Discuss
Window A/C compressor won't turn off
 in
Heating, Ventilation, and Air Conditioning (HVAC)
After 4 years of use, the compressor runs constantly for this window A/C unit. Regardless of the temperature and thermostat
Appliance Repair Forum > Appliance Repair Help > Heating, Ventilation, and Air Conditioning (HVAC) » Window A/C compressor won't turn off
  #1 (permalink)
Old 07-25-2014, 04:39 PM
Junior Member
nathanstrauss is on a distinguished road
Default Window A/C compressor won't turn off
Model Number: AKM14ANT1   Brand: GE   Age: 1 - 5 years
After 4 years of use, the compressor runs constantly for this window A/C unit. Regardless of the temperature and thermostat (which seems to work) the compressor stays on and cold air continues to blow. When I turn the unit off the compressor continues to hum. I have to unplug the unit to shut it off. When I plug back in and try again, same problem. Two questions:
1) which part do i need to replace
2) is it possible to replace it myself
The unit is in a very tight spot and nearly impossible to remove from window entirely - so i'd like to fix if possible rather than replace - assuming i can access and replace the right part without removing entire thing from window.
thank you!!
Related Models
General Electric AKM14ANT1 ROOM AIR CONDITIONER
General Electric AKM18DNT1 ROOM AIR CONDITIONER
Amana AKM1B SURFACE UNIT- ELE
Amana AKM1C SURFACE UNIT- ELE
General Electric AKM25DNT1 ROOM AIR CONDITIONER
General Electric AKN05LAG1 Room air conditioner
General Electric AKN06LAM1 Room air conditioner
General Electric AKN08FAM1 Room air conditioner
Amana AKO2000E SURFACE UNIT- GAS
Amana AKO2000K SURFACE UNIT- GAS
Amana AKO2000WW SURFACE UNIT- GAS
General Electric AKQ08ANQ1 ROOM AIR CONDITIONER
General Electric AKQ08ANW1 ROOM AIR CONDITIONER
General Electric AKQ08FAM1 Room air conditioner
General Electric AKQ10ANT1 ROOM AIR CONDITIONER
General Electric AKQ10ANW1 ROOM AIR CONDITIONER
General Electric AKQ12ANT1 ROOM AIR CONDITIONER
General Electric AKQ12ANW1 ROOM AIR CONDITIONER
General Electric AKQ12DNT1 ROOM AIR CONDITIONER
General Electric AKQ24DNT1 ROOM AIR CONDITIONER
Amana AKR2000E FREEZER- CHEST
Amana AKR2000K FREEZER- CHEST
Amana AKR2000WW FREEZER- CHEST
Amana AKR3000E FREEZER- CHEST
Amana AKR3000LL FREEZER- CHEST
Amana AKR3000SS FREEZER- CHEST
Amana AKR3000WW FREEZER- CHEST
Amana AKR3001E FREEZER- CHEST
Amana AKR3001LL FREEZER- CHEST
Amana AKR3001SS FREEZER- CHEST
Amana AKR3001WW FREEZER- CHEST
Amana AKR30E SURFACE UNIT- ELE
Amana AKR30K SURFACE UNIT- ELE
Amana AKR30WW SURFACE UNIT- ELE
General Electric AKS05LAE1 ROOM AIR CONDITIONER
General Electric AKS05LBG1 Room air conditioner
Amana AKS30 SURFACE UNIT- GAS
Amana AKS3020L SURFACE UNIT- GAS
Amana AKS3020W SURFACE UNIT- GAS
Amana AKS3030E SURFACE UNIT- GAS
Amana AKS3030SS SURFACE UNIT- GAS
Amana AKS3030WW SURFACE UNIT- GAS
Amana AKS3040BCC SURFACE UNIT- GAS
Amana AKS3040BE SURFACE UNIT- GAS
Amana AKS3040BSS SURFACE UNIT- GAS
Amana AKS3040BWW SURFACE UNIT- GAS
Amana AKS3040E RANGE- S/C S/I DDRAFT GAS
Amana AKS3040LL RANGE- S/C S/I DDRAFT GAS
Amana AKS3040SS RANGE- S/C S/I DDRAFT GAS
Amana AKS3040WW RANGE- S/C S/I DDRAFT GAS
Amana AKS3050CC SURFACE UNIT- GAS
Amana AKS3050E SURFACE UNIT- GAS
Amana AKS3050SS SURFACE UNIT- GAS
Amana AKS3050WW SURFACE UNIT- GAS
Amana AKS3080SS SURFACE UNIT- GAS
Amana AKS30WW SURFACE UNIT- GAS
Amana AKS3640CC SURFACE UNIT- GAS
Amana AKS3640E SURFACE UNIT- GAS
Amana AKS3640SS SURFACE UNIT- GAS
Amana AKS3640WW SURFACE UNIT- GAS
General Electric AKT05LNT1 ROOM AIR CONDITIONER
General Electric AKT05LNW1 ROOM AIR CONDITIONER
Amana AKT3000E SURFACE UNIT- ELE
Amana AKT3000W RANGE- S/C S/I DDRAFT GAS
Amana AKT3000WW SURFACE UNIT- ELE
Amana AKT3020E SURFACE UNIT- ELE
Amana AKT3020WW SURFACE UNIT- ELE
Amana AKT3040E SURFACE UNIT- ELE
Amana AKT3040SS SURFACE UNIT- ELE
Amana AKT3040WW SURFACE UNIT- ELE
Amana AKT3630E SURFACE UNIT- ELE
  #2 (permalink)
Old 08-08-2014, 10:58 PM
Junior Member
sharonringer is on a distinguished road
Default
If you are good with handling electrical work then you should replace the capacitor yourself.
Heat Recovery Ventilator & Systems | Warm Home Ventilation| Ventis
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
LG Window AC, compressor runs non-stop Brian Mc Heating, Ventilation, and Air Conditioning (HVAC) 1 09-16-2015 01:26 AM
Window A/C Compressor Fan upny12 Heating, Ventilation, and Air Conditioning (HVAC) 0 07-18-2013 10:26 AM
Window Air Conditioner compressor help??? SevillianSTS Heating, Ventilation, and Air Conditioning (HVAC) 2 12-14-2009 10:35 PM
A/C window unit compressor always on zygote7 Heating, Ventilation, and Air Conditioning (HVAC) 1 04-26-2009 05:12 PM
Window a/c compressor noise Justinjt Heating, Ventilation, and Air Conditioning (HVAC) 0 07-29-2008 11:05 PM
