Discuss
Coleman Evcom furnace stops, need cool down
 in
Heating, Ventilation, and Air Conditioning (HVAC)
I am located in Ontario, Canada. it is around 10 degree F. outside. My 18 years old furnace stops last
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » Coleman Evcom furnace stops, need cool down
  #1 (permalink)
Old 12-14-2017, 09:36 PM
Junior Member
newkid@north is on a distinguished road
Default Coleman Evcom furnace stops, need cool down
Model Number: coleman Evcom   Brand: -brand-   Age: More than 10 years
My 18 years old furnace stops last evening. I have to turn OFF both AC and thermostat long enough before the furnace would came back normal. It works for couple hours last night, I can hear it cycle OFF and ON on its own before went to bed.
Wake up at 65 degree in the morning, obviously it stops during the night. Have to shutdown AC and thermostat and wait long before it starts again.
Get back home early today and it was stops again.
My observations are:
*The furnace is try running as gas was heating up the unit.
*Seeing the 4 flash code couple times when checking.
*it seems that AC & thermostat reset would not put furnace back normal right the way. Has to wait longer to cool down.
*During my troubleshooting and restart, ignition will starts, frame goes on full, blower will not starts after minutes. I think eventually furnace stops after overheat protections.
*I checked the limit switch (LS1) is close when shutdown (AC off)
*The pressure switches burner 1LP & condensate 2LP are close when shutdown (AC off).
*Put the FAN to ON on thermostat would not starts the blower. (only starts after a long shutdown period)
*The impeller of blower could turns freely by hand.
*Each normal operation would last for 2+ hours before (blower?) stops, gas will frame up again but no blower.
*Blower motor was hot to touch every time after stops.
When measuring on blower motor wires, blue is heat, black in cool, red is park, white is neutral.
*After the last furnace stops, there is 170VAC between the park red wire & neutral white wire and 120VAC between cool black wire & neutral. Zero volt between heat blue wire and neutral. Furnace frame up but blower motor not turning.
*I measured that heat blue wire is open to neutral, 14ohm between red & neutral and 6ohm between cool black & neutral.
Is these symptoms pointing to either the blower motor or the 5uF capacitor is going to die?
Perhaps there is a overheat thermostat inside the blower motor which get open circuit due to overheat.
My big question is "would motor overheat caused by a bad capacitor?"
or the motor is almost dead?
Appreciated your help and expertise.
Thank You,
Philip
Related Models
Jenn-Air CP120B SURF CONT PANEL UNIT- DDFT ELE
Jenn-Air CP120B-C SURF CONT PANEL UNIT- DDFT ELE
Jenn-Air CP120B-EM Surf Cont Panel Unit - Ddft Ele
Jenn-Air CP120S SURF CONT PANEL UNIT- DDFT ELE
Jenn-Air CP120S-C SURF CONT PANEL UNIT- DDFT ELE
Jenn-Air CP120W SURF CONT PANEL UNIT- DDFT ELE
Jenn-Air CP120W-C SURF CONT PANEL UNIT- DDFT ELE
Amana CP15-2 FREEZER- CHEST
Amana CP153 FREEZER- CHEST
Whirlpool CP1961XLQ00 VERTICAL FREEZER
Jenn-Air CP200B SURF CONT PANEL UNIT- DDFT ELE
Jenn-Air CP200B-C SURF CONT PANEL UNIT- DDFT ELE
