Discuss
Water Heater Pilot Problem
 in
Heating, Ventilation, and Air Conditioning (HVAC)
Having an issue with my gas water heater pilot on my 11 year old 50 gallon Kenmore Power Miser 12
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » Water Heater Pilot Problem
  #1 (permalink)
Old 11-22-2017, 03:42 PM
Junior Member
jman02 is on a distinguished road
Default Water Heater Pilot Problem
Model Number: 153.331544   Brand: Kenmore   Age: More than 10 years
Having an issue with my gas water heater pilot on my 11 year old 50 gallon Kenmore Power Miser 12 model 153.331544. Pilot always go out when burner shuts off. No issues with lighting the pilot. But I change temperature setting to hot, burner fires up, stays on for about 10 minutes, burner shuts off and pilot goes with it.....everytime.
The pilot lights with no problem and stays on all day with temperature setting on pilot lighting. I've removed the burner assembly and cleaned the thermocouple and pilot tube with sandpaper. Also vacuumed and dusted the inside of the chamber and the air intake screens below. Also checked mV from thermocouple after lighting pilot, got up to 22-23 mV.
Could I have a bad control valve? Or is there something else I should check? Control valve is about $110 so don't want to replace without a good feeling that this should be it.
Thanks for any help.
Related Models
Frigidaire 15304-0A REFRIGERATOR
Frigidaire 15304-7A REFRIGERATOR
General Electric 154510 Electric range
Frigidaire 1547 SINKMASTER DISPOSAL
Amana 1550.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1551.000 MWAVE - FAMILY SIZE (60 HZ)
Kenmore 1552399-2 OPTIONAL ROTISSERIE KIT
Kenmore 15530810 KENMORE GAS BUILT-IN OVEN UNIT
Kenmore 15530815 KENMORE GAS OVEN UNIT
Kenmore 1553107050 OPTIONAL ROTISSERIE KIT
Kenmore 1553227290 KENMORE GAS BUILT-IN CONTINUOUS CLEANING OVEN
Kenmore 1553227291 KENMORE GAS BUILT-IN CONTINOUS CLEANING OVEN
Kenmore 1553227590 KENMORE GAS BUILT-IN CONTINUOUS CLEANING OVEN
Kenmore 1553227690 KENMORE GAS BUILT-IN CONTINUOUS CLEANING OVEN
Kenmore 15535060 BUILT-IN OVEN UNIT
Kenmore 15535170 KENMORE ELECTRIC BUILT-IN OVEN UNIT
Kenmore 15535260 BUILT-IN OVEN UNIT
Kenmore 1553546600 KENMORE GAS DROP-IN RANGE
Kenmore 1553546620 KENMORE GAS DROP-IN RANGE
Kenmore 1553546640 KENMORE GAS DROP-IN RANGE
Kenmore 1553546650 KENMORE GAS DROP-IN RANGE
Kenmore 1553546660 KENMORE GAS DROP-IN RANGE
Kenmore 1553546690 KENMORE GAS DROP-IN RANGE
Kenmore 1553546700 KENMORE GAS DROP-IN RANGE
Kenmore 1553546701 KENMORE GAS DROP-IN RANGE
Kenmore 1553546720 KENMORE GAS DROP-IN RANGE
Kenmore 1553546721 KENMORE GAS DROP-IN RANGE
Kenmore 1553546730 KENMORE GAS DROP-IN RANGE
Kenmore 1553546740 KENMORE GAS DROP-IN RANGE
Kenmore 1553546741 KENMORE GAS DROP-IN RANGE
Kenmore 1553546760 KENMORE GAS DROP-IN RANGE
Kenmore 1553546761 KENMORE GAS DROP-IN RANGE
Kenmore 1553546790 KENMORE GAS DROP-IN RANGE
Kenmore 1553547000 KENMORE GAS DROP-IN RANGE
Kenmore 1553547020 KENMORE GAS DROP-IN RANGE
Kenmore 1553547040 KENMORE GAS DROP-IN RANGE
Kenmore 1553547060 KENMORE GAS DROP-IN RANGE
Kenmore 1553547080 KENMORE GAS DROP-IN RANGE
Kenmore 1553547090 KENMORE GAS DROP-IN RANGE
Kenmore 1553567000 KENMORE RANGE
Kenmore 1553567001 KENMORE GAS DROP-IN RANGE
Kenmore 1553567020 KENMORE RANGE
Kenmore 1553567021 KENMORE GAS DROP-IN RANGE
Kenmore 1553567040 KENMORE RANGE
Kenmore 1553567041 KENMORE GAS DROP-IN RANGE
Kenmore 1553567060 KENMORE RANGE
Kenmore 1553567061 KENMORE GAS DROP-IN RANGE
Kenmore 1553567090 KENMORE RANGE
Kenmore 1553567091 KENMORE GAS DROP-IN RANGE
Kenmore 1553567200 KENMORE GAS DROP-IN RANGE
Kenmore 1553567201 KENMORE GAS DROP-IN RANGE
Kenmore 1553567290 KENMORE GAS DROP-IN RANGE
Kenmore 1553567291 KENMORE GAS DROP-IN RANGE
Kenmore 1553567292 KENMORE GAS DROP-IN RANGE
Kenmore 1553567300 KENMORE GAS DROP-IN RANGE
