Discuss
Wall Furnace Ignites but Immediately Shuts Down
 in
Heating, Ventilation, and Air Conditioning (HVAC)
Hi, new to the forums - and only came here because I am unable to afford a full-on repair or
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » Wall Furnace Ignites but Immediately Shuts Down
  #1 (permalink)
Old 12-11-2009, 07:48 PM
Junior Member
snaperific is on a distinguished road
Talking Wall Furnace Ignites but Immediately Shuts Down
Model Number: 867   Brand: Sears   Age: More than 10 years
Hi, new to the forums - and only came here because I am unable to afford a full-on repair or new furnace. I'm not mechanically inclined but can learn when I have to.
My Sears/Kenmore Counterflow Wall Furnace which is way more than 10 yrs old - is gas heat with an electonic ignitor.
The thermostat on the wall clicks and tells the furnace to open the gas valve. The gas valve opens and intermittantly it will ignite the gas. Within seconds of lift-off, there is a loud banging/clicking noise that repeats for about 10-15 seconds and then the gas valve shuts off the gas.
The electronic ignitor is a Honeywell 5825d, I only know this because that is what it says on the face of the little black box thingy (yes, thingy!) that ignites the gas. I have cleaned all the contacts/sensors and vaccuumed out the inside of the unit to ensure that no dust is interfering in the ignition process. All the wiring is connected, not loose. The durn thing fires up only sometimes. Right now, it's completely off.
I have restarted it repeatedly over the past week, both with the directions inside the unit about lighting the pilot light. (It's electronic, so lighting it manually is not an option. I do know this much, being a girl who can read directions and occasionally follow them as the manufacturer intended) I've managed to get it to light only about 10% of the time that I restart it. I've turned off the thermostat, shut off the pilot light switch, waited more than five minutes - sometimes more than an hour - to turn it all back on and try to fire it up. Again, sometimes it does, mostly it just doesn't. I've moved the temperature on the thermostat, I've even adjusted the thermostat differential thingy. Again, the thermostat fires and clicks and tells the unit to open the gas valve. It can't be the thermostat.
I think it's the Honeywell electronic ignition and sensor that doesn't work properly and the sensor is telling the gas valve to shut off. I have researched online and the part is clearly obsolete.
Is there a way to get a replacement part for the Honeywell 5825d?
If not, is there an optional part from another manufacturer that works universally that I can buy and have installed?
Am I possibly wrong on what the issue is?
Any thoughts on what it could be if I am?
Do not use the words "user error" or "thingy" in your response, please. Be nice. Thank you.
Ads By Google
Related Models
Kenmore 867.148  HOMART OIL FURNACE
Kenmore 867.27651  HOMART OIL-FIRED WALL FURNACE
Kenmore 867.501  HOMART OIL-FIRED BOILER
Kenmore 867.587110  SEARS ELECTRIC FURNACE
Kenmore 867.587120  SEARS ELECTRIC FURNACE
Kenmore 867.587130  SEARS ELECTRIC FURNACE
Kenmore 867.587140  SEARS ELECTRIC FURNACE
Kenmore 867.587141  SEARS ELECTRIC FURNACE
Kenmore 867.587150  SEARS ELECTRIC FURNACE
Kenmore 867.587151  SEARS ELECTRIC FURNACE
Kenmore 867.587160  SEARS ELECTRIC FURNACE
Kenmore 867.587161  SEARS ELECTRIC FURNACE
Kenmore 867.587210  SEARS ELECTRIC FURNACE
