Discuss
Friedrich Model SM21N30 Coils Freezing
 in
Heating, Ventilation, and Air Conditioning (HVAC)
Hello! I have a Friedrich Model #SM21N30 room AC unit install through the wall in my home since August 14,
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » Friedrich Model SM21N30 Coils Freezing
  #1 (permalink)
Old 06-20-2016, 11:17 AM
Junior Member
tcontic is on a distinguished road
Default Friedrich Model SM21N30 Coils Freezing
Model Number: SM21N30   Brand: -other-   Age: 1 - 5 years
Hello!
I have a Friedrich Model #SM21N30 room AC unit install through the wall in my home since August 14, 2012. Until this summer it's performed flawlessly cooling as expected. Now the interior coils have started freezing up at set temperatures as high as 68 degrees, this is where I normally set it for the past four years.
I check and clean the filter regularly it clean, the coils are also clean, spotless in fact. No outside air restrictions.
A local service person came out to check the unit and stated that it's clean, and not low on refrigerant. His test for low refrigerant was not very scientific, he basically out his hand on the coils and found uniform cooling from top to bottom. Nothing else he can do.
I called Friedrich as the sealed components are still under warrently until August of 2017 but the authorized service companies they recommended would not come to my location, they said because of distance, very strange. I don't live in a rural area, they just said its too far...
Is there anything else I can check on my own? Error codes? Thermostat?
Any help would be greatly appreciated.
Related Models
Amana SM22TBL REF - SXS/I&W
Amana SM22TBW REF - SXS/I&W
Frigidaire SM230JXD1 Wwh(v1) / Laundry Center
Frigidaire SM230JXD2 Wwh(v3) / Laundry Center
Frigidaire SM230JXD3 Wwh(v5) / Laundry Center
Frigidaire SM230JXD4 Wwh(v1) / Laundry Center
Frigidaire SM230JXW1 Wwh(v2) / Laundry Center
Frigidaire SM230JXW2 Wwh(v4) / Laundry Center
Frigidaire SM230JXW3 Wwh(v6) / Laundry Center
Frigidaire SM230JXW4 Wwh(v2) / Laundry Center
Frigidaire SM230LXD1 Wwh(v2) / Laundry Center
Frigidaire SM230LXD2 Wwh(v2) / Laundry Center
Frigidaire SM230LXW1 Wwh(v1) / Laundry Center
Frigidaire SM230LXW2 Wwh(v1) / Laundry Center
Frigidaire SM230MXD1 Wwh(v2) / 24 " Laundry Center
Frigidaire SM230MXD2 Wwh(v2) / 24 " Laundry Center
Frigidaire SM230MXW1 Wwh(v1) / 24 " Laundry Center
Frigidaire SM230MXW2 Wwh(v1) / 24 " Laundry Center
Frigidaire SM230PXD1 Wwh(v2) / 24 " Laundry Center
Frigidaire SM230PXD2 Wwh(v2) / 24 " Laundry Center
Frigidaire SM230PXD3 Wwh(v2) / 24 " Laundry Center
Frigidaire SM230PXW1 Wwh(v1) / 24 " Laundry Center
Frigidaire SM230PXW2 Wwh(v1) / 24 " Laundry Center
Frigidaire SM230PXW3 Wwh(v1) / 24 " Laundry Center
Thermador SM272B
Thermador SM272S
Thermador SM272W
Thermador SM272YB AFTER S/N 8204
Thermador SM272YS AFTER S/N 8204
Thermador SM272YW AFTER S/N 8204
Thermador SM272ZS AFTER S/N 8204
Whirlpool SM958PEKW0 Range (gas)*
Whirlpool SM958PEKW1 Range (gas)*
