Discuss
Rheem Heat Pump Help
 in
Heating, Ventilation, and Air Conditioning (HVAC)
My heat pump is 2 years old. When the compressor tries to come on, it just grinds for a few
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » Rheem Heat Pump Help
  #1 (permalink)
Old 03-03-2010, 02:36 PM
Junior Member
bradford is on a distinguished road
Default Rheem Heat Pump Help
Model Number: RPNE-060JAZ   Brand: -other-   Age: 1 - 5 years
My heat pump is 2 years old. When the compressor tries to come on, it just grinds for a few seconds. Then it stops for a bit. Then tries again. Then stops. Then tries again. Etc. When it tries, the lits dim in the house a bit. The contactors are good. The capacitor APPEARS to be good. Sometimes the compressor will come on after a few tries. Sometimes it may be a few hours. Sometimes it never does come on. I know this should be under warranty, but getting someone out to fix it under warranty has proven difficult. Are there any steps anyone would recommend that I could try to troubleshooting it myself? I have read on the Web where the board in this model is actually a recall, but would that cause stuff like this? Any help that anyone could offer would be so greatly appreciated.
Thanks in advance.
Related Models
Amana RR MWAVE - FAMILY SIZE (60 HZ)
Amana RR-1 RANGE- S/C S/I DDRAFT GAS
Amana RR-10 MWAVE - FAMILY SIZE (60 HZ)
Amana RR-1000 RANGE- S/C S/I DDRAFT GAS
Amana RR-1000 MWAVE- CNTRTP / STAND ALONE
Amana RR-1010 RANGE- S/C S/I DDRAFT GAS
Amana RR-1010 MWAVE- CNTRTP / STAND ALONE
Amana RR-10A MWAVE - FAMILY SIZE (60 HZ)
Amana RR-10A MWAVE- CNTRTP / STAND ALONE
Amana RR-1110 MWAVE - FAMILY SIZE (60 HZ)
Amana RR-1225 MWAVE- CNTRTP / STAND ALONE
Amana RR-3H RANGE- S/C S/I DDRAFT GAS
Amana RR-4 RANGE- S/C S/I DDRAFT GAS
Amana RR-4D RANGE- S/C S/I DDRAFT GAS
Amana RR-4DW RANGE- S/C S/I DDRAFT GAS
Amana RR-5B MWAVE- CNTRTP / STAND ALONE
Amana RR-7 RANGE- S/C S/I DDRAFT GAS
Amana RR-700 RANGE- S/C S/I DDRAFT GAS
Amana RR-700 MWAVE- CNTRTP / STAND ALONE
Amana RR-7A MWAVE - FAMILY SIZE (60 HZ)
Amana RR-7B MWAVE - FAMILY SIZE (60 HZ)
Amana RR-7B MWAVE- CNTRTP / STAND ALONE
Amana RR-7D RANGE- S/C S/I DDRAFT GAS
Amana RR-7DA MWAVE - FAMILY SIZE (60 HZ)
Amana RR-8 MWAVE - FAMILY SIZE (60 HZ)
Amana RR-800 MWAVE- CNTRTP / STAND ALONE
Amana RR-810 MWAVE- CNTRTP / STAND ALONE
Amana RR-810 MWAVE - FAMILY SIZE (60 HZ)
Amana RR-820 MWAVE- CNTRTP / STAND ALONE
Amana RR-8A MWAVE - FAMILY SIZE (60 HZ)
Amana RR-8B MWAVE - FAMILY SIZE (60 HZ)
Amana RR-8T MWAVE- CNTRTP / STAND ALONE
Amana RR-8TC MWAVE- CNTRTP / STAND ALONE
Amana RR-9 RANGE- S/C S/I DDRAFT GAS
