Discuss
electrical smell after blower motor replacement
 in
Heating, Ventilation, and Air Conditioning (HVAC)
I replaced the capacitor and 1/3 hp blower motor on my york/champion heat pump air handler system. motor blows air
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » electrical smell after blower motor replacement
  #1 (permalink)
Old 04-29-2010, 09:16 PM
Junior Member
deltaparis is on a distinguished road
Default electrical smell after blower motor replacement
Model Number: CHPI30-A   Brand: -brand-   Age: Less than 1 year
I replaced the capacitor and 1/3 hp blower motor on my york/champion heat pump air handler system. motor blows air with good force. worries are 1. motor is loud and 2. there is an electrical smell. I am hoping the electrical smell burns off over time. I read a little about the squirrel cage being off balance, but there is only one set screw and it is tight. Also the fit of the squirrel cage bearing is very tight in fact so tight I can't get it back off the motor stem so i know it is not wobbling. I am not as concerned about the noise as I am the smell, but any help for either concern would be appreciated. Also, I heard there is a trick for getting the squirrel cage off using a pipe, but am not sure how it is supposed to work. maybe the squirrel cage is just mounted too far down on the motor stem, but I had to move it down almost all the way for it to fit into the air handler housing. Thanks and good luck with your own projects. I mainly work on computers, so if I can help with that drop me a line.
Ads By Google
Related Models
Whirlpool CHW8990XW0 COMMERCIAL AUTOMATIC WASHER
Whirlpool CHW9900VQ0 COMMERCIAL AUTOMATIC WASHER
Whirlpool CHW9900VQ1 COMMERCIAL AUTOMATIC WASHER
Whirlpool CHW9900WQ0 COMMERCIAL AUTOMATIC WASHER
Amana CI7.7 FREEZER- CHEST
Amana CI8.8 FREEZER- CHEST
Amana CI8.8-C FREEZER- CHEST
Amana CIC-3 REF - TOP MOUNT
Amana CIC-4H REF - TOP MOUNT
Amana CIC3 MISC / ACCESSORY
Amana CIC4 MISC / ACCESSORY
Amana CIC4H MISC / ACCESSORY
Amana CIC4K MISC / ACCESSORY
Maytag CIKHTM-1 MISC / ACCESSORY
Maytag CIKHTM-1V MISC / ACCESSORY
Amana CIM105 REF - BOTTOM MOUNTS
Amana CIM105L REF - BOTTOM MOUNTS
Amana CIM125 REF - BOTTOM MOUNTS
Amana CIM125L REF - BOTTOM MOUNTS
Amana CIM98 REF - BOTTOM MOUNTS
Amana CIM98L REF - BOTTOM MOUNTS
Amana CIMR-19 REF - SXS/I&W
Amana CIMR-22 REF - SXS/I&W
Hardwick CJ1616A49R RANGE- F/S STD GAS
Hardwick CJ1616W49R RANGE- F/S STD GAS
Hardwick CJ1626A49R RANGE- F/S STD GAS
Hardwick CJ1626W49R RANGE- F/S STD GAS
Thermador CJ302UB
Thermador CJ302US
Thermador CJ302UW
Thermador CJ302ZS
Hardwick CJ7121809RC WALLOVEN- STD GAS
Hardwick CJ7122809RC WALLOVEN- STD GAS
Hardwick CJ7141809RC WALLOVEN- STD GAS
Hardwick CJ7141819DE WALLOVEN- STD GAS
Hardwick CJ7142809RC WALLOVEN- STD GAS
Hardwick CJ9641A590R RANGE- F/S STD GAS
Hardwick CJ9641W590R RANGE- F/S STD GAS
Amana CJW1008.A COMMERCIAL MICROWAVES
Amana CJW1008.B COMMERCIAL MICROWAVES
Amana CJW1008.Z COMMERCIAL MICROWAVES
Amana CJW1040.A COMMERCIAL MICROWAVES
Amana CJW1040.B COMMERCIAL MICROWAVES
Amana CJW1040.Z COMMERCIAL MICROWAVES
Gaggenau CK062-604
Gaggenau CK064-604
Gaggenau CK066-604
Gaggenau CK067-604
Gaggenau CK069-604
Gaggenau CK074-604
Gaggenau CK074-614
Gaggenau CK074-624
Gaggenau CK163-604
