Discuss
Wall furnance
 in
Heating, Ventilation, and Air Conditioning (HVAC)
I need to know the volt meter usage so I can replace Thermostat. If you have the thermostat, please let
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » Wall furnance
  #1 (permalink)
Old 11-23-2009, 08:53 AM
Junior Member
wolfstallion is on a distinguished road
Default Wall furnance
Model Number: 629.756660   Brand: Sears   Age: More than 10 years
I need to know the volt meter usage so I can replace Thermostat. If you have the thermostat, please let me know too.
Thank you,
Roger Dye
Ads By Google
Related Models
Jenn-Air 629.80515 MISC / ACCESSORY
Jenn-Air 629.80519 MISC / ACCESSORY
Kenmore 62912103 COOKTOPS
Kenmore 62912104 COOKTOPS
Kenmore 62920245 ELECTRIC/GAS SLIDE-IN RANGE
Kenmore 62921136 Built-In Oven, Electric
Kenmore 62921137 Built-In Oven, Electric
Kenmore 62921238 WALL OVEN
Kenmore 62921239 WALL OVEN
Kenmore 62921336 WALL OVEN
Kenmore 62922001 COOKTOP
Kenmore 62922112 COOKTOPS
Kenmore 62922113 COOKTOPS
Kenmore 62922114 UPDRAFT ELECTRIC COOKTOP
Kenmore 62922115 UPDRAFT ELECTRIC COOKTOP
Kenmore 62922116 ELECTRIC COOKTOP
Kenmore 62922401 COOKTOP
Kenmore 62942015 COIL MODULE
Kenmore 62942019 COIL MODULE
Kenmore 62942025 GLASS CARTRIDGE
Kenmore 62942029 GLASS CARTRIDGE
Kenmore 62942032 GRIDDLE MODULE
Kenmore 62942035 GRILL COVER
Kenmore 62942039 GRILL COVER
Kenmore 62942765 ELECTRIC COOKTOP
Kenmore 62942769 ELECTRIC COOKTOP
Kenmore 62942865 ELECTRIC COOKTOP
Kenmore 62942869 ELECTRIC COOKTOP
Kenmore 62942975 COUNTER UNIT
Kenmore 62942975790 COUNTER UNIT
Kenmore 62942979 COUNTER UNIT
Kenmore 62942979790 COUNTER UNIT
Kenmore 6294576 ELECTRIC SLIDE-IN RANGE
Kenmore 62945765 ELECTRIC RANGE
Kenmore 62945765690 ELECTRIC RANGE
Kenmore 62945765790 ELECTRIC RANGE
Kenmore 62945766790 ELECTRIC RANGE
Kenmore 62945769790 ELECTRIC RANGE
Kenmore 62945775 KENMORE COOKING
Kenmore 62945776 KENMORE COOKING
Kenmore 62945779 KENMORE COOKING
Kenmore 62946775690 ELECTRIC RANGE
Kenmore 62946775790 ELECTRIC RANGE
Kenmore 62946776790 ELECTRIC RANGE
Kenmore 62946779790 ELECTRIC RANGE
Kenmore 62946795 ELECTRIC RANGE
Kenmore 62946796 ELECTRIC RANGE
Kenmore 62946799 ELECTRIC RANGE
Kenmore 62946965 ELECTRIC RANGE
Kenmore 62946969 ELECTRIC RANGE
Kenmore 6294697 ELECTRIC RANGE
Kenmore 62946975 WIRING DIAGRAM-RANGE
Kenmore 62946979 WIRING DIAGRAM-RANGE
Kenmore 62960002600 KENMORE COOKING
Kenmore 62960002601 KENMORE COOKING
Kenmore 62960002606 ELECTRIC RANGE
Kenmore 62960003600 KENMORE COOKING
Kenmore 62960008600 KENMORE COOKING
Kenmore 62960008601 KENMORE COOKING
Kenmore 62960008606 ELECTRIC RANGE
Kenmore 62960009600 KENMORE COOKING
Kenmore 62960009601 KENMORE COOKING
Kenmore 62960009606 ELECTRIC RANGE
Kenmore 62970131 GAS RANGE
Kenmore 62970138 GAS RANGE
Kenmore 62990131 ELECTRIC RANGE
Kenmore 62990138 ELECTRIC RANGE
