| » Removing the control panel - how to do it???? |
Model Number: RM278BXV-4 Brand: Whirlpool Age: More than 10 years
My Mom's built microwave oven quit working soon after she pushed the start button. Now it has no power at all - no light, and the control panel display is blank. The conventional oven at the bottom has a light when we open the door - so we know power is getting to the unit.
It looks like the problem is a fuse or the control panel itself... The problem I'm having now is that I can't even open the control panel for further troubleshooting. I turned off the breaker at the wall and removed the 2 screws at the top of the panel and now the top can tilt forward a little bit. Then I tried to push it up to unlock it from the tabs at the bottom so I could pull it out, BUT it is really hard. It almost seems that there are other screws securing the panel, but I can't see it. Could anyone help me and describe how to remove the control panel so I can access the circuit board and/or the fuse(s) to troubleshoot the problem further? Thank you very much in advance for your help. Using the diagram below - I removed the 2 screws at the top of the plastic frame (part #1 in the drawing) of the control panel, but still couldn't remove the panel. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=258589 |
I figured it out...
One has to remove the outer frame/trim of the entire microwave oven then remove the 2 screws at the top of the control panel to gain access to the electrical components inside. On my old GE model, one did not have to remove the trim - the panel would tilt down by removing 2 screws on the left side of the control panel. With this Whirlpool model (RM278BXV-4), one has to remove 5 screws (3 on top + 1 screw on each of the sides) securing the outer trim frame then take the 2 screws on top of the control panel. By the way, the reason why the microwave had no power at all was a burnt fuse (250V, 20A) inside the unit (about $1.00). I hope this helps someone in the future. Cheers! ![]() |
| Display Modes | |
| Replace control panel or just control panel housing? | Max Strano | Dishwasher Repair | 1 | 08-26-2008 07:02 PM |
| Control Panel | orange | Oven Repair (including Ranges and Cooktops) | 1 | 07-03-2008 04:44 PM |
| Removing Glass panel | jimhammer1 | Oven Repair (including Ranges and Cooktops) | 1 | 05-15-2008 10:52 PM |
| Pain in the butt removing electrical panel | repair_steve | Washer Repair | 1 | 02-05-2008 12:56 PM |
| Do I have a bad control panel? | wenoch01 | Oven Repair (including Ranges and Cooktops) | 4 | 11-05-2007 05:51 PM |
