| » Blower Motor Wiring Question |
I stayed up most of the night last night trying to research the 'net to figure out what to do.
I found many potential answers. I decided to go with the simplest set-up first and see what would work. The brown wires are both completely brown, no white stripe. I retested the fuses, which I suspected I had blown in my first wiring attempt. They were good when the repair guy was there, because the compressor was running. The fact that I miswired on my first attempt is why they say "Don't try this at home." I prayed that I hadn't REALLY fried my complete system (and thankful that I hadn't fried myself.) I had, in fact, blown both fuses. I replaced them. I connected the black high speed fan wire to the fan relay. I screwed the green ground wire to the frame. I connected the two brown wires to the capacitor. Yes, I replaced the capacitor & yes, I made sure it was rated for the motor. There had been a blue wire attached to one of the posts on the capacitor going off elsewhere into the system. I reattached that blue wire. I taped off the remaining speed wires. I taped off and DID NOT connect the white wire to anything. I inserted the power cutoff and heard the most beautiful hum in the world. The motor was whirring away. My guess is that the blue wire coming off of the capacitor is acting as the common - return for the motor. It has run fine since this afternoon. - Bill |
Glad you got it fixed.
| Display Modes | |
| Wiring question for Jenn Air oven | ripleys | Oven Repair (including Ranges and Cooktops) | 4 | 02-25-2009 07:56 AM |
| Blower motor for sears furnace | dickcollentine | Heating, Ventilation, and Air Conditioning (HVAC) | 5 | 12-06-2008 05:59 AM |
| Shot motor - remove blower? | kcbyemom | Dryer Repair | 4 | 07-08-2008 04:06 AM |
| Blower motor won't work. | rbeckner2 | Heating, Ventilation, and Air Conditioning (HVAC) | 1 | 02-20-2008 02:45 PM |
| Blower Motor for Sears Furnace | dickcollentine | Heating, Ventilation, and Air Conditioning (HVAC) | 1 | 12-12-2007 12:57 PM |