Kenmore 629CG200 GAS COOKTOP
Magic Chef 62S14XAA RANGE- S/I CONT CLEAN GAS
Magic Chef 62S14XAS RANGE- S/I CONT CLEAN GAS
Magic Chef 62S14XAW RANGE- S/I CONT CLEAN GAS
Hoover 63
Amana 630.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 630.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 630.002 RANGE- S/C S/I DDRAFT GAS
Amana 630.003 RANGE- S/C S/I DDRAFT GAS
Frigidaire 6307B WASHER
Frigidaire 6308A WASHER
Frigidaire 6309A WASHER
Amana 631.000 RANGE- S/C S/I DDRAFT GAS
Amana 631.001 RANGE- S/C S/I DDRAFT GAS
Amana 631.002 RANGE- S/C S/I DDRAFT GAS
Amana 631.003 RANGE- S/C S/I DDRAFT GAS
Amana 631.004 RANGE- S/C S/I DDRAFT GAS
Amana 631.006 RANGE- S/C S/I DDRAFT GAS
Amana 632-3J ROOM AIR CONDITIONER
Frigidaire 6337B WASHER
Frigidaire 6338A WASHER
Frigidaire 6339A WASHER
Hoover 634
Frigidaire 6347B WASHER
Frigidaire 6348A WASHER
Frigidaire 6358A WASHER
Frigidaire 6389-80A WASHER
Frigidaire 6389-80B WASHER
Frigidaire 6389-87A WASHER
Frigidaire 6389-87B WASHER
Hoover 64
Maytag 640C DRYER- GAS
Maytag 640W DRYER- GAS
Magic Chef 6458XRA RANGE- S/C S/I GAS
Magic Chef 6458XRS RANGE- S/C S/I GAS
Magic Chef 6458XRW RANGE- S/C S/I GAS
Magic Chef 6458XTA RANGE- S/C S/I GAS
Magic Chef 6458XTS RANGE- S/C S/I GAS
Magic Chef 6458XTW RANGE- S/C S/I GAS
Kenmore 6476037210 KENMORE 30 IN GAS RANGE
Kenmore 6476037220 KENMORE 30 IN GAS RANGE
Kenmore 6476037240 KENMORE 30 IN GAS RANGE
Kenmore 6476037260 KENMORE 30 IN GAS RANGE
Kenmore 6476037310 KENMORE 30 IN GAS RANGE
Kenmore 6476037311 KENMORE 30 INCH GAS RANGE
Kenmore 6476037312 KENMORE 30 IN GAS RANGE
Kenmore 6476037313 KENMORE 30 INCH GAS RANGE
Kenmore 6476037320 KENMORE 30 IN GAS RANGE
Kenmore 6476037321 KENMORE 30 INCH GAS RANGE
Kenmore 6476037322 KENMORE 30 IN GAS RANGE
Kenmore 6476037323 KENMORE 30 INCH GAS RANGE
Kenmore 6476037340 KENMORE 30 IN GAS RANGE
  #2 (permalink)
Old 11-24-2009, 09:43 AM
Senior Expert
APP Volunteer
SublimeMasterJW is on a distinguished road
Default
Any 2 wire thermostat will work. This one offered by APP is a quality one that should last for many years. Comes with instructions and is made by White Rodgers a hallmark company in HVAC parts. It costs a bit more than an el cheapo home store type one but you gets what you pay for. Instructions included. A few things you may want to do before turning on the thermostat. Check the gas valve for the amp draw. .2,.3,.4 etc. Set the heat anticipator to the amp draw of the gas valve. Why? This is so the heat will shut down a hair earlier and not overshoot the comfort zone and run you out the house. Then when it shuts down it waits till freezing to cut back on. Most of the thermostats are pre set but it never hurts to check. Never touch the 2 wires together at the gas valve to see if you have power. Doing so will fry the heat anticipator and you will need to buy another one.
