Thank you very much in advance for your help.
Using the diagram below - I removed the 2 screws at the top of the plastic frame (part #1 in the drawing) of the control panel, but still couldn't remove the panel.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=258589
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 07-28-2008, 11:19 AM
Junior Member
Smile I figured it out!
I figured it out...
One has to remove the outer frame/trim of the entire microwave oven then remove the 2 screws at the top of the control panel to gain access to the electrical components inside. On my old GE model, one did not have to remove the trim - the panel would tilt down by removing 2 screws on the left side of the control panel.
With this Whirlpool model (RM278BXV-4), one has to remove 5 screws (3 on top + 1 screw on each of the sides) securing the outer trim frame then take the 2 screws on top of the control panel.
By the way, the reason why the microwave had no power at all was a burnt fuse (250V, 20A) inside the unit (about $1.00).
I hope this helps someone in the future.
Cheers!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Replace control panel or just control panel housing? Max Strano Dishwasher Repair 1 08-26-2008 07:02 PM
Control Panel orange Oven Repair (including Ranges and Cooktops) 1 07-03-2008 04:44 PM
Removing Glass panel jimhammer1 Oven Repair (including Ranges and Cooktops) 1 05-15-2008 10:52 PM
Pain in the butt removing electrical panel repair_steve Washer Repair 1 02-05-2008 12:56 PM
Do I have a bad control panel? wenoch01 Oven Repair (including Ranges and Cooktops) 4 11-05-2007 05:51 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
