Discuss
HVAC heat elements stay on
 in
Heating, Ventilation, and Air Conditioning (HVAC)
Had a Heat Pump fan problem which was solved by replacing both fan and motor. System runs great (hot air)
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » HVAC heat elements stay on
  #1 (permalink)
Old 02-24-2010, 03:44 PM
Junior Member
mooney99 is on a distinguished road
Default HVAC heat elements stay on
Model Number: TWEO48C140B3   Brand: -other-   Age: More than 10 years
Had a Heat Pump fan problem which was solved by replacing both fan and motor. System runs great (hot air) but my 20 KW elements also run all the time when heat is on. My thermostat is four-wire without aux and emer. settings but I did have the correct changeover thermostats when the system was installed. The Trane "specialists" came out, changed the thermostats (2) and never came back. I also have zone damper control unit (2 zones, I think). They apparently wired the system to have the heat elements on all the time with heat.
My question is how can I use heat pump heat only except for very cold days and nights. What wires and where should I change. THANKS!
Ads By Google
Related Models
Frigidaire TWX233RBD0 Tap(v4) / 27 " Washer
Frigidaire TWX233RBD1 Tap(v1) / 27 " Washer
Frigidaire TWX233RBD2 Tap(v1) / Top Load Washer
Frigidaire TWX233RBD3 Tap(v1) / Washer
Frigidaire TWX233RBW0 Tap(v3) / 27 " Washer
Frigidaire TWX233RBW1 Tap(v2) / 27 " Washer
Frigidaire TWX233RBW2 Tap(v2) / Top Load Washer
Frigidaire TWX233RBW3 Tap(v2) / Washer
Frigidaire TWX233REW1 Frg(v0) / Washer
Frigidaire TWX645RBD0 Tap(v2) / 27 " Washer
Frigidaire TWX645RBD2 Tap(v3) / Top Load Washer
Frigidaire TWX645RBD4 Tap(v1) / Washer
Frigidaire TWX645RBW0 Tap(v1) / 27 " Washer
Frigidaire TWX645RBW1 Tap(v3) / 27 " Washer
Frigidaire TWX645RBW2 Tap(v4) / Top Load Washer
Frigidaire TWX645RBW3 Tap(v0) / Washer
Frigidaire TWX645RBW4 Tap(v2) / Washer
Amana TX18J Ref - Top Mount
Amana TX18K Ref - Top Mount
Amana TX18K2 Ref - Top Mount
Amana TX18M Ref - Top Mount
Amana TX18MB Ref - Top Mount
Amana TX18N Ref - Top Mount
Amana TX18NB Ref - Top Mount
Amana TX18Q2L Ref - Top Mount
Amana TX18Q2W Ref - Top Mount
Amana TX18QB2L Ref - Top Mount
Amana TX18QB2W Ref - Top Mount
Amana TX18QBG Ref - Top Mount
Amana TX18QBL Ref - Top Mount
Amana TX18QBW Ref - Top Mount
Amana TX18QG Ref - Top Mount
Amana TX18QL Ref - Top Mount
Amana TX18QW Ref - Top Mount
Amana TX18R2L Ref - Top Mount
Amana TX18R2W Ref - Top Mount
Amana TX18RL Ref - Top Mount
Amana TX18RW Ref - Top Mount
Amana TX18VC Ref - Top Mount
Amana TX18VE Ref - Top Mount
Amana TX18VL Ref - Top Mount
Amana TX18VW Ref - Top Mount
Amana TX19R2E Ref - Top Mount
Amana TX19R2L Ref - Top Mount
Amana TX19R2W Ref - Top Mount
Amana TX19R3E Ref - Top Mount
Amana TX19R3L Ref - Top Mount
Amana TX19R3W Ref - Top Mount
Amana TX19RE Ref - Top Mount
Amana TX19RL Ref - Top Mount
Amana TX19RW Ref - Top Mount
Amana TX19S3E Ref - Top Mount
Amana TX19S3L Ref - Top Mount
Amana TX19S3W Ref - Top Mount
Amana TX19V2E Ref - Top Mount
Amana TX19V2L Ref - Top Mount
Amana TX19V2W Ref - Top Mount
Amana TX20J Ref - Top Mount
Amana TX20K Ref - Top Mount
Amana TX20M Ref - Top Mount
Amana TX20MB Ref - Top Mount
Amana TX20N Ref - Top Mount
Amana TX20NB Ref - Top Mount
Amana TX20QBG Ref - Top Mount
Amana TX20QBL Ref - Top Mount
Amana TX20QBW Ref - Top Mount
Amana TX20QG Ref - Top Mount
Amana TX20QL Ref - Top Mount
Amana TX20QW Ref - Top Mount
Amana TX21A3E Ref - Top Mount
Amana TX21A3L Ref - Top Mount
Amana TX21A3W Ref - Top Mount
Amana TX21R2E Ref - Top Mount
  #2 (permalink)
Old 02-24-2010, 04:35 PM
Junior Member
Fastlanedan is on a distinguished road
Smile you need a diffeent thermostat
You need a thermostat that has two stage heating. you will also need new thermostat wire, mininum 6 wire, (I recommend installing 8 wire for future add one, Example: you might have two stage cooling, and 2 stage heating, plus zone control)
  #3 (permalink)
Old 02-24-2010, 04:50 PM
Member
John @ Fischers is on a distinguished road
Default
Do you have 2- Double pole 220V breakers at the air handler? Cut them off and the heat strips should not come on. Hopefully that didn't wire the blower into this power source.