Here is a few notes I wrote down concerning these fine wall heaters:
Their are a couple different versions of these. The originals had no fan and used millivolt wall themostats. The fan driven ones use the same thermostat. The millivolt gas valve relys on the voltage from the thermophile to control the whole operation. Yours however does not use a thermophile( a thermophile cost $75) Yours uses a $7 thermocouple so that tells me your heater works with a 24 volt transformer. Like I was saying the Williams wall heater uses low voltage thermostat mounted on wall. If that thermostat has no continuity get another one. The heater uses a 120 to 24 volt ac transformer to power that gas operator on the combination gas valve. It is called a combination gas valve because it combines a gas operator( to open the burner gas thermistatically) and a pressure regulator to bring down the meter pressure to specific pressure to allow for the rest of the gas appliances in the house to function properly. The transformer is located up near the top of heater where the power cord comes in. If it is bad then the heat will not come on. Remove the 2 wires on the gas valve operator and check them for 24 volts output. Never touch the 2 wires together to check for power as this will fry the heat anticipator on the wall thermostat and ruin it. Check the 2 terminals on the gas valve for continuity. If they are open the gas valve will not work(the pilot will, but not the main gas). The gas valve has a thermocouple whichs holds open the gas when the pilot is lit. The thermocouple has a ceramic fuse mounted in series which kills the thermocouple and shuts down the gas, when the heater gets too hot. The burner must be wire brushed cleaned well to prevent uneven combustion. The heat exchanger must be clean of cobwebs and rust. The chimney stack must be clear. If not, the heater fuse will shut down. The burner will fire off but the fan does not come on right away. The fan klixon mounted midways up the heat exchanger under the front cover will turn the fan on as soon as the heat exchanger is properly warmed. Another 3 wire klixon controls high and low speeds. A third one is a high limit which shuts down the heater if that fan won't come on. The heater is pretty easy to work on. The burner assembly is removable for bench testing and repairs. The gas valve will need replacing sooner or later and you can damage the burner if you are not careful. I put the valve in a vice and turn the burner near where it screws into the valve. The fan blade will tend to rattle and this can be fixed by peening the hub. I remove the fan blade and set it on a 1/2 inch shaft, using a ball peen hammer and blount nose chisel. I dimple the hub all around the shaft to tighten it up. Hey it saves 50 bucks. I also oil the motor with Hi temp oil. I use zoom spout turbine oil.
The pilot on these heaters is mounted on the cast iron burner so that when heat is called for the flame will quickly ignite the burner.
To light this heater: Move the knob to the "PILOT" position. Press down on the gas knob and light the pilot. Hold down on the button until the pilot stays lit with the button released. Move the knob to the "ON" position. If the wall thermostat is in the on position then the burner should light off. After a minute or so the fan should kick in. When the wall thermostat is satisfied the burner will shut down but the fan will continue to blow until the heat in the exchanger drops
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
wall oven tune Oven Repair (including Ranges and Cooktops) 0 08-09-2009 09:02 AM
wall oven tune Washer Repair 1 08-08-2009 06:07 PM
Jenn Air Wall Electric Wall Oven WILLIAM SHIVER Oven Repair (including Ranges and Cooktops) 3 05-20-2009 12:56 AM
Wall Furnance gas valve exchange DBM Heating, Ventilation, and Air Conditioning (HVAC) 3 01-23-2009 01:08 PM
wall oven Angela50 Oven Repair (including Ranges and Cooktops) 0 12-09-2008 03:02 PM