Frigidaire CP200SP2D1 Kel(v10) / Gas Range
Frigidaire CP200SP2D2 Frg(v2) / Gas Range
Frigidaire CP200SP2W1 Tap(v4) / Gas Range
Frigidaire CP200SP2W2 Frg(v1) / Gas Range
Jenn-Air CP220B Surf Cont Panel Unit - Ddft Ele
Jenn-Air CP220B-C Surf Cont Panel Unit - Ddft Ele
Jenn-Air CP220B-EM SURF CONT PANEL UNIT- DDFT ELE
Jenn-Air CP220S Surf Cont Panel Unit - Ddft Ele
Jenn-Air CP220S-C Surf Cont Panel Unit - Ddft Ele
Jenn-Air CP220W Surf Cont Panel Unit - Ddft Ele
Jenn-Air CP220W-C Surf Cont Panel Unit - Ddft Ele
Jenn-Air CP240B SURF CONT PANEL UNIT- DDFT ELE
Frigidaire CP240SP2D1 Kel(v10) / Gas Range
Frigidaire CP240SP2D2 Frg(v2) / Gas Range
Frigidaire CP240SP2D3 Frg(v2) / Gas Range
Frigidaire CP240SP2L02 Frg(v2) / Gas Range
Frigidaire CP240SP2W1 Tap(v4) / Gas Range
Frigidaire CP240SP2W2 Frg(v1) / Gas Range
Frigidaire CP240SP2W3 Frg(v1) / Gas Range
Frigidaire CP302BP2D1 Gib(v8) / Gas Range
Frigidaire CP302BP2D2 Frg(v1) / Gas Range
Frigidaire CP302BP2D3 Frg(v2) / Gas Range
Frigidaire CP302BP2W1 Tap(v4) / Gas Range
Frigidaire CP302BP2W2 Frg(v2) / Gas Range
Frigidaire CP302BP2W3 Frg(v1) / Gas Range
Frigidaire CP302BP2WJ01 Kel(v15) / Gas Range
Frigidaire CP302BP2WW01 Frg(v1) / Gas Range
Frigidaire CP302BP2WY01 Gib(v9) / Gas Range
Frigidaire CP302BP2Y1 Frg(v3) / Gas Range
Frigidaire CP303VC3D1 Frg(v2) / Gas Range
Frigidaire CP303VC3D2 Frg(v2) / Gas Range
Frigidaire CP303VC3W1 Frg(v1) / Gas Range
Frigidaire CP303VC3W2 Frg(v1) / Gas Range
Frigidaire CP303VP2D01 Kel(v14) / Gas Range
Frigidaire CP303VP2D1 Frg(v2) / Gas Range
Frigidaire CP303VP2D3 Frg(v2) / Gas Range
Frigidaire CP303VP2D4 Frg(v4) / Gas Range
Frigidaire CP303VP2J01 Kel(v15) / Gas Range
Frigidaire CP303VP2W01 Tap(v4) / Gas Range
Frigidaire CP303VP2W1 Frg(v1) / Gas Range
Frigidaire CP303VP2W3 Frg(v1) / Gas Range
Frigidaire CP303VP2W4 Frg(v3) / Gas Range
Frigidaire CP303VP2Y1 Frg(v3) / Gas Range
Frigidaire CP305WP2W1 Frg(v1) / Gas Range
Frigidaire CP305WP2W2 Frg(v1) / Gas Range
Crosley CP31200ADQ RANGE- F/S STD GAS
Crosley CP31200ADV RANGE- F/S STD GAS
Crosley CP31200BDQ RANGE- F/S STD GAS
Crosley CP31200BDV RANGE- F/S STD GAS
Crosley CP31600ADQ RANGE- F/S STD GAS
Crosley CP31600ADV RANGE- F/S STD GAS
Jenn-Air CP320B JENN-AIR ACCESSORY
Jenn-Air CP320B-C SURF CONT PANEL UNIT- DDFT ELE
Jenn-Air CP320B-EM JENN-AIR ACCESSORY
Jenn-Air CP320S ELECTRIC GRILL
Jenn-Air CP320S-C SURF CONT PANEL UNIT- DDFT ELE
Jenn-Air CP320W ELECTRIC GRILL
Jenn-Air CP320W-C SURF CONT PANEL UNIT- DDFT ELE
Jenn-Air CP340B SURF CONT PANEL UNIT- DDFT ELE
General Electric CP350ST1SS ELECTRIC RANGE
Thermador CP55 COMBINATION OVEN
General Electric CP650ST1SS ELECTRIC RANGE
Frigidaire CPBM189KFA MICROWAVE
Frigidaire CPBM189KFB MICROWAVE
Frigidaire CPCF3091LFA ELECTRIC RANGE
Frigidaire CPCF3091LFB ELECTRIC RANGE
Frigidaire CPCF3091LFC ELECTRIC RANGE
Frigidaire CPCF3091LFD ELECTRIC RANGE
Frigidaire CPCS3085LFA ELECTRIC RANGE
Frigidaire CPCS3085LFB ELECTRIC RANGE
Frigidaire CPCS389DC3 Frigidaire Canada/dual Fuel Range
Frigidaire CPCS389EC2 Frigidaire Canada/gas Range
Frigidaire CPCS389EC3 Frigidaire Canada/gas Range
Frigidaire CPCS389EC4 Frigidaire/gas Range
Frigidaire CPCS389EC5 Frigidaire Canada/gas Range
Frigidaire CPCS389EC6 DUAL FUEL RANGE
Frigidaire CPCS389EC7 DUAL FUEL RANGE
