Discuss
AC trips breaker when condenser is connected
 in
Heating, Ventilation, and Air Conditioning (HVAC)
I tested the continuity between all the terminals, and for the fan also, and all readings resulted in 2.9ohms if
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » AC trips breaker when condenser is connected
  #1 (permalink)
Old 03-16-2016, 03:55 PM
Junior Member
juntjoo is on a distinguished road
Default AC trips breaker when condenser is connected
Brand: -brand-   Age: 5 - 10 years
I tested the continuity between all the terminals, and for the fan also, and all readings resulted in 2.9ohms if I read it correctly. I was following some articles online and YouTube. Anyway, not sure what the consistent readings mean. I learned elsewhere that for the compressor the combined resistance between two terminals is supposed to equal the resistance between two others. Besides rise technical details, the only thing that makes sense to me is that the main breaker doesn't trip if I leave the condenser disconnected(unscrewed two wires to this wire bridge connector whatever it's called)
Are there any other tests I should try at this point? I also tested the capacitor which shot the needle up then dropped back down for resistance across different terminal combinations. Supposedly that's a sign of a healthy capacitor. Fan moves nicely by hand.
Are compressors something you can DIY or do I need to pay a tech big bucks? Thanks!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Breaker trips after 45 Ken Martin Dryer Repair 3 07-27-2011 04:08 AM
Breaker trips after 45 Ken Martin Dryer Repair 1 07-26-2011 05:09 PM
trips breaker dstallings Dishwasher Repair 0 08-23-2009 07:39 PM
Breaker Trips rocker5164 Dryer Repair 3 10-13-2008 12:30 PM