Kenmore 867.587211  ELECTRIC FURNACE
Kenmore 867.587220  SEARS ELECTRIC FURNACE
Kenmore 867.587221  ELECTRIC FURNACE
Kenmore 867.587230  SEARS ELECTRIC FURNACE
Kenmore 867.587231  ELECTRIC FURNACE
Kenmore 867.587240  SEARS ELECTRIC FURNACE
Kenmore 867.587241  ELECTRIC FURNACE
Kenmore 867.587250  SEARS ELECTRIC FURNACE
Kenmore 867.587260  SEARS ELECTRIC FURNACE
Kenmore 867.587261  ELECTRIC FURNACE
Kenmore 867.587270  SEARS ELECTRIC FURNACE
Kenmore 867.587280  SEARS ELECTRIC FURNACE
Kenmore 867.587290  SEARS ELECTRIC FURNACE
Kenmore 867.587310  ELECTRIC FURNACES
Kenmore 867.587320  ELECTRIC FURNACES
Kenmore 867.587330  ELECTRIC FURNACES
Kenmore 867.587340  ELECTRIC FURNACES
Kenmore 867.587350  ELECTRIC FURNACES
Kenmore 867.587360  ELECTRIC FURNACES
Kenmore 867.587370  ELECTRIC FURNACES
Kenmore 867.587380  ELECTRIC FURNACES
Kenmore 867.587390  ELECTRIC FURNACES
Kenmore 867.587510  SEARS ELECTRIC FURNACE
Kenmore 867.587520  SEARS ELECTRIC FURNACE
Kenmore 867.587530  SEARS ELECTRIC FURNACE
Kenmore 867.587540  SEARS ELECTRIC FURNACE
Kenmore 867.587550  SEARS ELECTRIC FURNACE
Kenmore 867.587710  ELECTRIC FURNACE
Kenmore 867.587711  SEARS ELECTRIC FURNACE
Kenmore 867.587712  SEARS ELECTRIC FURNACES
Kenmore 867.587720  ELECTRIC FURNACE
Kenmore 867.587721  SEARS ELECTRIC FURNACE
Kenmore 867.587722  SEARS ELECTRIC FURNACES
Kenmore 867.587730  SEARS ELECTRIC FURNACE
Kenmore 867.587731  SEARS ELECTRIC FURNACE
Kenmore 867.587732  SEARS ELECTRIC FURNACE
Kenmore 867.587740  SEARS ELECTRIC FURNACE
Kenmore 867.6125  HOMART GAS-FIRED BOILERS
Kenmore 867.6126  HOMART GAS-FIRED BOILERS
Kenmore 867.6127  HOMART GAS-FIRED BOILERS
Kenmore 867.6128  HOMART GAS-FIRED BOILERS
Kenmore 867.6129  HOMART GAS-FIRED BOILERS
Kenmore 867.6130  HOMART GAS-FIRED BOILERS
Kenmore 867.6131  HOMART GAS-FIRED BOILERS
Kenmore 867.6132  HOMART GAS-FIRED BOILERS
Kenmore 867.6133  HOMART GAS-FIRED BOILERS
Kenmore 867.6134  HOMART GAS-FIRED BOILERS
Kenmore 867.6135  HOMART GAS-FIRED BOILERS
Kenmore 867.6136  HOMART GAS-FIRED BOILERS
Kenmore 867.6137  HOMART GAS-FIRED BOILERS
Kenmore 867.6138  HOMART GAS-FIRED BOILERS
Kenmore 867.6139  HOMART GAS-FIRED BOILERS
Kenmore 867.6140  HOMART GAS-FIRED BOILERS
Kenmore 867.6141  HOMART GAS-FIRED BOILERS
Kenmore 867.6142  HOMART GAS-FIRED BOILERS
Kenmore 867.6143  HOMART GAS-FIRED BOILERS
Kenmore 867.6144  HOMART GAS-FIRED BOILERS
Kenmore 867.6145  HOMART GAS-FIRED BOILERS
Kenmore 867.6146  HOMART GAS-FIRED BOILERS
Kenmore 867.6147  HOMART GAS-FIRED BOILERS
Kenmore 867.6148  HOMART GAS-FIRED BOILERS
Kenmore 867.6149  HOMART GAS-FIRED BOILERS
Kenmore 867.6150  HOMART GAS-FIRED BOILERS
Kenmore 867.6151  HOMART GAS-FIRED BOILERS
Kenmore 867.6152  HOMART GAS-FIRED BOILERS
Kenmore 867.6153  HOMART GAS-FIRED BOILERS
Kenmore 867.6154  HOMART GAS-FIRED BOILERS
Kenmore 867.651  SEARS OIL BURNER
Kenmore 867.6510  SEARS CONDENSING UNITS
Kenmore 867.6511  SEARS CONDENSING UNITS
Kenmore 867.6512  SEARS CONDENSING UNITS
Kenmore 867.6513  SEARS CONDENSING UNITS
Kenmore 867.6514  SEARS CONDENSING UNITS
Kenmore 867.6515  SEARS CONDENSING UNITS
Kenmore 867.6516  SEARS EVAPORATOR
Kenmore 867.6517  SEARS EVAPORATOR
Kenmore 867.6518  SEARS EVAPORATOR
Kenmore 867.6519  SEARS EVAPORATOR
Kenmore 867.652  SEARS OIL BURNER
Kenmore 867.6520  SEARS CONDENSING UNITS
Kenmore 867.6521  SEARS EVAPORATOR
Kenmore 867.721300  DIRECT VENT WALL FURNACE
Kenmore 867.721310  DIRECT VENT WALL FURNACE
Kenmore 867.721400  DIRECT VENT WALL FURNACE
