Discuss
Lennox G24M series Furnace Story and Questions
 in
Heating, Ventilation, and Air Conditioning (HVAC)
First a story, then questions. (Images below) Once upon a time my friend had a gas furnace that would shut
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » Lennox G24M series Furnace Story and Questions
  #1 (permalink)
Old 11-21-2014, 08:59 AM
Junior Member
drcarl is on a distinguished road
Default Lennox G24M series Furnace Story and Questions
Model Number: G24M   Brand: -other-   Age: 5 - 10 years
Once upon a time my friend had a gas furnace that would shut down on its own, sometimes after a few hours and sometimes after a few minutes. I did some research, then opened her up (the furnace, not the friend) and removed and cleaned the burners, igniter, and flame sensor.
Before buttoning her up, I sat there and watched the furnace go through its paces. Everything looked great until I spotted a wire laying on the burner box top. Its pool of brown melting/melted plastic insulation was turned black.
To me, this looked like an accident in progress, and about to get worse, so I lifted the wire and held it up off of the now heating hot burner box top with a socket driver in my left hand, and the tip of my knife in my right.
With both hands occupied, and unable to abandon my post, I wondered how I was going to get the furnace turned off. At that moment, with a great luck my friend appeared and I said, “Would you please turn it off?”
With the furnace off, now I could relax and take a closer look. I keep repeating my mantra: “I am not a furnace repair man,” yet I have eyes and a brain...so I contemplated what sat before me and noticed some things.
One of the wires going to the left rollout switch (not the melted one) had been tied into a loop thus “shortening” the wire. I saw that it was not in contact with the burner box top like my melting one was. So, I tied a loop in my melted wire.
Inspecting the bundle of wires that my melted wire led to, I noticed that the way the bundle was clipped to the side of the box, there was so much slack that many of the other wires were touching, or very close to the burner box top. So, I opened the clip, moved the wire bundle up a ways to remove the slack, and clipped them back.
It’s my uneducated belief that the insulation on the rollout switch wire is there to prevent its shorting out on anything, and that as long as the copper is healthy, the wire will perform its wire functions just fine.
I then noticed a little metal plate near or maybe partially covering an opening in the burner box top next to the igniter...I wondered about functions involved here... and what the proper configuration is supposed to be... hmmm
QUESTIONS
(1) What would happen if a rollout switch wire was resting atop the burner box top once it gets hot and potentially shorts-out the rollout switch wire?
(2) Could this have been the root cause of the problem all along?
(3) Is a little wrap of electrical tape enough of a band-aid for the wire’s melted insulation, or is more a more drastic (complicated) remedy (like splicing or replacing the wire) required?
(4) Now that the wire is looped and suspended nicely, does it even need any tape at all?
(5) What needs to happen with the opening in the burner box top? Move the little loose metal plate off and leave it open? Should it be covered? Does it need to be secured in some way? Discarded?
(6) What else should I ask here that I don’t know to ask about?
