Discuss
Magic Chef Gas Furnace
 in
Heating, Ventilation, and Air Conditioning (HVAC)
Magic Chef furnace works OK during the day. Pilot goes out overnight. Relights with no problem in the morning. Fan
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » Magic Chef Gas Furnace
  #1 (permalink)
Old 01-09-2010, 11:23 AM
Junior Member
gmot455@yahoo.com is on a distinguished road
Default Magic Chef Gas Furnace
Model Number: G66-75D-5   Brand: Magic Chef   Age: More than 10 years
Magic Chef furnace works OK during the day. Pilot goes out overnight. Relights with no problem in the morning. Fan runs continuously all the time. I wired a switch for the fan down near the thermostat so I can shut it off when the room warms up. What controls the fan turn on and shut off? Is it the Honeywell control on the left side behind the Gas valve? The fan is monted below the gas logs. It seems to me there should be a filter in the bottom of the furnace below the fan. True? I need schematic and manual if available anywhere. thanks
Ads By Google
Related Models
Frigidaire G7W
Maytag GA104 Washer - Top Loading
Maytag GA107 Washer - Top Loading
Maytag GA107S Washer - Top Loading
Maytag GA108 Washer - Top Loading
Maytag GA110 Washer - Top Loading
Maytag GA1110PRW Range - F/s Std Gas
Maytag GA112 Washer - Top Loading
Maytag GA180 Washer - Top Loading
Maytag GA183 Washer - Top Loading
Maytag GA190 Washer - Top Loading
Maytag GA1910 Washer - Top Loading
Maytag GA200 Washer - Top Loading
Maytag GA200S Washer - Top Loading
Maytag GA202 Washer - Top Loading
Maytag GA202S Washer - Top Loading
Maytag GA203 Washer - Top Loading
Maytag GA203S Washer - Top Loading
Maytag GA206 Washer - Top Loading
Maytag GA206S Washer - Top Loading
Maytag GA208 Washer - Top Loading
Maytag GA209 Washer - Top Loading
Maytag GA210 Washer - Top Loading
Maytag GA211 Washer - Top Loading
Maytag GA211S Washer - Top Loading
Maytag GA212 Washer - Top Loading
Maytag GA212T Washer - Top Loading
Maytag GA23CS Washer - Top Loading
Maytag GA25CM Washer - Top Loading
Maytag GA25CME Washer - Top Loading
Maytag GA25CS Washer - Top Loading
Maytag GA25CT Washer - Top Loading
Maytag GA26CD Washer - Top Loading
Maytag GA26CDC Washer - Top Loading
Maytag GA282 Washer - Top Loading
Maytag GA283 Washer - Top Loading
Maytag GA284 Washer - Top Loading
Maytag GA305 Washer - Top Loading
Maytag GA308 Washer - Top Loading
Maytag GA308S Washer - Top Loading
Maytag GA310 Washer - Top Loading
Maytag GA3110PRAM Range - F/s Std Gas
Maytag GA3110PRWM Range - F/s Std Gas
Maytag GA312 Washer - Top Loading
International GA3170MPAW Range - F/s Std Gas
International GA31713WAM Range - F/s Std Gas
International GA31713WAV Range - F/s Std Gas
International GA31713WAW Range - F/s Std Gas
International GA3171SXAW Range - F/s Cont Clean Gas
Maytag GA3177WUV Range - F/s Std Gas
Maytag GA3177WUW5 Range - F/s Std Gas
Maytag GA3216WRAM Range - F/s Std Gas
Maytag GA3216WRWM Range - F/s Std Gas
International GA3271SXAA Range - F/s Cont Clean Gas
International GA3271SXAW Range - F/s Cont Clean Gas
International GA3277WUAM Range - F/s Std Gas
International GA3277WUWM Range - F/s Std Gas
International GA3277XUA Range - F/s Std Gas
International GA3277XUAM Range - F/s Std Gas
International GA3277XUW Range - F/s Std Gas
International GA3277XUWM Range - F/s Std Gas
International GA3478XUAX Range - S/c F/s Gas
International GA3478XUWX Range - S/c F/s Gas
International GA3488VVV Range - S/c F/s Gas
International GA3510PRW Range - F/s Std Ele
