Discuss
Water at Bottom of Wine Refrigerator
 in
Heating, Ventilation, and Air Conditioning (HVAC)
Compressor running and cooling great, both fans are running, the coil is clean, etc. Condensation on wine btls; small pool
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » Water at Bottom of Wine Refrigerator
  #1 (permalink)
Old 10-16-2014, 10:30 PM
Junior Member
Agosti is on a distinguished road
Default Water at Bottom of Wine Refrigerator
Model Number: XR-142   Brand: -other-   Age: More than 10 years
Compressor running and cooling great, both fans are running, the coil is clean, etc. Condensation on wine btls; small pool of water collects on the bottom of the unit. (1) applied weather stripping where the door gasket seals condensation reduced about 50-70%% but water still collecting on the bottom; and (2) verified drain hole is not plugged. Door gasket isn't cracked or torn, however, we were able to pull it back easily in several places but figured weather-stripping would resolve that issue. Searched the Web for a replacement gasket but find nothing - probably b/c the unit is old and b/c Wine Enthusiast (Lord Winston 50 Btl) outsourced these units but doesn't indicate to who. Don't know what else to do.
Related Models
Amana XRBR206BB REF - BOTTOM MOUNTS
Amana XRBR206BW REF - BOTTOM MOUNTS
Amana XRBR904BB REF - BOTTOM MOUNTS
Amana XRBR904BS REF - BOTTOM MOUNTS
Amana XRBR904BW REF - BOTTOM MOUNTS
Amana XRBS017BB REF - BOTTOM MOUNTS
Amana XRBS017BW REF - BOTTOM MOUNTS
Amana XRBS209BBR REF - BOTTOM MOUNTS
Amana XRBS209BSR REF - BOTTOM MOUNTS
Amana XRBS209BWR REF - BOTTOM MOUNTS
Amana XRSR465BW REF - SXS/I&W
Amana XRSR665BW REF - SXS/I&W
Amana XRSR687BW REF - SXS/I&W
Amana XRSS204BB REF - SXS
Amana XRSS204BW REF - SXS
Amana XRSS264BB REF - SXS/I&W
Amana XRSS264BW REF - SXS/I&W
Amana XRSS267BB REF - SXS/I&W
Amana XRSS267BW REF - SXS/I&W
Amana XRSS287BB REF - SXS/I&W
Amana XRSS287BW REF - SXS/I&W
Amana XRSS465BB REF - SXS/I&W
Amana XRSS665BB REF - SXS/I&W
Amana XRSS687BB REF - SXS/I&W
Amana XST-305 RANGE- S/C S/I DDRAFT GAS
Amana XST-307 RANGE- S/C S/I DDRAFT GAS
Amana XST-310 RANGE- S/C S/I DDRAFT GAS
Amana XST111 ELE CARTRIDGE
Amana XST111UB ELE CARTRIDGE
Amana XST111UB1 ELE CARTRIDGE
Amana XST111UW ELE CARTRIDGE
Amana XST111UW1 ELE CARTRIDGE
Amana XST111UWW1 ELE CARTRIDGE
Amana XST2022B RANGE- S/C S/I DDRAFT GAS
 XST2022W ELE CARTRIDGE
Amana XST2052B RANGE- S/C S/I DDRAFT GAS
Amana XST2052W RANGE- S/C S/I DDRAFT GAS
Amana XST2072B RANGE- S/C S/I DDRAFT GAS
Amana XST2072W RANGE- S/C S/I DDRAFT GAS
Amana XST209-2B RANGE- S/C S/I DDRAFT GAS
Amana XST209-2W RANGE- S/C S/I DDRAFT GAS
Amana XST2092B ELE CARTRIDGE
Amana XST2092K ELE CARTRIDGE
Amana XST2092W ELE CARTRIDGE
Amana XST229 ELE CARTRIDGE
Amana XST235 ELE CARTRIDGE
Amana XST310 ELE CARTRIDGE
Amana XST311U ELE CARTRIDGE
Amana XST329 ELE CARTRIDGE
Amana XST339 ELE CARTRIDGE
Whirlpool XVP5000TQ0 LAUNDRY TOWER
Whirlpool XVP8600TB0 LAUNDRY TOWER
Whirlpool XVP8600TU0 LAUNDRY TOWER
Whirlpool XVP8600TW0 LAUNDRY TOWER
Whirlpool XVP9000TA0 LAUNDRY TOWER
Whirlpool XVP9000TB0 LAUNDRY TOWER
Whirlpool XVP9000TU0 LAUNDRY TOWER
