Discuss
Unexpected wiring found on existing thermostat
 in
Heating, Ventilation, and Air Conditioning (HVAC)
Hi, I am replacing my thermostat. I've attached a photo of the existing wiring and new wiring. 1. Why is
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » Unexpected wiring found on existing thermostat
  #1 (permalink)
Old 03-20-2010, 10:31 PM
Junior Member
mportobello is on a distinguished road
Default Unexpected wiring found on existing thermostat
Model Number: Trane XE80   Brand: -other-   Age: 5 - 10 years
1. Why is the existing thermostat wired backwards (R --> W and W --> R)?
2. Why is G (fan) controlled by a relay and switch located in the basement rather than the thermostat? Is it for mechanical 2-wire thermostats?
3. Is the new wiring reasonable?
R --> R
W --> W
G --> G
C --> C
Thanks for any help!
Brian
Other details:
Trane XE80 natural gas forced air furnace with White Rodgers 50A65-475 ignition control board
Current thermostat is a LUX 1500
New thermostat is a HAI RC-80
My place is a townhouse condo built 1999 in Calgary, Canada
If attachment doesn't work: FurnaceWiring
Ads By Google
Related Models
Amana TRG16J REF - TOP MOUNT
Amana TRG18J REF - TOP MOUNT
Amana TRG18K REF - TOP MOUNT
Amana TRG18M REF - TOP MOUNT
Amana TRG18N REF - TOP MOUNT
Amana TRG18QB2L REF - TOP MOUNT
Amana TRG18QB2W REF - TOP MOUNT
Amana TRG18QB3G REF - TOP MOUNT
Amana TRG18QB3L REF - TOP MOUNT
Amana TRG18QB3W REF - TOP MOUNT
Amana TRG18QBG REF - TOP MOUNT
Amana TRG18QBL REF - TOP MOUNT
Amana TRG18QBW REF - TOP MOUNT
Amana TRG18SPH REF - TOP MOUNT
Amana TRG20J REF - TOP MOUNT
Amana TRG20M REF - TOP MOUNT
Amana TRG20SPH REF - TOP MOUNT
Amana TRG22J REF - TOP MOUNT
Amana TRGI18J REF - TOP MOUNT
Amana TRGI18QBL REF - TOP MOUNT
Amana TRGI18QBW REF - TOP MOUNT
Amana TRGI20J REF - TOP MOUNT
Amana TRGI22J REF - TOP MOUNT
Amana TRI-17D MISC / ACCESSORY
Amana TRI-17D-1 MISC / ACCESSORY
Amana TRI-17E MISC / ACCESSORY
Amana TRI-17LD MISC / ACCESSORY
Amana TRI-17LD-1 MISC / ACCESSORY
Amana TRI-17LE MISC / ACCESSORY
Amana TRI16K REF - TOP MOUNT
Amana TRI17E MISC / ACCESSORY
Amana TRI17LE MISC / ACCESSORY
Amana TRI18D REF - TOP MOUNT
Amana TRI18D MISC / ACCESSORY
Amana TRI18D-A REF - TOP MOUNT
Amana TRI18D-C REF - TOP MOUNT
Amana TRI18D-G REF - TOP MOUNT
Amana TRI18D-L REF - TOP MOUNT
Amana TRI18E MISC / ACCESSORY
Amana TRI18E-A MISC / ACCESSORY
Amana TRI18E-C MISC / ACCESSORY
Amana TRI18E-G MISC / ACCESSORY
Amana TRI18E-L MISC / ACCESSORY
Amana TRI18J REF - TOP MOUNT
Amana TRI18K REF - TOP MOUNT
Amana TRI18TE REF - TOP MOUNT
Amana TRI18TL REF - TOP MOUNT
Amana TRI18TW REF - TOP MOUNT
Amana TRI18V1E REF - TOP MOUNT
Amana TRI18V1L REF - TOP MOUNT
Amana TRI18V1W REF - TOP MOUNT
Amana TRI20K REF - TOP MOUNT
Amana TRI21S4E REF - TOP MOUNT
Amana TRI21S4L REF - TOP MOUNT
Amana TRI21S4W REF - TOP MOUNT
Amana TRI21VE REF - TOP MOUNT
Amana TRI21VL REF - TOP MOUNT
Amana TRI21VW REF - TOP MOUNT
Amana TRI22S4 REF - TOP MOUNT
Amana TRI22S4E REF - TOP MOUNT
Amana TRI22S4L REF - TOP MOUNT
Amana TRI22S4W REF - TOP MOUNT
Amana TRI22SRL REF - TOP MOUNT
Amana TRI25S5E REF - TOP MOUNT
Amana TRI25S5L REF - TOP MOUNT
Amana TRI25S5W REF - TOP MOUNT
Amana TRI25VE REF - TOP MOUNT
Amana TRI25VL REF - TOP MOUNT
Amana TRI25VW REF - TOP MOUNT
Admiral TRIS225BAW REF - SXS/I&W
Admiral TRIS225FAW REF - SXS/I&W
Admiral TRIS245BBW REF - SXS/I&W
Admiral TRIS245FBW REF - SXS/I&W
Frigidaire TRS20WRHD0 Tap(v1) / Refrigerator
Frigidaire TRS20WRHD1 Tap(v1) / Side By Side Refrigerator
Frigidaire TRS20WRHD2 Tap(v1) / Side By Side Refrigerator
Frigidaire TRS20WRHD3 Tap(v2) / Side By Side Refrigerator
Frigidaire TRS20WRHD4 Tap(v1) / Refrigerator
Frigidaire TRS20WRHD5 Tap(v1) / Refrigerator
Frigidaire TRS20WRHW0 Tap(v2) / Refrigerator
Frigidaire TRS20WRHW1 Tap(v2) / Side By Side Refrigerator
Frigidaire TRS20WRHW2 Tap(v3) / Side By Side Refrigerator
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thermostat wiring BrewerIA Dryer Repair 1 03-15-2010 07:10 AM
Thermostat wiring wrktem Dryer Repair 0 02-04-2010 10:39 AM
New thermostat won't plug into wiring. Jim Roethler Oven Repair (including Ranges and Cooktops) 3 10-21-2009 12:36 PM
New thermostat won't plug into wiring. Jim Roethler Oven Repair (including Ranges and Cooktops) 3 10-20-2009 09:24 PM
Wiring Oven Thermostat lbosma Oven Repair (including Ranges and Cooktops) 0 05-15-2008 12:47 PM