International GA3531WUA Range - F/s Std Ele
International GA3531WUV Range - F/s Std Ele
International GA3531WUW Range - F/s Std Ele
Maytag GA3631XUA Range - F/s Std Ele
Maytag GA3631XUW Range - F/s Std Ele
International GA3631XUWG Range - F/s Std Ele
Maytag GA382 Washer - Top Loading
Maytag GA382T Washer - Top Loading
Maytag GA3872XUW Range - S/c F/s Ele
International GA3878XUW Range - S/c F/s Ele
Maytag GA390 Washer - Top Loading
Maytag GA3910 Washer - Top Loading
Maytag GA408 Washer - Top Loading
Maytag GA408S Washer - Top Loading
Maytag GA410 Washer - Top Loading
Maytag GA412 Washer - Top Loading
Maytag GA412T Washer - Top Loading
International GA4251WTA Range - F/s Cont Clean Gas
International GA4251WTW Range - F/s Cont Clean Gas
Maytag GA482 Washer - Top Loading
Maytag GA484 Washer - Top Loading
Maytag GA490 Washer - Top Loading
Maytag GA4910 Washer - Top Loading
Maytag GA5000 Washer - Top Loading
Maytag GA503 Washer - Top Loading
Maytag GA506 Washer - Top Loading
Maytag GA510 Washer - Top Loading
Maytag GA512 Washer - Top Loading
Maytag GA590 Washer - Top Loading
Maytag GA5910 Washer - Top Loading
Maytag GA608 Washer - Top Loading
Maytag GA608S Washer - Top Loading
Maytag GA610 Washer - Top Loading
Maytag GA612 Washer - Top Loading
Maytag GA612T Washer - Top Loading
Maytag GA613 Washer - Top Loading
Maytag GA6910 Washer - Top Loading
Maytag GA710 Washer - Top Loading
Maytag GA712 Washer - Top Loading
Maytag GA7300 Washer - Top Loading
Maytag GA7400 Washer - Top Loading
Maytag GA7500 Washer - Top Loading
Maytag GA7800 Washer - Top Loading
Maytag GA806 Washer - Top Loading
Maytag GA806S Washer - Top Loading
Maytag GA810 Washer - Top Loading
Maytag GA8100 Washer - Top Loading
Maytag GA8120 Washer - Top Loading
Maytag GA8140 Washer - Top Loading
Maytag GA8200 Washer - Top Loading
Maytag GA8210 Washer - Top Loading
Maytag GA8240 Washer - Top Loading
Maytag GA8340 Washer - Top Loading
Maytag GA8420 Washer - Top Loading
Maytag GA8440 Washer - Top Loading
  #2 (permalink)
Old 01-19-2010, 07:55 AM
Senior Expert
APP Volunteer
SublimeMasterJW is on a distinguished road
Default
You said something about gas logs so i am assuming you are concerned about a blower /circulatory motor. The fan in this case must be powered up by a Fan Klixon. A fan klixon looks just like a limit switch (usually mounts right beside the limit over the plenum) but works the opposite, when it heats up to around 90f or 100f it kicks on the fan. The contacts in yours are probably fried together. Find the klixon with an F stamped into it. If it has continuity while at room temp it is bad. You can test these fan klixons by heating gently the base of them with a torch. It takes about 30 seconds for the bi-metal inside to pop. heating it makes it have continuity. Next wait to see if it cools down and clicks. Most of the time after a minute it kicks back off. If yours don't then that would explain why the fan runs constantly.
  #3 (permalink)
Old 08-02-2012, 06:03 PM
Junior Member
bigdaddy88 is on a distinguished road
Default wiring diagram for magic chef ac and furnace
u seem to no what ur talkin about man hopin u could help me with mine
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
magic chef elizabeth reiling Refrigerator & Freezer Repair 1 01-04-2010 02:46 PM
Magic chef gsonny50 Refrigerator & Freezer Repair 0 12-28-2009 01:36 PM
Magic Chef maverick0923 Oven Repair (including Ranges and Cooktops) 1 11-27-2009 12:35 PM
Magic Chef jeany Refrigerator & Freezer Repair 1 10-16-2009 05:31 PM
