Discuss
Goodman A/C Fan stopped, no cooling
 in
Heating, Ventilation, and Air Conditioning (HVAC)
This is the fan in the outdoor A/C unit. It worked fine earlier today and the unit was cooling the
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » Goodman A/C Fan stopped, no cooling
  #1 (permalink)
Old 05-23-2010, 05:56 PM
Junior Member
redeyedog is on a distinguished road
Default Goodman A/C Fan stopped, no cooling
Model Number: CK24-1B   Brand: -other-   Age: 5 - 10 years
This is the fan in the outdoor A/C unit. It worked fine earlier today and the unit was cooling the house. I came back later and it was 88 degrees inside.
I took note that the indoor furnace/AC fan was blowing air through the vents, although it was just air that wasn't being cooled. I ran outside and noted the compressor was humming but the fan was not turning. The AC unit was very hot to the touch but it was 90 degrees outside today.
I turned off the inside thermostat, waited, turned it back on. Heard the click, then the indoor furnace/AC blower turned on. Air began cominjg through the vents. I ran outside and again heard the compressor humming but the fan on the AC unit was not turning. I shut everything down.
I would appreciate any ideas on whether I should throw in the towel and call the repairman or if this is something I might be able to fix inexpensively.
TIA
BTW, I looked through the grate on top of the unit and saw another tag inside. It said Model#H23B223ABCA
Ads By Google
Related Models
Gaggenau CK260-604
Gaggenau CK270-604
Maytag CK277SS-1 MISC / ACCESSORY
Maytag CK277SS-1V MISC / ACCESSORY
Gaggenau CK390-615
Gaggenau CK394-615
Gaggenau CK396-615
Gaggenau CK590-615
Gaggenau CK596-615
Hardwick CKD7121810AC WALLOVEN- CONT CLEAN GAS
Hardwick CKD7122810AC WALLOVEN- STD GAS
Hardwick CKD7221819A WALLOVEN- CONT CLEAN GAS
Hardwick CKD7221819AC WALLOVEN- STD GAS
Hardwick CKD7222810AC WALLOVEN- STD GAS
Hardwick CKD7222819A WALLOVEN- STD GAS
Hardwick CKD7224810AC WALLOVEN- STD GAS
Hardwick CKD7224819A WALLOVEN- STD GAS
Hardwick CKD7241819A WALLOVEN- CONT CLEAN GAS
Hardwick CKD7242819A WALLOVEN- STD GAS
Hardwick CKD7244819A WALLOVEN- STD GAS
Hardwick CKD9512W439R RANGE-F/S CONT CLEAN GAS
Hardwick CKD9516W421R RANGE-F/S CONT CLEAN GAS
Hardwick CKD9517W429R RANGE-F/S CONT CLEAN GAS
Hardwick CKD9521W439R RANGE-F/S CONT CLEAN GAS
Hardwick CKD9521W79R RANGE- F/S STD GAS
Hardwick CKF9621K-560RQ GAS RANGE
Hardwick CKG4612MA539RG RANGE-F/S CONT CLEAN GAS
Hardwick CKG4612MW539RG RANGE-F/S CONT CLEAN GAS
Hardwick CKG4642MA639RG RANGE-F/S CONT CLEAN GAS
Hardwick CKG4642MW639RG RANGE-F/S CONT CLEAN GAS
Hardwick CKG8421MA729RG WALLOVEN-STD DBL OVEN GAS
Hardwick CKG8421MW729RG WALLOVEN-STD DBL OVEN GAS
Hardwick CKG9622W439RGB RANGE-F/S CONT CLEAN GAS
Hardwick CKG9641W589RGC RANGE-F/S CONT CLEAN GAS
Hardwick CKJ9641A580RW RANGE-F/S CONT CLEAN GAS
Hardwick CKJ9641W580RW RANGE-F/S CONT CLEAN GAS
Hardwick CKM9641A580RW RANGE-F/S CONT CLEAN GAS
Hardwick CKM9641A589RGD RANGE-F/S CONT CLEAN GAS
Hardwick CKM9641W580RW RANGE-F/S CONT CLEAN GAS
Hardwick CKM9641W589RGC RANGE-F/S CONT CLEAN GAS
Hardwick CKM9641W589RGD RANGE-F/S CONT CLEAN GAS
Amana CKS3020LL SURFACE UNIT- GAS
Amana CKS3020WW SURFACE UNIT- GAS
Amana CKU-617 RANGE- S/C S/I DDRAFT GAS
Amana CKU-617A RANGE- S/C S/I DDRAFT GAS
