Discuss
Hood Light
 in
Heating, Ventilation, and Air Conditioning (HVAC)
I've got a Jenn-Air manufactured range hood that's now ~10 years old (Model: H304-R). The bulb burned out when my
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » Hood Light
  #1 (permalink)
Old 12-14-2009, 08:47 AM
Junior Member
Liklok is on a distinguished road
Default Hood Light
Model Number: H304R-A   Brand: Jenn-Air   Age: More than 10 years
I've got a Jenn-Air manufactured range hood that's now ~10 years old (Model: H304-R). The bulb burned out when my wife last turned on the switch. I replaced the bulb (no luck). So, obviously something needs replacing. What to do? Should I replace the receptacle that holds the bulb (Part AP4051210) or should I replace the switch (Part AP4041429)? Beyond that, I'm at a loss. Thanks.
Related Models
Maytag H304RA HOOD
Maytag H304RB HOOD
Maytag H304RQ HOOD
Maytag H304RS HOOD
Maytag H304RW HOOD
Hoover H3050 UPRT-HD,LC,MID,GNS,NS,GMN,PR AS,COM,ID
Hoover H3050010 UPRT-HD,LC,MID,GNS,NS,GMN,PR AS,COM,ID
Hoover H3060--- HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Hoover H3060020 HAND-HM,WET/DRY,W/AGT,TWIST,HD FLR BRZ
Thermador H30HQS RANGE HOODS
Thermador H30HQW RANGE HOOD
Hardwick H31000PAAD RANGE- F/S STD GAS
Hardwick H31000PAWD RANGE- F/S STD GAS
Hardwick H3100PPA RANGE- F/S STD GAS
Hardwick H3100PPW RANGE- F/S STD GAS
Hardwick H31103SAA RANGE- F/S STD GAS
Hardwick H31103SAW RANGE- F/S STD GAS
Hardwick H3110PPA RANGE- F/S STD GAS
Hardwick H3110PPW RANGE- F/S STD GAS
Hardwick H3110PRA RANGE- F/S STD GAS
Hardwick H3110PRW RANGE- F/S STD GAS
Hardwick H3120SPA RANGE- F/S STD GAS
Hardwick H3120SPW RANGE- F/S STD GAS
Hardwick H3120SRA RANGE- F/S STD GAS
Hardwick H3120SRW RANGE- F/S STD GAS
Hardwick H3131WRA RANGE- F/S STD GAS
Hardwick H3131WRW RANGE- F/S STD GAS
Hardwick H3131WTA RANGE- F/S STD GAS
Hardwick H3131WTW RANGE- F/S STD GAS
Hardwick H3131WUA RANGE- F/S STD GAS
Hardwick H3131WUW RANGE- F/S STD GAS
Hardwick H3131XRA RANGE- F/S STD GAS
Hardwick H3131XRW RANGE- F/S STD GAS
Hardwick H3131XTA RANGE- F/S STD GAS
Hardwick H3131XTW RANGE- F/S STD GAS
Hardwick H3131XUA RANGE- F/S STD GAS
Hardwick H3131XUW RANGE- F/S STD GAS
Hardwick H3137WRA-L RANGE- F/S STD GAS
Hardwick H3137WRV-L RANGE- F/S STD GAS
Hardwick H3137WUA-L RANGE- F/S STD GAS
Hardwick H3137WUV-L RANGE- F/S STD GAS
Hardwick H3177XRA RANGE- F/S STD GAS
Hardwick H3177XRW RANGE- F/S STD GAS
Hardwick H3177XUA RANGE- F/S STD GAS
Hardwick H3177XUW RANGE- F/S STD GAS
Hardwick H3221WRV RANGE-F/S CONT CLEAN GAS
Hardwick H3221WTV RANGE-F/S CONT CLEAN GAS
Hardwick H32315WAM RANGE-F/S CONT CLEAN GAS
Hardwick H32315WAV RANGE-F/S CONT CLEAN GAS
Hardwick H3231XRA RANGE-F/S CONT CLEAN GAS
Hardwick H3231XRW RANGE-F/S CONT CLEAN GAS
Hardwick H3231XTA RANGE-F/S CONT CLEAN GAS
Hardwick H3231XTW RANGE-F/S CONT CLEAN GAS
