| » When to consider having your air ducts cleaned |
| View Poll Results: How often do you inspect your air condition system? | |||
| Once a year |
0 | 0% |
| twice a year |
0 | 0% |
| Quarterly |
0 | 0% |
| Only when i think there is a problem. |
0 | 0% |
| Voters: 0. You may not vote on this poll | |||
Brand: -brand- Age: Less than 1 year
You should consider having the air ducts in your home cleaned if:
There is substantial visible mold growth inside hard surface (e.g., sheet metal) ducts or on other components of your heating and cooling system. There are several important points to understand concerning mold detection in heating and cooling systems: Many sections of your heating and cooling system may not be accessible for a visible inspection, so ask the service provider to show you any mold they say exists. You should be aware that although a substance may look like mold, a positive determination of whether it is mold or not can be made only by an expert and may require laboratory analysis for final confirmation. For about $50, some microbiology laboratories can tell you whether a sample sent to them on a clear strip of sticky household tape is mold or simply a substance that resembles it. If you have insulated air ducts and the insulation gets wet or moldy it cannot be effectively cleaned and should be removed and replaced. If the conditions causing the mold growth in the first place are not corrected, mold growth will recur. Ducts are infested with vermin, e.g. (rodents or insects); or Ducts are clogged with excessive amounts of dust and debris and/or particles are actually released into the home from your supply registers. If any of the conditions identified above exists, it usually suggests one or more underlying causes. Prior to any cleaning, retrofitting, or replacing of your ducts, the cause or causes must be corrected or else the problem will likely recur. Some research suggests that cleaning heating and AC cooling system components (e.g., cooling coils, fans and heat exchangers) may improve the efficiency of your system, resulting in a longer operating life, as well as some energy and maintenance cost savings. In the case that you will need an inspection always make sure you hire a professional licensed AC Service technician like the guys of N.R.G Air to assure that your system is working properly and that no other non visual problems hide and make a bigger one in the future. To contact them go to http://www.nrgair.com Ads By Google |
| Display Modes | |
| Right front burner won't light after it was cleaned | lesn | Oven Repair (including Ranges and Cooktops) | 2 | 12-09-2008 06:23 AM |
| Everything Cleaned & Still Not Cold Enough | Remy | Refrigerator & Freezer Repair | 0 | 12-07-2008 09:51 AM |
| Dishes not cleaned | Dreiding | Dishwasher Repair | 1 | 09-08-2008 07:56 PM |
| mico-wave door cleaned | glennj | Microwave Repair | 1 | 08-10-2007 09:15 PM |