Thanks in advance,
drcarl
Related Models
Frigidaire G24PCL0 Frg(v3) / Gas Range
Frigidaire G24PCL1 Frg(v5) / Gas Range
Frigidaire G24PCL3 Frg(v2) / Gas Range
Frigidaire G24PCL4 Frg(v4) / Gas Range
Frigidaire G24PCW0 Frg(v4) / Gas Range
Frigidaire G24PCW1 Frg(v6) / Gas Range
Frigidaire G24PCW3 Frg(v1) / Gas Range
Frigidaire G24PCW4 Frg(v3) / Gas Range
Frigidaire G25BNL0 Frg(v2) / Gas Range
Frigidaire G25BNW0 Frg(v1) / Gas Range
Whirlpool G25EFSB2313 REFRIGERATOR
Whirlpool G25EFSB23S4 REFRIGERATOR
Whirlpool G25EFSB23S5 REFRIGERATOR
Whirlpool G25EFSB23S6 REFRIGERATOR
Whirlpool G25EFSB23S7 REFRIGERATOR
Whirlpool G25EFSB23S8 REFRIGERATOR
Whirlpool G25EFSB23S9 REFRIGERATOR
Whirlpool G2IXEFMWB00 REFRIGERATOR
Whirlpool G2IXEFMWB01 REFRIGERATOR
Whirlpool G2IXEFMWB02 REFRIGERATOR
Whirlpool G2IXEFMWB03 REFRIGERATOR
Whirlpool G2IXEFMWQ00 REFRIGERATOR
Whirlpool G2IXEFMWQ01 REFRIGERATOR
Whirlpool G2IXEFMWQ02 REFRIGERATOR
Whirlpool G2IXEFMWQ03 REFRIGERATOR
Whirlpool G2IXEFMWS00 REFRIGERATOR
Whirlpool G2IXEFMWS01 REFRIGERATOR
Whirlpool G2IXEFMWS02 REFRIGERATOR
Whirlpool G2IXEFMWS03 REFRIGERATOR
Frigidaire G30BCL2 Frg(v2) / Gas Range
Frigidaire G30BCW1 Frg(v1) / Gas Range
Frigidaire G30CL0 Frg(v5) / Gas Range
Frigidaire G30CL2 Frg(v2) / Gas Range
Frigidaire G30CL3 Frg(v4) / Gas Range
Frigidaire G30CW0 Frg(v6) / Gas Range
Frigidaire G30CW2 Frg(v1) / Gas Range
Frigidaire G30CW3 Frg(v3) / Gas Range
Frigidaire G30LPNL1 Frg(v2) / Gas Range
Frigidaire G30LPNL2 Frg(v2) / Gas Range
Frigidaire G30LPNL3 Frg(v2) / Gas Range
Frigidaire G30LPNW1 Frg(v1) / Gas Range
Frigidaire G30LPNW2 Frg(v1) / Gas Range
Frigidaire G30LPNW3 Frg(v1) / Gas Range
Frigidaire G30NL1 Frg(v1) / Gas Range
Frigidaire G30NL2 Frg(v2) / Gas Range
Frigidaire G30NL3 Frg(v3) / Gas Range
Frigidaire G30NL4 Frg(v4) / Gas Range
Frigidaire G30NL5 Frg(v2) / Gas Range
Frigidaire G30NL6 Frg(v2) / Gas Range
Frigidaire G30NL7 Frg(v4) / Gas Range
Frigidaire G30NW1 Frg(v5) / Gas Range
Frigidaire G30NW2 Frg(v6) / Gas Range
Frigidaire G30NW3 Frg(v7) / Gas Range
Frigidaire G30NW4 Frg(v8) / Gas Range
Frigidaire G30NW5 Frg(v1) / Gas Range
Frigidaire G30NW6 Frg(v1) / Gas Range
Frigidaire G30NW7 Frg(v3) / Gas Range
Frigidaire G30PCL0 Frg(v7) / Gas Range
Frigidaire G30PCL1 Frg(v7) / Gas Range
Frigidaire G30PCL3 Frg(v2) / Gas Range
Frigidaire G30PCW0 Frg(v8) / Gas Range
Frigidaire G30PCW1 Frg(v8) / Gas Range
Frigidaire G30PCW3 Frg(v1) / Gas Range
Frigidaire G30PNL1 Frg(v2) / Gas Range
Frigidaire G30PNL2 Frg(v2) / Gas Range
Frigidaire G30PNL3 Frg(v4) / Gas Range
Frigidaire G30PNL4 Frg(v6) / Gas Range
Frigidaire G30PNL6 Frg(v2) / Gas Range