Kenmore 1553567301 KENMORE DROP-IN RANGE
Kenmore 1553567302 KENMORE GAS DROP-IN RANGE
Kenmore 1553567303 KENMORE GAS DROP-ON RANGE
Kenmore 1553567390 KENMORE GAS DROP-IN RANGE
Kenmore 1553567391 KENMORE DROP-IN RANGE
Kenmore 1553567392 KENMORE GAS DROP-IN RANGE
Kenmore 1553567393 KENMORE GAS DROP-ON RANGE
Kenmore 1553567500 KENMORE GAS DROP-IN RANGE
Kenmore 1553567501 KENMORE GAS DROP-IN RANGE
Kenmore 1553567590 KENMORE GAS DROP-IN RANGE
Kenmore 1553567591 KENMORE GAS DROP-IN RANGE
Kenmore 1553567600 KENMORE GAS DROP-IN RANGE
Kenmore 1553567690 KENMORE GAS DROP-IN RANGE
Kenmore 1553567700 KENMORE GAS DROP-IN RANGE
Kenmore 1553567790 KENMORE GAS DROP-IN RANGE
Kenmore 15540310 KENMORE ELECTRIC RANGE
Kenmore 15540815 KENMORE ELECTRIC OVEN UNIT
Kenmore 15541815 KENMORE ELECTRIC SURFACE UNIT
Kenmore 1554357690 KENMORE ELECTRIC CERAMIC COOKTOP DROP-IN RANGE
Kenmore 1554507000 KENMORE ELECTRIC DROP-IN RANGE
Kenmore 1554507001 KENMORE ELECTRIC RANGE
Kenmore 1554507011 KENMORE ELECTRIC RANGE
Kenmore 1554507300 KENMORE ELECTRIC RANGE
Kenmore 1554507500 KENMORE ELECTRIC CONTINUOUS CLEANING DROP-IN RANGE
Kenmore 1554507600 KENMORE ELECTRIC CONTINUOUS CLEANING DROP-IN RANGE
Kenmore 1554507700 KENMORE ELECTRIC CONTINUOUS CLEANING DROP-IN RANGE
Kenmore 1554527300 SEARS KENMORE ELECTRIC DROP-IN RANGE
Kenmore 1554527301 KENMORE ELECTRIC RANGE
Kenmore 1554527500 KENMORE ELECTRIC CONTINUOUS CLEANING DROP-IN RANGE
Kenmore 1554527600 KENMORE ELECTRIC CONTINUOUS CLEANING DROP-IN RANGE
Kenmore 1554527700 KENMORE ELECTRIC CONTINUOUS CLEANING DROP-IN RANGE
Kenmore 1554537390 KENMORE ELECTRIC CERAMIC COOK TOP DROP-IN RANGE
Kenmore 1554537590 KENMORE ELECTRIC CERAMIC COOK TOP DROP-IN RANGE
Kenmore 1554537591 KENMORE ELECTRIC CERAMIC COOKTOP DROP-IN RANGE
Kenmore 1554537690 KENMORE ELECTRIC CERAMIC COOKTOP DROP-IN RANGE
Kenmore 1554537790 KENMORE ELECTRIC CERAMIC COOKTOP DROP-IN RANGE
Kenmore 1554546601 KENMORE ELECTRIC DROP-IN RANGE
Kenmore 1554546620 KENMORE ELECTRIC DROP-IN RANGE
Kenmore 1554546621 KENMORE ELECTRIC DROP-IN RANGE
Kenmore 1554546640 KENMORE ELECTRIC DROP-IN RANGE
Kenmore 1554546641 KENMORE ELECTRIC DROP-IN RANGE
Kenmore 1554546651 KENMORE ELECTRIC DROP-IN RANGE
Kenmore 1554546661 KENMORE ELECTRIC DROP-IN RANGE
Kenmore 1554546691 KENMORE ELECTRIC DROP-IN RANGE
Kenmore 1554546700 KENMORE ELECTRIC DROP-IN RANGE
Kenmore 1554546701 KENMORE ELECTRIC DROP-IN RANGE
Kenmore 1554546702 KENMORE ELECTRIC DROP - IN RANGE
Kenmore 1554546720 KENMORE ELECTRIC DROP-IN RANGE
Kenmore 1554546721 KENMORE ELECTRIC DROP-IN RANGE
Kenmore 1554546722 KENMORE ELECTRIC DROP - IN RANGE
Kenmore 1554546730 KENMORE ELECTRIC DROP-IN RANGE
Kenmore 1554546731 KENMORE ELECTRIC DROP-IN RANGE
Kenmore 1554546732 KENMORE ELECTRIC DROP - IN RANGE
Kenmore 1554546740 KENMORE ELECTRIC DROP-IN RANGE
Kenmore 1554546741 KENMORE ELECTRIC DROP-IN RANGE
Kenmore 1554546742 KENMORE ELECTRIC DROP - IN RANGE
Kenmore 1554546760 KENMORE ELECTRIC DROP-IN RANGE
Kenmore 1554546761 KENMORE ELECTRIC DROP-IN RANGE
Kenmore 1554546762 KENMORE ELECTRIC DROP - IN RANGE
Kenmore 1554546790 KENMORE ELECTRIC DROP-IN RANGE
Kenmore 1554546791 KENMORE ELECTRIC DROP-IN RANGE
Kenmore 1554546792 KENMORE ELECTRIC DROP - IN RANGE
Kenmore 1554547000 KENMORE ELECTRIC DROP-IN RANGE
Kenmore 1554547001 KENMORE ELECTRIC DROP-IN RANGE
Kenmore 1554547002 KENMORE ELECTRIC DROP-IN RANGE
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
AO Smith Hotwater Heater Pilot Paul Stonerod Heating, Ventilation, and Air Conditioning (HVAC) 0 12-03-2012 08:27 AM
A.O. Smith Water Heater Pilot Light iwanttofixit Heating, Ventilation, and Air Conditioning (HVAC) 1 03-12-2012 08:15 PM
Heater Pilot Not Lighting tonyg Oven Repair (including Ranges and Cooktops) 5 03-26-2011 05:50 PM
Water heater problem Mike63 Refrigerator & Freezer Repair 0 07-11-2010 09:43 PM
