Discuss
Westinghouse dehumidifier
 in
Heating, Ventilation, and Air Conditioning (HVAC)
My fairly new dehumidifier has failed in its second year. Worked fine last year. The evaporator ices up and will
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » Westinghouse dehumidifier
  #1 (permalink)
Old 08-18-2007, 11:03 AM
Bart Bart is offline
Junior Member
Bart is on a distinguished road
Default Westinghouse dehumidifier
Brand: White-Westinghouse   Age: Less than 1 year
My fairly new dehumidifier has failed in its second year. Worked fine last year. The evaporator ices up and will not remove further moisture. The fan setting is on high, moisture level high. The ambient humidity is in the 35-40% range. Obviously the freon is low with an extreme pressure drop across the expansion valve causing a too cold evaporator. The cooling fins are clean. Question is: Is it cost effective to repair this appliance?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-19-2007, 07:45 PM
Matt / APP Team Matt / APP Team is offline
Administrator
APP Team
Matt / APP Team is on a distinguished road
Default
If you have determined it is low freon, then calling a certified freon tech out for a estimate will be the way to determine if it is worth it to you to fix.
__________________
Those who don't learn from history are doomed to relive it!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
