Discuss
a/c repair
 in
Heating, Ventilation, and Air Conditioning (HVAC)
Unit turns on and fan blows but the compessor doesn't come on so there is no cold air? Related Models
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » a/c repair
  #1 (permalink)
Old 05-04-2010, 01:03 PM
Junior Member
martensrf1 is on a distinguished road
Default a/c repair
Model Number: AGM18GDJ1   Brand: GE   Age: 1 - 5 years
Related Models
Amana AGM199 WASHER-TOP LOADING
General Electric AGM24DHG1 Room air conditioner
General Electric AGM24DHM1 Room air conditioner
General Electric AGM24DJM1 Room air conditioner
Amana AGM339 DRYER- GAS
Amana AGM359 DRYER- GAS
Amana AGM379 WASHER-TOP LOADING
Amana AGM399 WASHER-TOP LOADING
Amana AGM409L DRYER- GAS
Amana AGM409L2 DRYER- GAS
Amana AGM409W DRYER- GAS
Amana AGM409W2 DRYER- GAS
Amana AGM429L2 WASHER-TOP LOADING
Amana AGM429W DRYER- GAS
Amana AGM429W2 DRYER- GAS
Amana AGM439 DRYER- GAS
Amana AGM459 DRYER- GAS
Amana AGM479L2 WASHER-TOP LOADING
Amana AGM479W DRYER- GAS
Amana AGM479W2 DRYER- GAS
Amana AGM499L DRYER- GAS
Amana AGM499L2 DRYER- GAS
Amana AGM499W DRYER- GAS
Amana AGM499W2 DRYER- GAS
Amana AGM584E RANGE- S/I STD GAS
Amana AGM584LL RANGE- S/I STD GAS
Amana AGM584WW RANGE- S/I STD GAS
Amana AGM585E RANGE- S/I STD GAS
Amana AGM585LL RANGE- S/I STD GAS
Amana AGM585WW RANGE- S/I STD GAS
Amana AGM639 DRYER- GAS
Amana AGM659 DRYER- GAS
Amana AGM679L2 WASHER-TOP LOADING
Amana AGM679W DRYER- GAS
Amana AGM679W2 DRYER- GAS
Amana AGM699L DRYER- GAS
Amana AGM699L2 DRYER- GAS
Amana AGM699W DRYER- GAS
Amana AGM699W2 DRYER- GAS
General Electric AGN05LAG1 Room air conditioner
General Electric AGN05LBG1 Room air conditioner
General Electric AGN05LCG1 Room air conditioner
General Electric AGN05LHG1 Room air conditioner
General Electric AGN05LJG1 Room air conditioner
General Electric AGN06LAG1 Room air conditioner
General Electric AGN08FAG1 Room air conditioner
General Electric AGN08FBG1 Room air conditioner
General Electric AGN08FCM1 Room air conditioner
General Electric AGN08FDM1 Room air conditioner
General Electric AGN10AAG1 Room air conditioner
General Electric AGN10ABG1 Room air conditioner
General Electric AGN10ACG1 Room air conditioner
General Electric AGN12AAG1 Room air conditioner
General Electric AGN12ABG1 Room air conditioner
General Electric AGN12ACG1 Room air conditioner
General Electric AGN12ADG1 Room air conditioner
General Electric AGN14AAG1 Room air conditioner
General Electric AGN14AAG2 Room air conditioner
General Electric AGN14ABG1 Room air conditioner
General Electric AGN14ACG1 Room air conditioner
General Electric AGN18DAG1 Room air conditioner
General Electric AGN18DBG1 Room air conditioner
General Electric AGN18DBG2 Room air conditioner
General Electric AGN24DAD1 Room air conditioner
General Electric AGN24DAM1 Room air conditioner
Amana AGOD2750E RANGE- S/C S/I DDRAFT GAS
Amana AGOD2750WW RANGE- S/C S/I DDRAFT GAS
General Electric AGP05LAG1 Room air conditioner
General Electric AGP05LBG1 Room air conditioner
General Electric AGP05LCG1 Room air conditioner
General Electric AGP07LHG1 Room air conditioner
General Electric AGP07LJG1 Room air conditioner
General Electric AGP08AAG1 Room air conditioner
General Electric AGP08AAG2 Room air conditioner
General Electric AGP08FAG1 Room air conditioner
General Electric AGP08FBM1 Room air conditioner
General Electric AGP10AAG1 Room air conditioner
General Electric AGP10ABG1 Room air conditioner
General Electric AGP10ABG2 Room air conditioner
General Electric AGP10ACG1 Room air conditioner
General Electric AGP12AAG1 Room air conditioner
General Electric AGP12AAG2 Room air conditioner
General Electric AGP12ABG1 Room air conditioner
General Electric AGP12ACG1 Room air conditioner
General Electric AGP18DAD1 Room air conditioner
General Electric AGP18DBG1 Room air conditioner
General Electric AGP18DCG1 Room air conditioner
General Electric AGP18DCG2 Room air conditioner
 AGP200VDW0 GAS RANGE
  #2 (permalink)
Old 05-05-2010, 09:29 AM
Junior Member
twojoints is on a distinguished road
Default
Quote:
check the termal switch may triped or burn out
  #3 (permalink)
Old 05-08-2010, 06:07 PM
Senior Expert
APP Volunteer
icehouse is on a distinguished road
Default
Try replacing the capicitor. Looks like a metal can.
__________________
NATE, HVAC Ecellence, NCCER, PHCC Certified Instructor.
a tragedy has happen to me : http://web.me.com/zenzoidman/Bobice/
  #4 (permalink)
Old 05-08-2010, 06:35 PM
Junior Member
jhamp41 is on a distinguished road
Default a/c wont cool
It is a strong possibility that it is the capacitor. The way that you can tell most of the time is the capacitor will be swollen at the top. Be very careful you can get hurt bad if you don't know what you are doing it is always good to let a experience and licensed a/c guy work on it
  #5 (permalink)
Old 05-14-2010, 11:36 AM
Member
tvtech is on a distinguished road
Default
step one verify 220 available
2. manually engage relay (normally there is a plastic piece you can push on the relay.)
3.if compressor hmmms but dont run check start cap
4 if compressor dont even humm check wiring and 220 at both sides of the relay
Basically the thermostat engages the relay that supplies the 220 directly to the compressor like a switch
If you dont have a meter to check the capacitor take it to someone they will probably test it for free.
  #6 (permalink)
Old 05-14-2010, 06:47 PM
Senior Expert
APP Volunteer
Smile
1.This is a widow unit, not central.
2. What you mean is a contactor, not relay.
3. A/C's are mostly PSC compressors.
4. Turn power off and test capacitor with a test meter as follows.
Since this unit uses a dual capacitor (fan & compressor) place
one lead of meter (set to ohms) on center terminal, place other lead on either of existing terminals and observe. If good meter will rise then slowly fall. If it rises and stays or does not move, change capacitor.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
repair rkerns2008 Washer Repair 1 03-10-2010 06:03 PM
repair judykaiser Washer Repair 7 07-30-2009 06:24 AM
Repair a repair Geochemii Refrigerator & Freezer Repair 3 07-06-2009 06:55 AM
repair pepsiman62 Oven Repair (including Ranges and Cooktops) 1 05-24-2009 10:59 AM
