Discuss
VERY hot air handler relay
 in
Heating, Ventilation, and Air Conditioning (HVAC)
I have an ancient Trane furnace/ac unit (inside gas furnace with cooling evaporator above that, outside air conditioner/compressor unit). The
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » VERY hot air handler relay
  #1 (permalink)
Old 06-16-2015, 02:54 AM
Junior Member
seldomvisitor is on a distinguished road
Default VERY hot air handler relay
Model Number: Trane - 90340   Brand: -other-   Age: Less than 1 year
I have an ancient Trane furnace/ac unit (inside gas furnace with cooling evaporator above that, outside air conditioner/compressor unit). The inside box(es) have the air handler/blower - that blower's motor is switched by a 24VAC relay driven off a transformer that also sends 24VAC to the thermostat and outside contactor (relay) coil.
Anyway, this all works. Can turn on the fan switch on the thermostat and the blower runs, can turn on cooling and the outside contactor does its thing, the whole nine yards.
But...
The 24VAC relay's coil (standard 90340 style: image search for "90340 relay" to see lots of images of it) gets extremely hot - WAY too hot to touch. So, being naive and figuring there might be some sort of internal short in the relay's coil, I just replaced it.
The replacement relay is getting WAY too hot to touch.
The specs for the relay say it's 10VA for the coil. I believe that (~6W?) suggests the wattage could be enough to heat up the thing, maybe quite a bit.
But still...
Is this extreme temperature normal behavior for an otherwise working fine air handler relay/relay coil?
If not, where could I look to find what's causing the current draw/heating through the relay's coil? (I removed the relay, cleaned its plugs, and replaced it - same heat; I also checked the voltage across the coil and it was ~24 VAC so no short from wall voltage/current)
One of the next steps (to just prove to myself that this IS normal) would be to simply unplug the relay and wire JUST its coil to the transformer to prove that it is indeed the coil that's causing the heat (that is, disconnecting the relay completely from everything other than the coil connection).
But I thought I'd check here first.
Anyone seen this? Anyone have a quick answer? Procedure?
Thanks very much for any feedback.
Related Models
Amana TRG16J REF - TOP MOUNT
Amana TRG18J REF - TOP MOUNT
Amana TRG18K REF - TOP MOUNT
Amana TRG18M REF - TOP MOUNT
Amana TRG18N REF - TOP MOUNT
Amana TRG18QB2L REF - TOP MOUNT
Amana TRG18QB2W REF - TOP MOUNT
Amana TRG18QB3G REF - TOP MOUNT
Amana TRG18QB3L REF - TOP MOUNT
Amana TRG18QB3W REF - TOP MOUNT
Amana TRG18QBG REF - TOP MOUNT
Amana TRG18QBL REF - TOP MOUNT
Amana TRG18QBW REF - TOP MOUNT
Amana TRG18SPH REF - TOP MOUNT
Amana TRG20J REF - TOP MOUNT
Amana TRG20M REF - TOP MOUNT
Amana TRG20SPH REF - TOP MOUNT
Amana TRG22J REF - TOP MOUNT
Amana TRGI18J REF - TOP MOUNT
Amana TRGI18QBL REF - TOP MOUNT
Amana TRGI18QBW REF - TOP MOUNT
Amana TRGI20J REF - TOP MOUNT
Amana TRGI22J REF - TOP MOUNT
Amana TRI-17D MISC / ACCESSORY
Amana TRI-17D-1 MISC / ACCESSORY
Amana TRI-17E MISC / ACCESSORY
Amana TRI-17LD MISC / ACCESSORY
Amana TRI-17LD-1 MISC / ACCESSORY
Amana TRI-17LE MISC / ACCESSORY
Amana TRI16K REF - TOP MOUNT
Amana TRI17E MISC / ACCESSORY
Amana TRI17LE MISC / ACCESSORY
Amana TRI18D REF - TOP MOUNT
Amana TRI18D MISC / ACCESSORY
Amana TRI18D-A REF - TOP MOUNT
Amana TRI18D-C REF - TOP MOUNT
Amana TRI18D-G REF - TOP MOUNT
Amana TRI18D-L REF - TOP MOUNT
Amana TRI18E MISC / ACCESSORY
Amana TRI18E-A MISC / ACCESSORY
Amana TRI18E-C MISC / ACCESSORY
Amana TRI18E-G MISC / ACCESSORY
Amana TRI18E-L MISC / ACCESSORY