Frigidaire CL16CA1
Frigidaire CL16CA2
Frigidaire CL21CA1
Hardwick CL4-34A9 SURFACE UNIT- GAS
Hardwick CL4-34B9 SURFACE UNIT- GAS
Hardwick CL4-34W9 SURFACE UNIT- GAS
Hardwick CL4-44A9 SURFACE UNIT- GAS
Hardwick CL4-44B9 SURFACE UNIT- GAS
Hardwick CL4-44SA9 SURFACE UNIT- GAS
Hardwick CL4-44SB9 SURFACE UNIT- GAS
Hardwick CL4-44SW9 SURFACE UNIT- GAS
Hardwick CL4-44W9 SURFACE UNIT- GAS
Hardwick CL4-46GA9 SURFACE UNIT- GAS
Hardwick CL4-46GB9 SURFACE UNIT- GAS
Hardwick CL4-46GW9 SURFACE UNIT- GAS
Crosley CLCG500FW0 CROSLEY/LAUNDRY CENTER
Crosley CLCG900FW0 CROSLEY/LAUNDRY CENTER
Maytag CLE700 RANGE- STD MWAVE ELE
Maytag CLE750 RANGE- STD MWAVE ELE
Maytag CLG600 RANGE- STD MWAVE GAS
Maytag CLG601 RANGE- STD MWAVE GAS
Jenn-Air CLGP2720P GAS SURFACE UNIT
Jenn-Air CLGP2720PG GAS SURFACE UNIT
Jenn-Air CLGP2720PK GAS SURFACE UNIT
Jenn-Air CLGP2720PN GAS SURFACE UNIT
Magic Chef CLL1101ADW RANGE- S/C F/S ELE
Magic Chef CLL1120ADH RANGE- F/S STD GAS
Admiral CLR1100AJQ RANGE- F/S STD GAS
Admiral CLR1100AJW RANGE- F/S STD GAS
Magic Chef CLY1610ADB RV RANGE- GAS
Magic Chef CLY1610ADQ RV RANGE- GAS
Magic Chef CLY1610ADW RV RANGE- GAS
Magic Chef CLY1610BDB RV RANGE- GAS
Maytag CLY1610BDB13 16" GAS RV RANGE SUPER BURNER
Magic Chef CLY1610BDQ RV RANGE- GAS
Magic Chef CLY1610BDW RV RANGE- GAS
Magic Chef CLY1611BDH RV RANGE- GAS
Magic Chef CLY1612ADH RV RANGE- GAS
Magic Chef CLY1612BDH RV RANGE- GAS
Magic Chef CLY1620ADB RV RANGE- GAS
Magic Chef CLY1620ADQ RV RANGE- GAS
Magic Chef CLY1620ADS RV RANGE- GAS
Magic Chef CLY1620ADW RV RANGE- GAS
Magic Chef CLY1620BDB RV RANGE- GAS
Maytag CLY1620BDB13 16" GAS RV RANGE SUPER BURNER
Magic Chef CLY1620BDS RV RANGE- GAS
Maytag CLY1620BDS12 16" GAS RV RANGE SUPER BURNER
Magic Chef CLY1620BDW RV RANGE- GAS
Magic Chef CLY1628ADB RV RANGE- GAS
Magic Chef CLY1628BDB RV RANGE- GAS
Magic Chef CLY1631ADB RV RANGE- GAS
Magic Chef CLY1631ADH RV RANGE- GAS
Magic Chef CLY1631ADL RV RANGE- GAS
Magic Chef CLY1631BDB RV RANGE- GAS
Magic Chef CLY1631BDH RV RANGE- GAS
Magic Chef CLY1631BDL RV RANGE- GAS
Magic Chef CLY1631BDT RV RANGE- GAS
Magic Chef CLY1632ADB RV RANGE- GAS
Magic Chef CLY1632ADH RV RANGE- GAS
Magic Chef CLY1632ADL RV RANGE- GAS
Magic Chef CLY1632BDB RV RANGE- GAS
Magic Chef CLY1632BDH RV RANGE- GAS
Magic Chef CLY1632BDL RV RANGE- GAS
Magic Chef CLY1632BDT RV RANGE- GAS
Magic Chef CLY1638BDB RV RANGE- GAS
Magic Chef CLY1641ADB RV RANGE- GAS
Magic Chef CLY1641ADH RV RANGE- GAS
Magic Chef CLY1641ADL RV RANGE- GAS
Magic Chef CLY1641BDB RV RANGE- GAS
Magic Chef CLY1641BDH RV RANGE- GAS
Magic Chef CLY1641BDL RV RANGE- GAS
Magic Chef CLY1641BDT RV RANGE- GAS
Magic Chef CLY1642ADH RV RANGE- GAS
Magic Chef CLY1642BDH RV RANGE- GAS
Magic Chef CLY1645BDB RV RANGE- GAS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Goodman Gas/Electric Package Unit ray1216 Heating, Ventilation, and Air Conditioning (HVAC) 2 05-30-2011 05:35 PM
PLEASE HELP: Refrigerator Stopped Cooling romeroom Refrigerator & Freezer Repair 3 03-08-2010 04:02 AM
Cooling Has Stopped seahawksfan00 Refrigerator & Freezer Repair 0 11-17-2009 02:26 PM
My Fridge stopped cooling brianap Refrigerator & Freezer Repair 1 09-02-2009 05:49 PM
goodman ac. condener 69firebird Heating, Ventilation, and Air Conditioning (HVAC) 2 05-14-2009 05:24 PM