Whirlpool SM958PEKW2 Range (gas)*
Whirlpool SM958PEPW0 Range (gas)*
Whirlpool SM958PEPW1 Range (gas)*
Whirlpool SM958PESW0 Range (gas)*
Whirlpool SM958PESW1 Range (gas)*
Whirlpool SM958PESW2 Range (gas)*
Whirlpool SM958PESW3 Range (gas)*
Whirlpool SM958PESW4 Range (gas)*
Whirlpool SM958PESW5 Range (gas)*
Whirlpool SM958PSKW0 Range (gas)*
Whirlpool SM958PSKW1 Range (gas)*
Whirlpool SM958PSKW2 Range (gas)*
Hardwick SM9642A580R RANGE- F/S STD GAS
Hardwick SM9642W580R RANGE- F/S STD GAS
Whirlpool SM980PEYW0 Range (gas)*
Whirlpool SM980PEYW2 Range (gas)*
Whirlpool SM988PEPW0 Range (gas)*
Whirlpool SM988PEPW1 Range (gas)*
Whirlpool SM988PEPW2 Range (gas)*
Whirlpool SM988PESW0 Range (gas)*
Whirlpool SM988PESW1 Range (gas)*
Whirlpool SM988PESW2 Range (gas)*
Whirlpool SM988PESW3 Range (gas)*
Whirlpool SM988PESW7 Range (gas)*
Whirlpool SM988PESW8 Range (gas)*
Amana SMC-1 COMPACTOR
Amana SMC-1-A COMPACTOR
Amana SMC-1-AG COMPACTOR
Amana SMC-1-C COMPACTOR
Amana SMCD-2 COMPACTOR
Amana SMCD-2-A COMPACTOR
Amana SMCD-2-AG COMPACTOR
Amana SMCD-2-C COMPACTOR
Amana SMCD-2B-A COMPACTOR
Amana SMCD-2B-AG COMPACTOR
Amana SMCD-2B-C COMPACTOR
Amana SMCD-2B-L COMPACTOR
Amana SMCD-2W COMPACTOR
Amana SMCD-2W-A COMPACTOR
Amana SMCD-2W-AG COMPACTOR
Amana SMCD-2W-C COMPACTOR
Amana SMCD-2W/-AG COMPACTOR
Amana SMCD2B COMPACTOR
Amana SMD21TBW REF - SXS/I&W
Amana SMD22TBW REF - SXS/I&W
Amana SMD25TW REF - SXS/I&W
 SMH4150BD MWAVE- MOUNTED OVER RANGE/WO
 SMH4150WD MWAVE- MOUNTED OVER RANGE/WO
 SMH6140BB MWAVE- MOUNTED OVER RANGE/WO
 SMH6140CB MWAVE- MOUNTED OVER RANGE/WO
 SMH6140WB MWAVE- MOUNTED OVER RANGE/WO
 SMH7150BC MWAVE- MOUNTED OVER RANGE/WO
 SMH7150BE MWAVE- MOUNTED OVER RANGE/WO
 SMH7150BE/XAA MWAVE- MOUNTED OVER RANGE/WO
 SMH7150CC MWAVE- MOUNTED OVER RANGE/WO
 SMH7150CE MWAVE- MOUNTED OVER RANGE/WO
 SMH7150CE/XAA MWAVE- MOUNTED OVER RANGE/WO
 SMH7150WC MWAVE- MOUNTED OVER RANGE/WO
 SMH7159BC MWAVE- MOUNTED OVER RANGE/WO
 SMH7159CC MWAVE- MOUNTED OVER RANGE/WO
 SMH7159WC MWAVE- MOUNTED OVER RANGE/WO
 SMH7174BC MWAVE- MOUNTED OVER RANGE/WO
 SMH7174BE MWAVE- MOUNTED OVER RANGE/WO
 SMH7174BE/XAA MWAVE- MOUNTED OVER RANGE/WO
 SMH7174CC MWAVE- MOUNTED OVER RANGE/WO
 SMH7174WC MWAVE- MOUNTED OVER RANGE/WO
 SMH7174WE MWAVE- MOUNTED OVER RANGE/WO
 SMH7174WE/XAA MWAVE- MOUNTED OVER RANGE/WO
Reply
« G E | help »
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE dual evap Profile PS model, coils freezing over half-past Refrigerator & Freezer Repair 7 05-31-2017 10:44 AM
GE side-by-side evap. coils freezing, fridge freezing at bottom and not cold at top jttaylor Refrigerator & Freezer Repair 16 03-26-2012 12:45 PM
GE - fridge freezing in drawers, freezer not freezing at top, but coils frozen over jaxcarlson Refrigerator & Freezer Repair 0 12-01-2009 09:42 AM
1969 Model - Probably Coils? graphicsdewd Dryer Repair 1 06-29-2009 09:12 PM
Sub Zero 201 FD Freezer is not freezing and coils are frosting over/freezing up badace Refrigerator & Freezer Repair 1 12-02-2007 09:54 AM