Hardwick H3231XUA RANGE-F/S CONT CLEAN GAS
Hardwick H3231XUW RANGE-F/S CONT CLEAN GAS
Jenn-Air H325 Hood
Jenn-Air H325A MISC / ACCESSORY
Jenn-Air H325B MISC / ACCESSORY
Jenn-Air H326 HOOD
Jenn-Air H326A MISC / ACCESSORY
Jenn-Air H326B MISC / ACCESSORY
Hardwick H3277VRA RANGE-F/S CONT CLEAN GAS
Hardwick H3277VRV RANGE-F/S CONT CLEAN GAS
Hardwick H3277VUA RANGE-F/S CONT CLEAN GAS
Hardwick H3277VUV RANGE-F/S CONT CLEAN GAS
Hardwick H3277VUW RANGE-F/S CONT CLEAN GAS
Hardwick H3277XRA RANGE-F/S CONT CLEAN GAS
Hardwick H3277XRW RANGE-F/S CONT CLEAN GAS
Hardwick H3277XUA RANGE-F/S CONT CLEAN GAS
Hardwick H3277XUW RANGE-F/S CONT CLEAN GAS
Hardwick H3432SRA RANGE- S/C F/S GAS
Hardwick H3432SRW RANGE- S/C F/S GAS
Hardwick H3478VRA RANGE- S/C F/S GAS
Hardwick H3478VRV RANGE- S/C F/S GAS
Hardwick H3478VVA RANGE- S/C F/S GAS
Hardwick H3478VVV RANGE- S/C F/S GAS
Hardwick H3478XRA RANGE- S/C F/S GAS
Hardwick H3478XRW RANGE- S/C F/S GAS
Hardwick H3478XVA RANGE- S/C F/S GAS
Hardwick H3478XVB RANGE- S/C F/S GAS
Hardwick H3478XVW RANGE- S/C F/S GAS
Hardwick H3500PPA RANGE- F/S STD ELE
Hardwick H3500PPW RANGE- F/S STD ELE
Hardwick H3510PPA RANGE- F/S STD ELE
Hardwick H3510PPW RANGE- F/S STD ELE
Hardwick H3510PRA RANGE- F/S STD ELE
Hardwick H3510PRW RANGE- F/S STD ELE
Hardwick H3520SPA RANGE- F/S STD ELE
Hardwick H3520SPN RANGE- F/S STD ELE
Hardwick H3520SPW RANGE- F/S STD ELE
Hardwick H3520SRA RANGE- F/S STD ELE
Hardwick H3520SRW RANGE- F/S STD ELE
Hardwick H3531WRA RANGE- F/S STD ELE
Hardwick H3531WRW RANGE- F/S STD ELE
Hardwick H3531WUA RANGE- F/S STD ELE
Hardwick H3531WUW RANGE- F/S STD ELE
Hardwick H3531XRA RANGE- F/S STD ELE
Hardwick H3531XRW RANGE- F/S STD ELE
Hardwick H3531XUA RANGE- F/S STD ELE
Hardwick H3531XUW RANGE- F/S STD ELE
Maytag H362RA HOOD
Maytag H362RB HOOD
Maytag H362RQ HOOD
Maytag H362RS HOOD
Maytag H362RW HOOD
Maytag H363RA HOOD
Maytag H363RB HOOD
Maytag H363RQ HOOD
Maytag H363RS HOOD
Maytag H363RW HOOD
Maytag H364RA HOOD
Maytag H364RB HOOD
Maytag H364RQ HOOD
Maytag H364RS HOOD
Maytag H364RW HOOD
Hardwick H3657XRA RANGE- F/S CONT CLEAN ELE
Hardwick H3657XRW RANGE- F/S CONT CLEAN ELE
Hardwick H3657XUA RANGE- F/S CONT CLEAN ELE
Hardwick H3657XUW RANGE- F/S CONT CLEAN ELE
Hardwick H3674XRA RANGE- F/S CONT CLEAN ELE
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
R&R light sw. on a range hood quincyguy Oven Repair (including Ranges and Cooktops) 2 04-10-2010 06:11 PM
Thermador Hood Light is Blinking Kitchendude Oven Repair (including Ranges and Cooktops) 0 06-01-2009 09:04 PM
No light/fan on MWave Hood serena Microwave Repair 6 11-26-2008 03:13 PM
light fixture for range hood cehender Oven Repair (including Ranges and Cooktops) 0 07-28-2008 08:05 PM
Range Hood Light Cover - Where to Buy? Tanu Oven Repair (including Ranges and Cooktops) 0 05-17-2008 01:34 PM