Frigidaire CPCS389EC9 DUAL FUEL RANGE
Hardwick CPD9822A539ACG RANGE- S/C F/S GAS
Hardwick CPD9822W539ACG RANGE- S/C F/S GAS
Hardwick CPD9826A429R RANGE- S/C F/S GAS
Hardwick CPD9826W429R RANGE- S/C F/S GAS
Hardwick CPD9843KA659ACG RANGE- S/C F/S GAS
Hardwick CPD9843KA659AG RANGE- S/C F/S GAS
Hardwick CPD9843KW659ACG RANGE- S/C F/S GAS
Hardwick CPD9843KW659AG RANGE- S/C F/S GAS
Hardwick CPD9849KW659A RANGE- S/C F/S GAS
Frigidaire CPDF4085KF1 RANGE
Frigidaire CPDF4085KF2 RANGE
Frigidaire CPDS3085KF1 RANGE
Frigidaire CPDS3085KF2 RANGE
Frigidaire CPDS3085KF3 RANGE
Frigidaire CPDS3085KF4 RANGE
Frigidaire CPDS3085KF5 RANGE
Frigidaire CPEB27S9DC1
Frigidaire CPEB27S9DC2 Frigidaire/wall Oven
Frigidaire CPEB27S9FC1 Frigidaire/wall Oven
Frigidaire CPEB27S9FC2 Frigidaire Canada/walloven
Frigidaire CPEB27S9FC3 WALL OVEN
Frigidaire CPEB27S9FC4 WALL OVEN
Frigidaire CPEB27S9FC5 WALL OVEN
Frigidaire CPEB30S9DC2 Frigidaire Canada/wall Oven
Frigidaire CPEB30S9FC1 Frigidaire/wall Oven
Frigidaire CPEB30S9FC2 Frigidaire/wall Oven
Frigidaire CPEB30S9FC3 WALL OVEN
Frigidaire CPEB30S9FC4 WALL OVEN
Frigidaire CPEB30S9FC7 WALL OVEN
  #2 (permalink)
Old 12-14-2017, 10:58 PM
Junior Member
Default
The latest status of my stops Coleman furnace is it would not starts after long cooling at HEAT and FAN ON positions.
I have to switch to COOL and FAN ON, let the blower turns, then I switch back to HEAT.
To my surprise, even when the gas frame up in full, blower runs with hot air blowing out, the blower motor blue wire for HEAT stays at ZERO volt!
Is my furnace do not has separate speed for HEAT? (one speed for COOL and HEAT?)
This runs for 15 minutes then having a 6 flash error code.
perhaps my problem is block vent or intake pipes?
Any idea?
  #3 (permalink)
Old 12-15-2017, 06:41 AM
Junior Member
Default Furnace still not starts normally.
last night after the 15 minutes runs, then stop with 6 flash code, Im not able to bring it back after long cooling. So put the furnace to OFF before bed.
This morning I put the thermostat to COOL position, FAN to auto.
Turn on the furnace, back to the thermostat, turn the FAN to ON, blower starts after couple of seconds. Once again the blower will starts at COOL position. Later flip the swithc to HEAT, couple more seconds later gas starts, warm air came out in minutes.
It ran for more than 2 hours non-stop by now.
This furnace has no AC, AC was added later years. It might explain why there is only one speed.
Any suggestion or comments to above problems?
Thanks.
  #4 (permalink)
Old 12-15-2017, 11:35 AM
Junior Member
Default
Any help?
Thanks...
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Coleman Furnace/Trane AC unit pdl2 Heating, Ventilation, and Air Conditioning (HVAC) 0 08-03-2013 08:19 AM
Timer Stops At Cool Down and Will Not Continue to Off Position ymkarlsson Dryer Repair 1 02-20-2012 02:05 PM
Coleman Evcon flame off garycoleman Heating, Ventilation, and Air Conditioning (HVAC) 9 02-25-2011 06:59 PM
Amana Furnace Stops working produces oil/electic smell hamsi067 Heating, Ventilation, and Air Conditioning (HVAC) 1 11-17-2009 03:55 PM
Freezer works, Fridge won't Cool...fan stops Gamla33 Refrigerator & Freezer Repair 1 10-07-2007 12:15 PM
