Discuss
erratic heat cycles
 in
Heating, Ventilation, and Air Conditioning (HVAC)
I have a Payne 90% gas furnace. It was installed in 1991 or 92. Ten days ago we woke up
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » erratic heat cycles
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 02-20-2008, 03:50 PM
kw48116 kw48116 is offline
Junior Member
kw48116 is on a distinguished road
Default erratic heat cycles
Model Number: 398AAV036060   Brand: -other-   Age: More than 10 years
I have a Payne 90% gas furnace. It was installed in 1991 or 92. Ten days ago we woke up to no heat. I cycled the power to the unit and it fired right up. It maintained the heat cycle until the house reached the set temp. It worked OK for a day and then same thing no heat and would work fine after cycling the power. The White-Rogers programmable T-stat that was originally installed (and only displayed Celsius) was replaced as the suspected problem. What is a real concern is that once I had to cycle power several times to get to the point where the burners fired up. The igniter would glow and then I could hear a relay trip and then nothing. About the 4th try the burners kicked on and it ran. With the new Honeywell t-stat installed all was good for about a week. Now same issue has returned. As an aside, it seems to take longer to come up to temp then before. It took 2 hours to gain 4 degrees. Any suggestions would be welcome on how to troubl shoot this. Thanks
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-12-2008, 04:13 PM
#1 tech #1 tech is offline
Junior Member
#1 tech is on a distinguished road
Default
i would be concirned about the gas valve .. probly the click you heard .. theese can be a pain to troubleshoot when it is not a consistent problem ... there very well could be a board issue ... could be time for a pro
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag microwave erratic jackinga Microwave Repair 4 01-17-2008 10:46 AM
Oven erratic effyt Oven Repair (including Ranges and Cooktops) 3 01-15-2008 12:01 PM
BOSCH DW Does not run thru cycles Waterguy81 Dishwasher Repair 2 12-27-2007 08:12 PM
Washer Not Going Thru Most Cycles ncnicholson Washer Repair 3 11-29-2007 08:17 PM
Bad noise & erratic motion when agitator runs k8mp Washer Repair 3 10-15-2007 09:51 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