Gaggenau CK169-604
Gaggenau CK260-604
Gaggenau CK270-604
Maytag CK277SS-1 MISC / ACCESSORY
Maytag CK277SS-1V MISC / ACCESSORY
Gaggenau CK390-615
Gaggenau CK394-615
Gaggenau CK396-615
Gaggenau CK590-615
Gaggenau CK596-615
Hardwick CKD7121810AC WALLOVEN- CONT CLEAN GAS
Hardwick CKD7122810AC WALLOVEN- STD GAS
Hardwick CKD7221819A WALLOVEN- CONT CLEAN GAS
Hardwick CKD7221819AC WALLOVEN- STD GAS
Hardwick CKD7222810AC WALLOVEN- STD GAS
Hardwick CKD7222819A WALLOVEN- STD GAS
Hardwick CKD7224810AC WALLOVEN- STD GAS
Hardwick CKD7224819A WALLOVEN- STD GAS
Hardwick CKD7241819A WALLOVEN- CONT CLEAN GAS
Hardwick CKD7242819A WALLOVEN- STD GAS
Hardwick CKD7244819A WALLOVEN- STD GAS
Hardwick CKD9512W439R RANGE-F/S CONT CLEAN GAS
Hardwick CKD9516W421R RANGE-F/S CONT CLEAN GAS
Hardwick CKD9517W429R RANGE-F/S CONT CLEAN GAS
Hardwick CKD9521W439R RANGE-F/S CONT CLEAN GAS
Hardwick CKD9521W79R RANGE- F/S STD GAS
Hardwick CKF9621K-560RQ GAS RANGE
Hardwick CKG4612MA539RG RANGE-F/S CONT CLEAN GAS
Hardwick CKG4612MW539RG RANGE-F/S CONT CLEAN GAS
Hardwick CKG4642MA639RG RANGE-F/S CONT CLEAN GAS
Hardwick CKG4642MW639RG RANGE-F/S CONT CLEAN GAS
Hardwick CKG8421MA729RG WALLOVEN-STD DBL OVEN GAS
Hardwick CKG8421MW729RG WALLOVEN-STD DBL OVEN GAS
Hardwick CKG9622W439RGB RANGE-F/S CONT CLEAN GAS
Hardwick CKG9641W589RGC RANGE-F/S CONT CLEAN GAS
Hardwick CKJ9641A580RW RANGE-F/S CONT CLEAN GAS
Hardwick CKJ9641W580RW RANGE-F/S CONT CLEAN GAS
Hardwick CKM9641A580RW RANGE-F/S CONT CLEAN GAS
Hardwick CKM9641A589RGD RANGE-F/S CONT CLEAN GAS
Hardwick CKM9641W580RW RANGE-F/S CONT CLEAN GAS
Hardwick CKM9641W589RGC RANGE-F/S CONT CLEAN GAS
Hardwick CKM9641W589RGD RANGE-F/S CONT CLEAN GAS
Amana CKS3020LL SURFACE UNIT- GAS
Amana CKS3020WW SURFACE UNIT- GAS
Amana CKU-617 RANGE- S/C S/I DDRAFT GAS
Amana CKU-617A RANGE- S/C S/I DDRAFT GAS
Frigidaire CL16CA1
Frigidaire CL16CA2
Frigidaire CL21CA1
Hardwick CL4-34A9 SURFACE UNIT- GAS
Hardwick CL4-34B9 SURFACE UNIT- GAS
Hardwick CL4-34W9 SURFACE UNIT- GAS
Hardwick CL4-44A9 SURFACE UNIT- GAS
Hardwick CL4-44B9 SURFACE UNIT- GAS
Hardwick CL4-44SA9 SURFACE UNIT- GAS
Hardwick CL4-44SB9 SURFACE UNIT- GAS
Hardwick CL4-44SW9 SURFACE UNIT- GAS
Hardwick CL4-44W9 SURFACE UNIT- GAS
Hardwick CL4-46GA9 SURFACE UNIT- GAS
Hardwick CL4-46GB9 SURFACE UNIT- GAS
Hardwick CL4-46GW9 SURFACE UNIT- GAS
Crosley CLCG500FW0 CROSLEY/LAUNDRY CENTER
Crosley CLCG900FW0 CROSLEY/LAUNDRY CENTER
Maytag CLE700 RANGE- STD MWAVE ELE
  #2 (permalink)
Old 04-29-2010, 10:08 PM
Senior Expert
APP Volunteer
icehouse is on a distinguished road
Default
Was this a factory direct replacement motor ?
If you need to pry the blower wheel off, sounds like uneven shaft.
__________________
NATE, HVAC Ecellence, NCCER, PHCC Certified Instructor.
a tragedy has happen to me : http://web.me.com/zenzoidman/Bobice/
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Electrical smell from dishwasher. kosherjd@optonline.net Dishwasher Repair 3 03-10-2010 04:21 PM
Motor and Blower Replacement gmoliver Dryer Repair 5 02-22-2010 07:05 AM
Electrical Smell smeiser78 Washer Repair 2 12-15-2009 02:45 PM
kenmore electrical oil smell fastlap Refrigerator & Freezer Repair 3 11-24-2009 07:53 AM
Microwave has a bad electrical smell linda aufderhar Microwave Repair 0 10-15-2009 04:06 PM
