Discuss
Electric Furnace cycles on and off
 in
Heating, Ventilation, and Air Conditioning (HVAC)
I have an old electric furnace and the blower cycles on and off every 30 seconds or so until it
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » Electric Furnace cycles on and off
  #1 (permalink)
Old 02-01-2010, 07:52 PM
Junior Member
jredv is on a distinguished road
Default Electric Furnace cycles on and off
Brand: -other-   Age: More than 10 years
I have an old electric furnace and the blower cycles on and off every 30 seconds or so until it gets to temp. BUT, when I take the cover off the blower enclosure, it doesn't do this.
The blower spins smooth like brand new, but I cleaned and oiled it anyway and the problem didn't go away. I guess maybe the blower is overheating?
By the way, I don't have this problem in the summe with the A/C (same blower) Any ideas anyone? Thanks
Ads By Google
  #2 (permalink)
Old 02-11-2010, 04:50 PM
Member
John @ Fischers is on a distinguished road
Default
So its' only doing this on heat cycle? BTW, in Elect. furnace, the blower comes on first for about 20- 30 seconds before your heat strip comes on, unless you have a heat pump. Which heat strip would be second call for heat, but blower comes on first either way.
Have you tried to just turn fan on manual at thermostat and see if it runs without shutting off. if so, then you will have a bad time delay relay. According to how many KW heater strips you have, will depend on how the relays are wired and which one is operating the blower.
Also, could have a bad thermostat due to when W is energized on stat, it closes the time delay relay and the fan is first call of heating cycle. could be losing connection to W on stat. just food for thought. let me know about the testing.
  #3 (permalink)
Old 02-14-2010, 07:47 AM
Junior Member
furniture is on a distinguished road
Default Houston Furniture
Houston Furniture
  #4 (permalink)
Old 02-14-2010, 07:50 AM
Junior Member
Default Dallas modern furniture
  #5 (permalink)
Old 02-14-2010, 07:53 AM
Junior Member
Default Austin Divorce
Austin Divorce
  #6 (permalink)
Old 02-14-2010, 08:01 AM
Junior Member
Default Houston Criminal Attorney
  #7 (permalink)
Old 02-14-2010, 08:03 AM
Junior Member
Default Air Conditioning Houston
  #8 (permalink)
Old 02-14-2010, 08:04 AM
Junior Member
Default Lighting Fixtures Houston
  #9 (permalink)
Old 02-14-2010, 08:16 AM
Junior Member
Default Discount furniture houston
  #10 (permalink)
Old 02-14-2010, 08:17 AM
Junior Member
Default Dentist Houston
Dentist Houston
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Wont advance cycles... Have to manually turn knob to advance cycles at 2 points nickf829 Washer Repair 1 12-20-2009 04:43 PM
Amana Gas Furnace Ouiserm Heating, Ventilation, and Air Conditioning (HVAC) 2 11-29-2009 09:51 AM
furnace roel Heating, Ventilation, and Air Conditioning (HVAC) 1 10-05-2009 08:28 PM
Maytag electric dryer takes 2 or 3 cycles to dry msta116949 Dryer Repair 1 06-30-2009 09:39 PM
Electric Dryer cycles but no heat; cycle runs forever. chele163 Dryer Repair 1 03-30-2009 07:44 PM