Frigidaire G30PNL7 Frg(v2) / Gas Range
Frigidaire G30PNW1 Frg(v1) / Gas Range
Frigidaire G30PNW2 Frg(v1) / Gas Range
Frigidaire G30PNW3 Frg(v3) / Gas Range
Frigidaire G30PNW4 Frg(v5) / Gas Range
Frigidaire G30PNW6 Frg(v1) / Gas Range
Frigidaire G30PNW7 Frg(v1) / Gas Range
Admiral G3110PRA-M RANGE- F/S STD GAS
Admiral G3110PRA5K RANGE- F/S STD GAS
Admiral G3110PRW-M RANGE- F/S STD GAS
Admiral G3110PRW5K RANGE- F/S STD GAS
Admiral G3127WRA RANGE- F/S STD GAS
Admiral G3127WRA-3 RANGE- F/S STD GAS
Admiral G3127WRA-4 RANGE- F/S STD GAS
Admiral G3127WRA-5 RANGE- F/S STD GAS
Admiral G3127WRV RANGE- F/S STD GAS
Admiral G3127WRV-3 RANGE- F/S STD GAS
Admiral G3127WRV-4 RANGE- F/S STD GAS
Admiral G3127WRW-3 RANGE- F/S STD GAS
Admiral G3127WRW-4 RANGE- F/S STD GAS
Admiral G3127XRA-5 RANGE- F/S STD GAS
Frigidaire G31BFH0 Frg(v3) / Gas Range
Frigidaire G31BFH1 Frg(v6) / Gas Range
Frigidaire G31BFL0 Frg(v2) / Gas Range
Frigidaire G31BFL1 Frg(v5) / Gas Range
Frigidaire G31BFW0 Frg(v1) / Gas Range
Frigidaire G31BFW1 Frg(v4) / Gas Range
Frigidaire G31BPNL1 Frg(v2) / Gas Range
Frigidaire G31BPNL2 Frg(v4) / Gas Range
Frigidaire G31BPNL3 Frg(v2) / Gas Range
Frigidaire G31BPNL4 Frg(v2) / Gas Range
Frigidaire G31BPNL5 Frg(v2) / Gas Range
Frigidaire G31BPNL6 Frg(v2) / Gas Range
Frigidaire G31BPNW1 Frg(v1) / Gas Range
Frigidaire G31BPNW2 Frg(v3) / Gas Range
Frigidaire G31BPNW3 Frg(v1) / Gas Range
Frigidaire G31BPNW4 Frg(v1) / Gas Range
Frigidaire G31BPNW5 Frg(v1) / Gas Range
Frigidaire G31BPNW6 Frg(v1) / Gas Range
Admiral G32026PEKB REF - BOTTOM MOUNTS
Admiral G32026PEKS REF - BOTTOM MOUNTS
Maytag G32026PEKS13 REFRIGERATOR
Maytag G32026PEKS4 REFRIGERATOR
Maytag G32026PEKS5 REFRIGERATOR
Maytag G32026PEKS6 REFRIGERATOR
Maytag G32026PEKS7 REFRIGERATOR
Admiral G32026PEKW REF - BOTTOM MOUNTS
Maytag G32026PEKW12 REFRIGERATOR
Maytag G32026PEKW3 REFRIGERATOR
Maytag G32026PEKW4 REFRIGERATOR
Admiral G32026PELB REF - BOTTOM MOUNTS
Maytag G32026PELB12 REFRIGERATOR
  #2 (permalink)
Old 11-24-2014, 04:25 PM
Junior Member
Default Anyone?
Any furnace people here?
  #3 (permalink)
Old 12-03-2014, 12:15 PM
Junior Member
Default anybody home?
HELLO....Hello......hello......ello..........lo... ...lo......lo.....
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Lennox PUlse G14 Furnace sometimes starts rydholm11211 Heating, Ventilation, and Air Conditioning (HVAC) 3 10-28-2012 12:59 AM
A/C Issue - Lennox furnace fixerguy123 Heating, Ventilation, and Air Conditioning (HVAC) 1 07-10-2012 06:55 AM
Gas Hot Water Furnace questions Kilapapipa Heating, Ventilation, and Air Conditioning (HVAC) 1 11-24-2009 09:57 AM
