Discuss
TRANE XB80 no heat!
 in
Heating, Ventilation, and Air Conditioning (HVAC)
Hello folks! Yesterday after coming home from work I noticed the house was a bit chilly. Noticed air was being
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » TRANE XB80 no heat!
  #1 (permalink)
Old 04-11-2010, 10:40 PM
Junior Member
tommyt37 is on a distinguished road
Default TRANE XB80 no heat!
Brand: -brand-   Age: 1 - 5 years
Hello folks! Yesterday after coming home from work I noticed the house was a bit chilly. Noticed air was being blown but it was only cold air.
The following is what I know and what I have looked at.
1) Heat is commanded vent motor fires up. After about 6 seconds vent motor shuts off and main fan blower kicks on. No flame, no ignition...
2) Error LED flashes 6 times. Supposed to mean 115VAC reveresed polarity or bad ground.
3) I checked all powerI have 120VAC.. getting to the circuit board. I have 120VAC on Primary of transformer and 27VAC on secondary being fed to CB.
4) I have no voltage ever getting sent to Gas valve or ignitor. Have clean filter shorted out safety switched one at a time same results.
This one is bugging me I am not sure what the cause would be... I am thinking it may be the Circuit board but I don't know. About ready to give in and call HVAC tech but any other advice would be welcome.
Regards,
Tom Spokane, WA
Ads By Google
  #2 (permalink)
Old 04-16-2010, 05:04 PM
Senior Expert
APP Volunteer
icehouse is on a distinguished road
Default
http://www.aireng.com/clientuploads/...urnace/tuy.pdf
__________________
NATE, HVAC Ecellence, NCCER, PHCC Certified Instructor.
a tragedy has happen to me : http://web.me.com/zenzoidman/Bobice/
  #3 (permalink)
Old 05-15-2010, 09:07 PM
Member
tvtech is on a distinguished road
Default
6 blink codes is from the control board indicating the problem..... Computer never lie. Check your ground and polarity.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Trane furnace has no heat, fan still working slycer2002 Heating, Ventilation, and Air Conditioning (HVAC) 5 03-16-2010 07:12 AM
Dryer will not heat. It tumbles and cycles but it will not emit any heat. agentsmith0505 Dryer Repair 0 10-14-2009 09:44 AM
Trane XE90 not heating! danielghile Heating, Ventilation, and Air Conditioning (HVAC) 1 10-03-2009 05:30 AM
Is my Trane Gas/Electric overheating? gfergie Heating, Ventilation, and Air Conditioning (HVAC) 1 12-22-2008 10:12 AM
Trane unit working properly, but not blowing cold air Moe Sab Heating, Ventilation, and Air Conditioning (HVAC) 2 06-12-2008 05:57 AM