Amana RR-900 MWAVE- CNTRTP / STAND ALONE
Amana RR-910 RANGE- S/C S/I DDRAFT GAS
Amana RR-910 MWAVE- CNTRTP / STAND ALONE
Amana RR-9T MWAVE - FAMILY SIZE (60 HZ)
Amana RR-9TA MWAVE - FAMILY SIZE (60 HZ)
Amana RR-9TA MWAVE- CNTRTP / STAND ALONE
Amana RR-9TB MWAVE - FAMILY SIZE (60 HZ)
Amana RR-9TB MWAVE- CNTRTP / STAND ALONE
Amana RR-II RANGE- S/C S/I DDRAFT GAS
Amana RR1020 MWAVE- CNTRTP / STAND ALONE
Amana RR1220 MWAVE- CNTRTP / STAND ALONE
Amana RR2 MWAVE- CNTRTP / STAND ALONE
Amana RR510 MWAVE- CNTRTP / STAND ALONE
Amana RR510A MWAVE- CNTRTP / STAND ALONE
Amana RR52 MWAVE - FAMILY SIZE (60 HZ)
Amana RR54 MWAVE - FAMILY SIZE (60 HZ)
Amana RR54D MWAVE- CNTRTP / STAND ALONE
Amana RR56 MWAVE- CNTRTP / STAND ALONE
Amana RR57D MWAVE- CNTRTP / STAND ALONE
Amana RR59T MWAVE- CNTRTP / STAND ALONE
Amana RR6W MWAVE- CNTRTP / STAND ALONE
Amana RR7 MWAVE- CNTRTP / STAND ALONE
Amana RR720 MWAVE- CNTRTP / STAND ALONE
Amana RR9 MWAVE- CNTRTP / STAND ALONE
Amana RR920 MWAVE- CNTRTP / STAND ALONE
Amana RRC57D MWAVE- CNTRTP / STAND ALONE
Amana RRH-10 MWAVE - FAMILY SIZE (60 HZ)
Amana RRL-10A MWAVE - FAMILY SIZE (60 HZ)
Amana RRL-10A MWAVE- CNTRTP / STAND ALONE
Amana RRL-10C MWAVE- CNTRTP / STAND ALONE
Amana RRL-10TD MWAVE - FAMILY SIZE (60 HZ)
Amana RRL-10TD MWAVE- CNTRTP / STAND ALONE
Amana RRL-10XA MWAVE - FAMILY SIZE (60 HZ)
Amana RRL-5C MWAVE - FAMILY SIZE (60 HZ)
Amana RRL-5D MWAVE - FAMILY SIZE (60 HZ)
Amana RRL-5D MWAVE- CNTRTP / STAND ALONE
Amana RRL-7C MWAVE - FAMILY SIZE (60 HZ)
Amana RRL-7C MWAVE- CNTRTP / STAND ALONE
Amana RRL-8T MWAVE- CNTRTP / STAND ALONE
Amana RRL-8TC MWAVE- CNTRTP / STAND ALONE
Amana RRL-8TD MWAVE - FAMILY SIZE (60 HZ)
Amana RRL-8TD MWAVE- CNTRTP / STAND ALONE
Amana RRL-8X MWAVE - FAMILY SIZE (60 HZ)
  #2 (permalink)
Old 03-03-2010, 03:07 PM
Junior Member
hvac_hillbilly is on a distinguished road
Default
try one of these sounds like your comprsser is locke or near locked this could be a tempory fix however probaly need to replace compressor 2 years old should be under warrenty but there may be a labor charge
Part Details - PRO HARD START KITS, part number: AP4502865
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Pilot Light on Rheem RGAA 100AA won't stay lit j.clayton Heating, Ventilation, and Air Conditioning (HVAC) 1 02-15-2010 06:24 PM
Old heat pump trowing breaker neverforget.911 Heating, Ventilation, and Air Conditioning (HVAC) 3 05-31-2009 07:12 PM
Rheem-Ruud Advantage Plus leak donnor General Talk 0 04-12-2009 06:41 PM
Whirlpool AC/Heat pump - no heat martydoug@gmail.com Heating, Ventilation, and Air Conditioning (HVAC) 2 11-05-2008 12:25 PM
