Discuss
Bosch/Aquastar Tankless Water Heater
 in
Heating, Ventilation, and Air Conditioning (HVAC)
I have propane fed tankless water heater with an electrical (battery powered) igniter. It died suddenly - checked batteries, voltage is
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » Bosch/Aquastar Tankless Water Heater
  #1 (permalink)
Old 03-04-2008, 04:26 PM
drradon drradon is offline
Junior Member
drradon is on a distinguished road
Default Bosch/Aquastar Tankless Water Heater
Model Number: 125X   Brand: Bosch   Age: 1 - 5 years
I have propane fed tankless water heater with an electrical (battery powered) igniter. It died suddenly - checked batteries, voltage is fine there - and no change when new batteries are installed; gas supply is fine; lines are clean. There is no spark to start the pilot when the hot water line is on; and the red LED indicator light is not lit. (I believe LED is supposed to be lit when the unit is "on" and goes to flashing when the batteries are low. )
My best guess is that the igniter module - that apparently generates a HV AC for the ignition spark - is bad and needs to be replaced? Alternatives diagnoses??? Anything else I can check with a VOM to confirm diagnosis?
Many thanks.
Related Models
Whirlpool 1262W0A
Whirlpool 1262^0A
Admiral 1265H-EZW Walloven - S/c Ele
Whirlpool 1265W0A
Whirlpool 1265^0A
Whirlpool 1268W56
Whirlpool 1268W66
Whirlpool 1268^56
Whirlpool 1268^66
Whirlpool 1276W0A
Whirlpool 1276^0A
Amana 1285.000 Mwave - Family Size (60 Hz)
Amana 1285.A Mwave - Family Size (60 Hz)
Amana 1290.000 Mwave - Family Size (60 Hz)
Amana 12A Freezer - Vertical
Amana 12A1 Freezer - Vertical
Amana 12A2 Freezer - Vertical
Amana 12B Freezer - Vertical
Amana 12C2MA Room Air Conditioner
Amana 12C2MB Room Air Conditioner
Amana 12C2MD Room Air Conditioner
Amana 12C2MT Room Air Conditioner
Amana 12C2MY Room Air Conditioner
Amana 12C3A Room Air Conditioner
Amana 12C3B Room Air Conditioner
Amana 12C3EV Room Air Conditioner
Amana 12C3EW Room Air Conditioner
Amana 12C3HES Room Air Conditioner
Amana 12C3HEV Room Air Conditioner
Amana 12C3HEW Room Air Conditioner
Amana 12C3T Room Air Conditioner
Amana 12C3V Room Air Conditioner
Amana 12C3W Room Air Conditioner
Amana 12C5A Room Air Conditioner
Amana 12C5B Room Air Conditioner
Amana 12C5C Room Air Conditioner
Amana 12C5V Room Air Conditioner
Amana 12C5W Room Air Conditioner
Amana 12C5Y Room Air Conditioner
Amana 12E Freezer - Vertical
Amana 12F Freezer - Vertical
Amana 12G Freezer - Vertical
Amana 12H Freezer - Vertical
Frigidaire 12HA121
Frigidaire 12HA121A
Amana 12J Freezer - Vertical
Amana 12JI Freezer - Vertical
Amana 12M12TA Room Air Conditioner
Amana 12M22PA Room Air Conditioner
Amana 12M22PB Room Air Conditioner
Amana 12M22PC Room Air Conditioner
Amana 12M32PAE Room Air Conditioner
Amana 12M32PAEH Room Air Conditioner
Amana 12M32PBE Room Air Conditioner
Amana 12M32PBEH Room Air Conditioner
Amana 12M32PCE Room Air Conditioner
Amana 12M52TA Room Air Conditioner
Amana 12M52TB Room Air Conditioner
Amana 12QZ22RC Room Air Conditioner
Amana 12QZ22RC1 Room Air Conditioner
Amana 12QZ22TA Room Air Conditioner
Amana 12QZ22TB Room Air Conditioner
Thermador 12WC
Frigidaire 13-2589-00-01 Tap(v1) / Electric Modular Cooktop
Frigidaire 13-2589-32-01 Tap(v2) / Electric Modular Cooktop
Frigidaire 13-2620-00-01 Tap(v2) / Electric Countertop Range