Turn them off and then try the heat and see if the blower on the air handler still comes on, if so, then see if the strips are off and the outside unit is still running.
Post back.
  #4 (permalink)
Old 02-24-2010, 05:16 PM
Junior Member
Default
Post back.
Thanks, yes I can cut off the 2-Double Pole breakers at the Air Handler but they do have the blower motor wired to one of the sources. Great help on the thermostat but I think there are many more wires not used
at the room thermostats as I orginally had the correct thermostats-
  #5 (permalink)
Old 02-25-2010, 11:18 AM
Junior Member
Default
At the heat source I have the 2 double pole breakers that feed the two contactors-can I disconnect the three small white wires to the sides of the contactors (24V) and the system still work with Heat Pump? These wires seem to come from the PCB/ Fan Relay board-
  #6 (permalink)
Old 02-26-2010, 10:43 AM
Junior Member
hvac_hillbilly is on a distinguished road
Default
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
  #7 (permalink)
Old 02-26-2010, 10:50 AM
Junior Member
Default
Quote:
i would suggest an outdoor thermostat set for 35 degrees outdoor ambient to bring on heat strips with unit at that tempture this will improve the overall fuction of your system as the heatpump starts to become inefficent at this out door temp you will need no more wires between thermostat and indoor unit however you will need a total of a total of 5 wire from indoor unit to outdoor unit
  #8 (permalink)
Old 02-26-2010, 11:17 AM
Junior Member
Default
Thanks for your help- Is this thermostat in the Heat Pump control panel? Can this thermostat be manually set or do I buy one that is preset?
I have one thermostat ( hanging at the bottom with two wires) but can't find the other thermostat unless it is on the PCB Defrost Control Board-
  #9 (permalink)
Old 02-26-2010, 01:24 PM
Junior Member
Default
this would be an add on outdoor themostat that you would have to mount to the outdoor unit
i like rancho it has a set of normally opened and a set of normally closed contacts to wire (i know i pprobaly get a lot of disagreement on this but t does work) come off the yellow wire to the contactor through open contacts to white wire to heatsrips make sure you hook up the white wire to the defrost board so the strips come on in defrost going to look for diagram
  #10 (permalink)
Old 02-26-2010, 01:36 PM
Junior Member
Default
Quote:
before we rehook the heat strips we need them off can you tell me how the thermostat is wired
r=red to 24 volt side of contactor
y=yellow to contactor outside unit
o=orange to reversing vavle
g=green to fan relay
w should be jumped to y for this applacation
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
New EOC No heat at elements colbert Oven Repair (including Ranges and Cooktops) 7 11-03-2009 05:20 PM
elements heat but cannot control andyg Oven Repair (including Ranges and Cooktops) 1 06-23-2009 11:08 AM
Both grilling and bake elements do not heat up radmo Oven Repair (including Ranges and Cooktops) 2 11-25-2008 01:56 PM
Heating elements stay on until dryer is unplugged quagmire Dryer Repair 1 06-17-2008 01:25 PM
NO heat from elements sivade Oven Repair (including Ranges and Cooktops) 6 04-02-2008 09:18 AM
