Discuss
Blower Motor not working
 in
Heating, Ventilation, and Air Conditioning (HVAC)
Trane Heat motor not working-hums then cuts off. I took Fan motor to have checked and it runs. New dual
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » Blower Motor not working
  #1 (permalink)
Old 02-11-2010, 03:02 PM
Junior Member
mooney99 is on a distinguished road
Default Blower Motor not working
Model Number: TWRO48C100A2   Brand: -other-   Age: More than 10 years
Trane Heat motor not working-hums then cuts off. I took Fan motor to have checked and it runs. New dual capacitor, new start capcitor and new contactor relay. Voltage to each wire of motor is 115 volts. All wire connections appear to be ok. Any ideals or what can I check next. I think it is the motor but man said it was fine. The resistance from the two wires going into the motor is 23 ohms. Motor is 200-230/1/60 825 speed. Thanks for your help!!
Ads By Google
Related Models
Frigidaire TWX233RBD0 Tap(v4) / 27 " Washer
Frigidaire TWX233RBD1 Tap(v1) / 27 " Washer
Frigidaire TWX233RBD2 Tap(v1) / Top Load Washer
Frigidaire TWX233RBD3 Tap(v1) / Washer
Frigidaire TWX233RBW0 Tap(v3) / 27 " Washer
Frigidaire TWX233RBW1 Tap(v2) / 27 " Washer
Frigidaire TWX233RBW2 Tap(v2) / Top Load Washer
Frigidaire TWX233RBW3 Tap(v2) / Washer
Frigidaire TWX233REW1 Frg(v0) / Washer
Frigidaire TWX645RBD0 Tap(v2) / 27 " Washer
Frigidaire TWX645RBD2 Tap(v3) / Top Load Washer
Frigidaire TWX645RBD4 Tap(v1) / Washer
Frigidaire TWX645RBW0 Tap(v1) / 27 " Washer
Frigidaire TWX645RBW1 Tap(v3) / 27 " Washer
Frigidaire TWX645RBW2 Tap(v4) / Top Load Washer
Frigidaire TWX645RBW3 Tap(v0) / Washer
Frigidaire TWX645RBW4 Tap(v2) / Washer
Amana TX18J Ref - Top Mount
Amana TX18K Ref - Top Mount
Amana TX18K2 Ref - Top Mount
Amana TX18M Ref - Top Mount
Amana TX18MB Ref - Top Mount
Amana TX18N Ref - Top Mount
Amana TX18NB Ref - Top Mount
Amana TX18Q2L Ref - Top Mount
Amana TX18Q2W Ref - Top Mount
Amana TX18QB2L Ref - Top Mount
Amana TX18QB2W Ref - Top Mount
Amana TX18QBG Ref - Top Mount
Amana TX18QBL Ref - Top Mount
Amana TX18QBW Ref - Top Mount
Amana TX18QG Ref - Top Mount
Amana TX18QL Ref - Top Mount
Amana TX18QW Ref - Top Mount
Amana TX18R2L Ref - Top Mount
Amana TX18R2W Ref - Top Mount
Amana TX18RL Ref - Top Mount
Amana TX18RW Ref - Top Mount
Amana TX18VC Ref - Top Mount
Amana TX18VE Ref - Top Mount
Amana TX18VL Ref - Top Mount
Amana TX18VW Ref - Top Mount
Amana TX19R2E Ref - Top Mount
Amana TX19R2L Ref - Top Mount
Amana TX19R2W Ref - Top Mount
Amana TX19R3E Ref - Top Mount
Amana TX19R3L Ref - Top Mount
Amana TX19R3W Ref - Top Mount
Amana TX19RE Ref - Top Mount
Amana TX19RL Ref - Top Mount
Amana TX19RW Ref - Top Mount
Amana TX19S3E Ref - Top Mount
Amana TX19S3L Ref - Top Mount
Amana TX19S3W Ref - Top Mount
Amana TX19V2E Ref - Top Mount
Amana TX19V2L Ref - Top Mount
Amana TX19V2W Ref - Top Mount
Amana TX20J Ref - Top Mount
Amana TX20K Ref - Top Mount
Amana TX20M Ref - Top Mount
Amana TX20MB Ref - Top Mount
Amana TX20N Ref - Top Mount
Amana TX20NB Ref - Top Mount
Amana TX20QBG Ref - Top Mount
Amana TX20QBL Ref - Top Mount
Amana TX20QBW Ref - Top Mount
Amana TX20QG Ref - Top Mount
Amana TX20QL Ref - Top Mount
Amana TX20QW Ref - Top Mount
Amana TX21A3E Ref - Top Mount
Amana TX21A3L Ref - Top Mount
Amana TX21A3W Ref - Top Mount
Amana TX21R2E Ref - Top Mount
  #2 (permalink)
Old 02-11-2010, 04:37 PM
Member
John @ Fischers is on a distinguished road
Default
When you say Blower motor, i assume your referring to the indoor motor. How have you tried to make it come on. Running the heat and letting it come on that way, or forcing it to come on by the thermostat ?
  #3 (permalink)
Old 02-11-2010, 05:28 PM
Junior Member
Default
Quote:
Sorry, it is the Heat Pump-
  #4 (permalink)
Old 02-24-2010, 03:48 PM
Junior Member
Default
LATER, I went and ahead and replaced new start and dual caps, new contactor and cleaned and reinstalled all wires. Replaced fan and moter.
Works great, quiet as a mouse. Apparently, the small cracks in the fan blades ruined the bearings so the motor would not run. But with the moter being hand held, no fan, it would work. Crazy !!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Blower Motor RWKEND Oven Repair (including Ranges and Cooktops) 0 02-18-2010 08:52 AM
Blower Motor neboshone Heating, Ventilation, and Air Conditioning (HVAC) 1 10-03-2009 05:52 AM
Blower Motor shuts down during use rquack Oven Repair (including Ranges and Cooktops) 3 04-20-2009 07:00 PM
Blower motor is... blown Alcaeus Heating, Ventilation, and Air Conditioning (HVAC) 3 11-02-2008 05:57 AM
Blower motor won't work. rbeckner2 Heating, Ventilation, and Air Conditioning (HVAC) 1 02-20-2008 01:45 PM