Amana TRI18J REF - TOP MOUNT
Amana TRI18K REF - TOP MOUNT
Amana TRI18TE REF - TOP MOUNT
Amana TRI18TL REF - TOP MOUNT
Amana TRI18TW REF - TOP MOUNT
Amana TRI18V1E REF - TOP MOUNT
Amana TRI18V1L REF - TOP MOUNT
Amana TRI18V1W REF - TOP MOUNT
Amana TRI20K REF - TOP MOUNT
Amana TRI21S4E REF - TOP MOUNT
Amana TRI21S4L REF - TOP MOUNT
Amana TRI21S4W REF - TOP MOUNT
Amana TRI21VE REF - TOP MOUNT
Amana TRI21VL REF - TOP MOUNT
Amana TRI21VW REF - TOP MOUNT
Amana TRI22S4 REF - TOP MOUNT
Amana TRI22S4E REF - TOP MOUNT
Amana TRI22S4L REF - TOP MOUNT
Amana TRI22S4W REF - TOP MOUNT
Amana TRI22SRL REF - TOP MOUNT
Amana TRI25S5E REF - TOP MOUNT
Amana TRI25S5L REF - TOP MOUNT
Amana TRI25S5W REF - TOP MOUNT
Amana TRI25VE REF - TOP MOUNT
Amana TRI25VL REF - TOP MOUNT
Amana TRI25VW REF - TOP MOUNT
Admiral TRIS225BAW REF - SXS/I&W
Admiral TRIS225FAW REF - SXS/I&W
Admiral TRIS245BBW REF - SXS/I&W
Admiral TRIS245FBW REF - SXS/I&W
Frigidaire TRS20WRHD0 Tap(v1) / Refrigerator
Frigidaire TRS20WRHD1 Tap(v1) / Side By Side Refrigerator
Frigidaire TRS20WRHD2 Tap(v1) / Side By Side Refrigerator
Frigidaire TRS20WRHD3 Tap(v2) / Side By Side Refrigerator
Frigidaire TRS20WRHD4 Tap(v1) / Refrigerator
Frigidaire TRS20WRHD5 Tap(v1) / Refrigerator
Frigidaire TRS20WRHW0 Tap(v2) / Refrigerator
Frigidaire TRS20WRHW1 Tap(v2) / Side By Side Refrigerator
Frigidaire TRS20WRHW2 Tap(v3) / Side By Side Refrigerator
  #2 (permalink)
Old 06-16-2015, 02:11 PM
Junior Member
speedracer2015 is on a distinguished road
Default
Check the voltage output of the low voltage transformer. IF you have an amp meter place on low scale and put in series with one of the relay low voltage (control) terminals and see what it is reading. IF high, in some cases when the transformer gets old or has been replaced with a transformer of less VA (voltamps) than the original it causes relays and other items dependent on the low voltage to also draw more current = more heat. Just my .02 and good luck..
  #3 (permalink)
Old 06-16-2015, 04:07 PM
Junior Member
Default
Just a followup that may end the thread, though feedback from anyone who has noted this excessive heat themselves is certainly still appreciated.
Anyway, to answer the above reply, the voltage out of the transformer to the relay's coil is correct - 24-ish VAC.
I unplugged the relay, set it on a nonconductive surface, and attached jumpers from the transformer to the relay's coil connectors. I then turned on the air handler power (though only the transformer then got power because the relay wasn't plugged in, disconnecting everything else from the mains), the relay made a significant clunk as it engaged, and then I let it sit like that for about 15 minutes. When I came back the relay was, again, WAY too hot to touch/handle.
So that's that. The heat is totally being generated from the relay's coil (since all other relay connectors were disconnected since it was unplugged). It didn't matter which of the two relays were checked (ancient or new), they both got too hot to touch. From these two datapoints (huge dataset!), I'm concluding that this is indeed normal behavior for the 90340 relay being fed directly from a 24VAC transformer.
Of course, if you know otherwise or have that experience please correct me.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Janitrol air handler depmoss@hotmail.com Heating, Ventilation, and Air Conditioning (HVAC) 0 12-29-2013 07:39 PM
Maytag start relay connector too small for new start relay jrzus Refrigerator & Freezer Repair 12 03-22-2011 01:02 PM
air handler transformer keeps blowing!!! jonzo Heating, Ventilation, and Air Conditioning (HVAC) 1 01-24-2011 06:45 PM