Kenmore 867.721410  DIRECT VENT WALL FURNACE
Kenmore 867.721480  DIRECT VENT WALL FURNACE
Kenmore 867.721490  DIRECT VENT WALL FURNACE
Kenmore 867.721580  DIRECT VENT WALL FURNACE
Kenmore 867.721590  DIRECT VENT WALL FURNACE
Kenmore 867.725300  DIRECT VENT WALL FURNACE
Kenmore 867.725500  DIRECT VENT WALL FURNACE
Kenmore 867.730300  SEARS UP VENT WALL FURNACE
Kenmore 867.730310  SEARS UP VENT WALL FURNACE
Kenmore 867.730450  SEARS UP VENT WALL FURNACE
Kenmore 867.730460  SEARS UP VENT WALL FURNACE
Kenmore 867.730600  SEARS UP VENT WALL FURNACE
Kenmore 867.730610  SEARS UP VENT WALL FURNACE
Kenmore 867.734300  UP VENT WALL FURNACE
Kenmore 867.734301  UP VENT WALL FURNACE
Kenmore 867.734500  UP VENT WALL FURNACE
Kenmore 867.734501  UP VENT WALL FURNACE
Kenmore 867.734980  SEARS DIRECT VENT WALL FURNACE
Kenmore 867.734981  SEARS DIRECT VENT WALL FURNACE
Kenmore 867.736272  SEARS DIRECT VENT WALL FURNACE
Kenmore 867.736273  SEARS DIRECT VENT WALL FURNACE
Kenmore 867.736730  FURNACE RECALL
Kenmore 867.736731  FURNACE RECALL
  #2 (permalink)
Old 12-28-2009, 07:01 PM
Junior Member
hvac_hillbilly is on a distinguished road
Default think i can help
there is one thing to try that is easy and the best part its free
find your flame sensor its a steel rod that sits in the flame with a single wire coming off it carefuly remave and use a fine sand paper to clean then reinstall see if that dont take care of your problem
  #3 (permalink)
Old 12-29-2009, 02:14 PM
Junior Member
Default
you would have been my hero 3 weeks ago when it was 20 degrees out and i had no heat. because i do know for a fact now, that that would have worked and saved me the cost of a new heater. also, i ended up finding the replacement part for the honeywell black box thingy that is obsolete - after the issue is resolved, of course, and a new heater was purchased. maybe everyone's delayed response to my issue will help someone else in the future though who doesn't have the means to buy a new one.
an hvac guy from the neighborhood explained all this to me after the fact and showed me how to take the flame sensor out and clean it so that it "shines like a quarter".
as a non-mechanical person, i'm kind of proud of myself - even if it was an inconvenient lesson to learn, being without heat and all - but i learned how to find replacement parts for obsolete components and also what the different components inside my stupid heater and what their function is.
i just pray to god that i never have to know this stuff in the future. thanks for the suggestion though. i do know that's all it would have taken because the heater we removed works now, after doing just exactly what you suggested. thank you for the response.
  #4 (permalink)
Old 12-29-2009, 04:29 PM
Junior Member
Default
sorry un the delayed response but i just found sight last night looking for help my self so i thought since i am a hvac repair man i might try and help were i could
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Oven ignites then shuts off sleepy1 Oven Repair (including Ranges and Cooktops) 1 02-04-2010 11:28 AM
Fixed It! Kenmore Oven ignites then shuts off sleepy1 Oven Repair (including Ranges and Cooktops) 0 02-04-2010 11:19 AM
Dacor wall oven shuts off GeoSight Oven Repair (including Ranges and Cooktops) 0 09-11-2009 07:24 AM
Gas Dryer - Ignites then shuts off craig8585 Dryer Repair 0 06-20-2009 07:10 AM
Gas burner ignites, burns, shuts off, repeat llew Dryer Repair 5 06-18-2009 03:11 PM