Whirlpool XVP9000TW0 LAUNDRY TOWER
Whirlpool XW18500VW0 SLIDE-OUT WORKSURFACE
Whirlpool XW29000TA0 LAUNDRY WORKSURFACE
Whirlpool XW29000TB0 LAUNDRY WORKSURFACE
Whirlpool XW29000TC0 LAUNDRY WORKSURFACE
Whirlpool XW29000TU0 LAUNDRY WORKSURFACE
Whirlpool XW29000TW0 LAUNDRY WORKSURFACE
Whirlpool XXHP1550VW0 PEDESTAL
Amana YA1200 WASHER-TOP LOADING
Whirlpool YACM052MM0 AIR CONDITIONER
Whirlpool YACM062MM0 AIR CONDITIONER
Whirlpool YACM082XK1 AIR CONDITIONER
Whirlpool YACM082XP0 AIR CONDITIONER
Whirlpool YACQ068MP0 AIR CONDITIONER
Whirlpool YACQ082XK1 AIR CONDITIONER
Whirlpool YACQ088MR0 AIR CONDITIONER
Whirlpool YACQ088XP0 AIR CONDITIONER
Whirlpool YACQ108MR0 AIR CONDITIONER
Whirlpool YACQ128XR0 AIR CONDITIONER
Maytag YAED4370TQ0 29" ELECTRIC DRYER
Maytag YAED4470TQ0 29" ELECTRIC DRYER
Maytag YAED4475TQ1 29" ELECTRIC DRYER
Maytag YAMV1160VAB0 Microwave Oven 1.6 Cu. Ft.
Maytag YAMV1160VAB1 MICROWAVE OVEN 1.6 CU. FT.
Maytag YAMV1160VAS0 Microwave Oven 1.6 Cu. Ft.
Maytag YAMV1160VAS1 MICROWAVE OVEN 1.6 CU. FT.
Maytag YAMV1160VAW0 Microwave Oven 1.6 Cu. Ft.
Maytag YAMV1160VAW1 MICROWAVE OVEN 1.6 CU. FT.
General Electric YBXR1060T2WW Washer
General Electric YBXR1060T3WW Washer
General Electric YBXR1060T4WW Washer
General Electric YBXR1060T5WW Washer
General Electric YBXR1060T8WW Washer
General Electric YBXR1060TAWW Washer
General Electric YBXR1060V0WW Washer
General Electric YBXR1060V1WW Washer
General Electric YBXR2070T2WW Washer
General Electric YBXR2070T3WW Washer
General Electric YBXR2070T5WW Washer
General Electric YBXR2070T6WW Washer
General Electric YBXR2070T8WW Washer
General Electric YBXR2070TAWW Washer
General Electric YBXR2070V0WW Washer
General Electric YBXR2070V1WW Washer
Whirlpool YCEDS563SQ0 29" ELECTRIC DRYER
Whirlpool YCEDX463RQ1 29"electric Dryer
Whirlpool YCEE2760KQ0 COMMERCIAL ELECTRIC DRYER
Whirlpool YCEE2760KQ1 COMMERCIAL ELECTRIC DRYER
  #2 (permalink)
Old 11-05-2014, 03:17 PM
Junior Member
bulletsnbrains is on a distinguished road
Default
Use a 'dollar bill test' to determine if there is any air getting past the gasket. Pinch dollar between gasket and unit front. pull on dollar to see if any resistance. Do in several places, especially on hinge side of door. Also look for any other sources of air leaks. I find the most prone location is around the heat exchanger passes from compressor area to evaporator. For the moisture already collecting inside unit, look to see if evap is draining into drain trough. Maybe some obstruction diverting condensate away from drain. Is there any moisture collecting in the drain pan under the unit? HTH
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Why my refrigerator leaks the water at the bottom q0987 Refrigerator & Freezer Repair 0 04-21-2011 10:23 AM
Water in bottom of refrigerator. olddog Refrigerator & Freezer Repair 2 08-04-2009 12:26 PM
water in bottom of refrigerator bcrist7258@aol.com Refrigerator & Freezer Repair 1 09-23-2008 06:08 PM
Water in bottom of Refrigerator Krankbait Refrigerator & Freezer Repair 0 06-04-2008 06:46 PM
Water in bottom of Refrigerator Krankbait Refrigerator & Freezer Repair 0 06-04-2008 07:56 AM