Frigidaire 13-2620-00-02 Tap(v2) / Electric Countertop Range
Frigidaire 13-2620-08-02 Tap(v1) / Electric Countertop Range
Frigidaire 13-2620-23-01 Tap(v1) / Electric Countertop Range
Frigidaire 13-2620-23-02 Tap(v3) / Electric Countertop Range
Frigidaire 13-2626-00-10 Tap(v2) / Electric Cooktop
Frigidaire 13-2626-08-10 Tap(v1) / Electric Cooktop
Frigidaire 13-2626-23-10 Tap(v3) / Electric Cooktop
Frigidaire 13-2626-57-10 Tap(v4) / Electric Cooktop
Frigidaire 13-2626-66-10 Tap(v5) / Electric Cooktop
Frigidaire 13-3008-00-01 Tap(v1) / Electric Range
Frigidaire 13-3008-23-01 Tap(v2) / Electric Range
Frigidaire 13-3008-45-01 Tap(v3) / Electric Range
Frigidaire 13-3008-57-01 Tap(v4) / Electric Range
Frigidaire 13-3008-66-01 Tap(v5) / Electric Range
Frigidaire 13-3028-00-01 Tap(v1) / Electric Range
Frigidaire 13-3028-00-02 Tap(v1) / Electric Cooktop Range
Frigidaire 13-3028-08-02 Tap(v3) / Electric Cooktop Range
Frigidaire 13-3028-23-01 Tap(v2) / Electric Range
Frigidaire 13-3028-23-02 Tap(v2) / Electric Cooktop Range
Frigidaire 13-3028-45-01 Tap(v3) / Electric Range
Frigidaire 13-3028-57-01 Tap(v4) / Electric Range
Frigidaire 13-3028-66-01 Tap(v5) / Electric Range
Frigidaire 13-3069-10-02 Tap(v1) / Electric Countertop Range
Frigidaire 13-3078-00-01 Tap(v1) / Electric Range
Frigidaire 13-3078-00-02 Tap(v1) / Electric Cooktop Range
Frigidaire 13-3078-23-01 Tap(v2) / Electric Range
Frigidaire 13-3078-23-02 Tap(v2) / Electric Cooktop Range
Frigidaire 13-3078-45-01 Tap(v3) / Electric Range
  #2 (permalink)
Old 08-16-2008, 07:08 PM
artie in miami artie in miami is offline
Junior Member
artie in miami is on a distinguished road
Default no spark in the aquastar heater
I also have a bosch aquastar tankless heater that uses propane except mine has the pilotless feature where the water moving through the unit generates the spark to light the propane (hydrogenerator...water spins a magnet inside a coil and makes the electricity). I had the same problem and found that the line that goes outside from the powervent module was clogged by some type of insect that made a nest in it. The safety feature shut the unit down...that took me several hours to figure out. If you have the powervent (takes the exhaust gases out of the house) and it has the stainless steel tubing going through the wall to vent outside...check that thin tube outside and see if it is clogged.
Right now mine won''t make a spark either...I am getting no voltage from the hydrogenerator and a replacement generator is around $125 and is nonreturnable. I wish I could find a place to buy parts for the hydrogenerator...all I need is the flow wheel/magnet...probably a two dollar piece. My magnet has a crack in it and I think it is the problem.
I wonder if it is possible to change the aquastar 125HX over to a battery powered spark or even one that uses 110 volts home power ?? Anybody know about that.
artie in miami
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
wiring hot water heater kyle pennsylvania Heating, Ventilation, and Air Conditioning (HVAC) 2 03-08-2008 07:26 AM
Bosch dishwasher not filling with water rritter Dishwasher Repair 3 01-17-2008 09:10 PM
Bosch keeps filling with water noisybosch Dishwasher Repair 1 11-18-2007 05:26 AM
Bosch/water in tub vz223 Dishwasher Repair 1 10-31-2007 07:00 PM
Gas TANKLESS WATER HEATER no heat Eddy General Talk 2 08-04-2007 06:54 PM
