| » Blower motor won't work. |
Model Number: 80 SSE Brand: Amana Age: More than 10 years
I thought motor was bad because when a call for heat is requested the exhaust blower kicks on, the burners ignite, but the blower motor does not turn on. I even installed a new motor thinking that was problem. Any suggestion at this point will help.
Thanks rbeckner2. Related Models |
More than likely the fan limit switch is your culprit, it's designed to operate the blower fan after the combustion chamber reaches a preset temp and keep it operating after the room thermostat is satisfied and the burners shutoff... The blower will 'cool off' the combustion chamber to a second preset temp on the limit switch... Certain types of this limit switch have a button on the front that will allow you to manually operate the blower motor continuously.. Locate this switch and push or pull the button if one exists and the blower should come on... Turn off the power if you're unfamiliar with this control and remove the cover of the limit switch to find the part number to help with finding a replacement...
__________________
| Display Modes | |
| Blower motor for sears furnace | dickcollentine | Heating, Ventilation, and Air Conditioning (HVAC) | 5 | 12-06-2008 05:59 AM |
| The lights work, motor doesn't?? | Luis | Refrigerator & Freezer Repair | 3 | 02-15-2008 12:46 PM |
| Motor won't work | erose | Washer Repair | 0 | 01-17-2008 06:46 PM |
| Blower Motor for Sears Furnace | dickcollentine | Heating, Ventilation, and Air Conditioning (HVAC) | 1 | 12-12-2007 12:57 PM |
| Replacing old dryer blower with new | Aaron Felty | Dryer Repair | 3 | 12-11-2007 02:10 PM |
